    Geodesic roof help
    23 Posts 6 Posters 4.1k Views 6 Watching
      disturbed13
      im trying to cover a roof on my house design with triangle windows
      but its not working out
      http://i107.photobucket.com/albums/m294/hedoe/glassroof_zps4238ba8b.jpg
      dont mind that 'stray' triangle
      as a FYI
      the roof is an arch that is 4' high at peak
      the shape is the interior of the room that i want the windows to be in
      so the right side is at 4' and so is the left
      the bottom 3 edges are flat
      and i have left the pitch change in the model to guide me when i place the windows
      any suggestions on how i could cover this roof with triangle or a window of the same shape
      and that is repeatable
      would be greatly appreciated
      • TaffGochT
        TaffGoch
        disturbed13,
        Is the perimeter a regular hexagon?
        You indicate that the roof profile is 4' high, but the other dimensions you provided are unclear (as to which entities they apply.)
        -Taff
        "Information is not knowledge." -- Albert Einstein
        • TaffGochT
          TaffGoch
          Perhaps, providing the SketchUp model of what you've done, so far, is in order.
          -Taff
            disturbed13
            -Taff
            okay
            i have some other parts in the model on other layers
            i have all of my second floor on there
            and im trying to cover the center room roof in windows
            oops....
            my file is 15 MB
            ill try to pm or email it to you
              disturbed13
              so yeah that didnt work either
              so i got pdf views
              they are virtually printed on A1 paper
              so they are kinda big
              roof 4ft archmk1a.pdf
              roof 4ft archmk1right.pdf
              • TaffGochT
                TaffGoch
                Uhmmm, jpegs & pdfs don't help.
                I suggested uploading your model, so that I could measure & build upon geometry that is fixed and shouldn't change.
                You can save the model, using a NEW name, then edit the new model to delete everything but the subject geometry. The resulting model will be MUCH smaller.
                I don't really need to know anything about the remaining geometry of the house.
                  disturbed13
                  okay lets see if this works
                  so its 15MB still
                  but i got a dropbox account
                  https://www.dropbox.com/sh/y12qr2i8su78eln/HSvVqZssz8
                  and you should be able to go there and download it from there
                  i hope
                  • TaffGochT
                    TaffGoch
                    disturbed13,
                    Good download, of the 15Mb file.
                    I immediately opened it, purged unused geometry, and got a file size of 74.5Kb
                    %(#8000BF)[
                    From Goggle:
                    Open the SketchUp file, and click "Window" > "Model Info" > "Statistics" > "Purge Unused."
                    From "SketchUp Sage":
                    https://sites.google.com/site/sketchupsage/faster/purge
                    Back to the model - I'll take a look at the roof geometry tomorrow.
                    I already have questions about the curved lines of the roof and tops of walls. It is unclear whether these arcs are "fixed" geometry of your design, and should not be modified/deleted. (Regarding "Component#91") How were they established, and should they not be edited?
                    -Taff
                      disturbed13
                      you are correct on all accounts
                      'component 91' is the for lack of a better term
                      outline of the roof geometry
                      my roof is 6" thick for now
                      ill deal with structure later (and i 100% expect dimensions to change when i add structure)
                      'component 91' is the temporary outline for the room below
                      there is no point to put any windows outside that since it will be over a wall
                      the odd shape to the top of the image is where i had to add another surface to give an overhang on the back of the house
                      if i didnt there would be a water fall running down windows
                      which causes the roof geometry to be more complicated 😞
                      but just incase i havent said this enough
                      THANK YOU! for looking
                        You have discovered that making a 'part' that you try to 'tile' over s complex roof shape is a nightmare.
                        Here's another approach...
                          disturbed13
                          very nice reply
                          i might have to try that
                          so far ive been useing one single component, the triangle
                          and turning it and copying the snot out of it with a dose of rotate to make it fit the arc of the roof
                          you way is far easier
                            is a nightmare
                            Yes if you want same triangle windows !
