    Guessing how instancing is gona work
    renderpluginsextensions
    22 Posts 8 Posters 2.1k Views 8 Watching
    • dkendigD Offline
      dkendig
      I don't know anything about V-Ray for Blender, but if they're VRMesh files, then yes, they will be compatible as far as I know.
      Devin Kendig
      Developer
      • broomstickB Offline
        broomstick
        @dkendig said:
        I've managed to get scene parsing time down considerably (in many cases)
        Thanks for addressing problem nΒ°1 for Vray 4 SU!!
        Any possible time frame for the release??
        • panixiaP Online
          panixia
          were i can find some video/demo of the proxy thing (maybe related to vray 4 rhino)?
          and how does it behave with rt engine?
          as far as i understood, the proxy is an heavy poly mesh linked to a low poly object in the sketchup viewport, is that right?
          for example (if i figured well the wole thing) i can place 2d billboard trees in an exterior scene in SU and link to the billboard component a hi poly tree model.. now in the rt preview what will be shown, the billboard version or the hig poly one?
          sorry for my bad english, i hope the question is understandable 😳
            Their YouTube channel is a good start: http://www.youtube.com/user/ChaosGroupTV
            Proxy: http://www.youtube.com/watch?v=L6stb8VupH0
            RT: http://www.youtube.com/watch?v=TEGUDMyB_UI
            • panixiaP Online
              panixia
              thank you thomthom very nice videos, but they didn't fully answer my question, the point is: will instancing work WITHIN the rt engine? or they will be available only for the final render? (as shown in the video above)
              • andybotA Offline
                andybot
                Yes, RT loads the same model info that the regular render loads, including proxies. At least that's the way it works in the other versions of vray, so it should be thus for vfsu 2 😎
                • andybotA Offline
                  andybot
                  Thanks for the video links thomthom. Good idea about looking to the vray for rhino to get a sense of what's coming for vfsu - since they will share the same plugin core.
                    Hoping the development get synced after this VfSU update.
                    I'm very excited about the DR fix, Proxies and the massive speed improvements! πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰ πŸŽ‰
                    • panixiaP Online
                      panixia
                      @andybot said:
                      @panixia said:
                      it should be
                      it would be perfect.
                      so i can add zillions of trees and see them real time.. nice β˜€
                      • andybotA Offline
                        andybot
                        @panixia said:
                        @andybot said:
                        @panixia said:
                        it should be
                        haha! If only it were that simple... RT generally works instantly on the lighting/ camera position/ material definitions. The mesh has to be exported again if you make geometry changes to objects in the scene - so for a heavy scene, you have to wait for the geometry to export again. I'm not sure if it will be done manually or automatically, but either way, it's not exactly going to be instantaneous magic. However, I think a CUDA card will be on my xmas list. πŸ˜„
                        • soloS Offline
                          From my experimenting with Cuda cards used for beta testing the new Thea engine I can suggest a card like the Nvidia GTX 66o TI 3gb, fast, value for money, silent, low power footprint and enough needed ram and Cuda cores for demanding jobs.
                          • panixiaP Online
                            panixia
                            @andybot said:
                            RT generally works instantly on the lighting/ camera position/ material definitions. The mesh has to be exported again if you make geometry changes to objects in the scene ..... However, I think a CUDA card will be on my xmas list. πŸ˜„
                            have a quick look to the whole scene and lighting is still "magic", considering i spend the most time in setting to properly place the camera, adjust sun/lights etc..
                            and i just got a cuda card so.. can't wait! πŸŽ‰
                            but, if one can't see the proxy group in the viewport or move it in rt preview, how the placement/snapping of this object will be fine-tuned?
                            • dkendigD Offline
                              dkendig
                              our flavor of RT doesn't support the GPU yet. Heads up guys.
                              Devin Kendig
                              Developer
                                Does the RT use only local CPUs? Or can you utilize a renderfarm?
                                glares over at the two dusty hexa-cores in the corner
                                • dkendigD Offline
                                  dkendig
                                  RT relies upon the DR Spawner, so it will utilize a farm, yes.
                                  Devin Kendig
                                  Developer
                                  • andybotA Offline
                                    andybot
                                    I don't know how exactly RT works, I'm just saying the update might take longer than just simply pressing the button and going. Proxies are definitely visible in the RT viewer, I just have no idea how responsive or not it will be.
                                    @Devin
                                    Too bad about the lack of GPU rendering for RT. But knowing that DR will work is good news. πŸ‘
                                    @Pete: thanks for the recommendation β˜€
