    [Plugin] CleanUp
    974 Posts 217 Posters 896.0k Views 217 Watching
      File; tt_api.so
      Size; 28672 bytes
      MD5; 029CFD69417000AAEAFA35AD22223D6B
      SHA1; 34CC57D297C130523086FC2047F0812038A4E8AD
      SHA256; 2AC9C5B620B7BA7E10264466DA4C1AF8975AA49C8BED99195077518D0F40D2C4
      SHA384; A3D0A690D523FB90E60E3709600FC3E30997915B8EDAE95F1C455A8EAB6692121A36CB1003E24FD1602844DD325AD547
      SHA512; EB1D8A702390FA124346C11353CA9B4DB7455C42119B91A6DDE927BADE80A8327802859BED5E7C2E6F53B48E2F9CDD0D600B06FC614F4367298CAAFFBD68307C
        Does this inside Clean Up ?
        something similar than "Shift + eraser tool" for quasi coplanar segment on a face ?
          Sorry, but what?
            Pilou, have you been into the egg nog? ๐Ÿ˜† That's nothing like the way you usually write. ๐Ÿ˜‰
              aslansie
              que hago con ese archivo no se donde meterlo y no se ejecuta
                Sorry, but what?
                For Simfonia ๐Ÿ˜‰ (Sorry in French but very visual! ๐Ÿ’š
                See my little animation ๐Ÿ˜„ (you can make the same with the fre version that I use ๐Ÿ˜‰
                Minute 1.16 for lines apparition and the "Shift erase" for hide them minute 3.00
                The normal Clean Up don't works, (the lines come back as soon as the animation restarts) ๐Ÿ˜ฒ
                only the "Shift + erase" works! ๐Ÿ˜ฎ
                  Did you also install TT_Lib? Read the requirements in the first post.
                    Sorry, but what?
                    So, you want to smooth+soften the edges instead of erasing them?
                    In this particular example, since the faces are quads, you can use QuadFace Tools to create soft+smooth triangulation edge.
                      Yes something like that but all in one clic! On my animation I had made one by one! ๐Ÿ˜ž
                      And you say all are quads , in this example yes, but in general case that can be be any thing!
                      I will try your QuadFace Tools
                        cm1963
                        Thom, excellent work. I downloaded and tried to install the plugin the usual manner (downloading directly to Plugins file), but it is still not appearing in the Plugins menue after I restart SU. It also did not work after I dragged and ropped the plugin in the Plugins file after an SU re-start. Please help, I am eager to try this plugin.
                        Charle
                        • massimoM Offline
                          massimo Moderator
                          Any error message in the Ruby console? Do you have also installed the required TT_lib2 as stated in the very first post under "Requirements"?
                            Any error messages?
                            Can you post screenshots of the files in the Plugins folder?
                            • john2J Offline
                              john2
                              Alrighty
                              Returned to working to SketchUp after a long time. Iโ€™ve been using this great plugin for years, I would like to resolve one doubt, the coplanar line doesnโ€™t get deleted using the cleanup command. This happens a lot of time during SketchUp. Iโ€™ve faced this issue. Can anyone tell me when does this conflict happen?
                              My cleanup tool is otherwise RRRRROCKING. ๐Ÿ˜„ ๐Ÿ‘
                              sample for doubt.skp
                              Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                • john2J Offline
                                  john2
                                  @thomthom said:
                                  [attachment=0:cjg9atln]<!-- ia0 -->InternalFace.png<!-- ia0 -->[/attachment:cjg9atln]
                                  oh i see. ๐Ÿ˜ณ This is embarrassing.
                                    It's a common thing. I've used it so much now that whenever I see lines that doesn't disappear when I expect them the first thing I do is check for internal faces.
                                    Determining what's internal faces is tricky so say the least, do I've not got around to work on a solution for that. Instead I just point to TIG's various tools for cleaning up internal faces.
                                      Dougalmaster
                                      I downloaded and ran the Cleanup 3.1.9 plugin and received a message when it finished that there were 1303 errors and I should contact the author.
                                      1303 errors occurred. Please report the error and sample model to the author.
                                      1303 - Face merge resulted in lost geometry!
                                      How do I do this?
                                        Post the model here.
                                        Is your model by any change filled with lots of tiny faces?
                                          Dougalmaster
                                          I'm not able to upload the files. I get the following message:
                                          Shed_Frame v2.3.skp => The file is too big, maximum allowed size is 4 MiB
                                          The file size is 7.8M each. It is a timber frame shed that is assembled using dovetail mortise & tenon joinery. There really aren't many small faces - at least not many compared to most of the complex models I've seen. I had intended to give you a copy of the file before & after running Cleanup.
                                          Is there another way to get you the files?
                                          • arcnhanA Offline
                                            arcnhan
                                            amazing, thanks sir ๐Ÿ˜„) ๐Ÿ‘
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 48
                                            • 49
                                            • 33 / 49