                              Another approach 😉
                              http://forums.polyloop.net/picture.php?albumid=23&pictureid=655
                              • TaffGochT
                                TaffGoch
                                disturbed13,
                                The roof sections that are in your model are referred to as "barrel vaults."
                                Barrel vault roof sections
                                The problem, which you've demonstratively-realized, is that equilateral triangles can not be tiled to fit a 135° "bend" in the barrel-vault curved roof.
                                135° barrel-vault intersection
                                Even if the intersection was 120°, which would, at "first blush," fit the equilateral triangle edge, can NOT be tiled with equilateral triangles. The reason is that, on a cylinder, tiled equilateral triangle edges follow a helix, not the planar intersection line between two adjacent cylindrical roof sections. In the image below, you can see the spiral helix path traced by the equilateral triangle edges.
                                120° barrel-vault intersection
                                If you wanted to employ equilateral triangles, making all the windows the same, it can not be done. There's no way to get around the mathematical facts of the intersection of cylindrical barrel-vaulted roofs. (Actually, even if they were NOT cylindrical, you can't get a planar-intersection arc to fit equilateral triangles.)
                                Did you want to proceed with triangles that are not equilateral?
                                Isosceles triangles might/should work, where windows in each ROW share the same specs.
                                -Taff
                                  disturbed13
                                  i had a hunch
                                  i call it a variable pitch roof
                                  from the edge to the center the pitch is as follows
                                  1/3 > 1/4 > 1/5 > 1/9
                                  i would really like to know the math/method that is used to figure out how to do it
                                  as i have several more roofs to draw
                                  and other parts of my design might get the triangle treatment
                                    disturbed13
                                    the whole point was to use as much of the same shape as possible to keep $ down
                                    i welcome any guidance you can offer
                                      If the roof is a simple barrel-vault with equal length segments in its arc, then for a simple form you only need two main component 'panels' that are 'isosceles triangles' - one with it's point up-slope [designed in profile to let water run off its low-point 'sill'] and the other with its point down-slope [designed to let water run off its low-point apex].
                                      These frames are then arranged radially in section, around the cross-section arc's nodes.
                                      Purpose made cover flashings weatherproof the roof at the panels' junctions.
                                      How the frames are supported or are made self-supporting is a major issue not yet addressed.
                                      As well as the two 'standard panels' you'll need to consider how you terminate any verges, and junctions...
                                      At each 'verge' you'll need '1/2' frames of the two main-types used in alternating rows, the opposite 'verge' will need a 'half' frame made from a handed version of the first verge's 1/2 frames, all depending how the pattern works across the eaves.
                                      At junctions between barrels or barrels and abutments etc things become complicated !
                                      Unless you contrive the roof so that where two 'barrels' intersect so that the angles are neatly formed at the diagonals of the panels' junctions you'll doom yourself to have to make many variants of infill part-panels...
                                      At least with a geodesic dome you repeat most panels and only get convoluted where it's cut at the ground, doorways are added etc - and geodesic spheres are even simpler, especially if you only omit sets of whole panels to allow access etc...
                                        disturbed13
                                        well i figured it out
                                        http://i107.photobucket.com/albums/m294/hedoe/roof4ftarchmk1_zpsdaeb0a94.jpg
                                        • olisheaO
                                          olishea
                                          Another approach 😉
                                          how i made this a long time ago!
                                          http://i654.photobucket.com/albums/uu269/olishea/speed2.jpg
                                          oli
                                            disturbed13
                                            and the finished product
                                            http://i107.photobucket.com/albums/m294/hedoe/buildmk3with4ftarchedroof_zps25093787.jpg
                                            i have 57 solar panels up top as well
                                            the passive solar shades are turned at a 30 degree
                                            and when compaired to the vertical
                                            they provide 61% more shade on the house
                                            if anyone wants ill post a thread on how to make the windows in that area
