    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 1.0m Views 175 Watching
      sepo
      @tig said:
      As mentioned in earlier threads, try changing it from a horizontal to a vertical toolbar arrange.
      Close and restart Sketchup and set the toolbar back to horizontal - the extra button should disappear - it seems to be a MAC only occasional glitch πŸ˜•
      The code makes an empty toolbar and adds the various tools onto it one at a time.
      Somehow on a MAC if the bar is horizontal it decides it needs an empty button, before the real buttons are made - however, flipping it vertical, restarting and making it horizontal again removes this oddity... Most MAC users and all PC users never get this happening... πŸ˜’
      OK thanks ... I will try that when I get back home.
        sepo
        It worked...Thanks for your help Tig.
        • pbacotP
          I went back to an old project file and was looking at a part and thinking, "Now how did I do that?"
          Thanks TIG!
          • LanaL
            Lana
            Thanks, thanks Tig.
              dinsa2
              Thank you for this great contribution....
              • P
                pureinhere
                Hello all, first post here. Love the plugin and all the others I found hear. I have a quick question.
                When I use the extrude edges by faces command, say an oval on the end of a curve, and a circle at the beginning of the curve, I often get a flat spot when the two merge together at a certain point in the middle. Is there a way for it to stay perpinddicular to the path at all times? If someone can let me know how to post an image I can do that as well. Thanks for the great plugins and your time as well.
                DC
                  You need to fix the start of both curves; otherwise the 'real start' gets taken and as these might not be near each other, you'll get a 'twist' as the surface is bent around...
                  So if you add a line square to each of the circle/oval perimeter so that it 'splits' it where it meets, then this tool should start each surface aligned at the same place and therefore not 'twist' it...
                  The alternative is to try one of Fredo's CurviLoft tools, which can give similar results...
                  • V
                    victor hugo
                    Hi TIG.
                    Is there any pdf documentation for this really cool πŸ‘ plugins?
                    Thanks.
                      Each individual tool has its own thread - each of which is linked through the zipped set's download page.
                      On each tool's page are detailed explanations, images etc; there are some videos for some of them too...
                        redgray
                        Wow, this is what I'm looking for, thanks for this excellent tool!!!
                        • C
                          christopher shaw
                          Hi, ive downloaded and unzipped but nothing seems to have changed in sketchup, there doesnt appear to be a plugin menu. Can anyone help? Mnay thanks πŸ˜„
                            Is it enabled under preferences?
                            • C
                              christopher shaw
                              Yes i believe plugins are enabled as there is a tab fro plugins between "window" and "help" at the top of the screen. But when i click on the plugin tab the dropdown only offers "cost" and there is no extrude sub heading. Any jelp much appreciated
                                go to Window > Preferences > Extensions and see if Extrude Tools is listed and checked/enabled
                                • C
                                  christopher shaw
                                  I've checked as you suggested but extrude is not in the list to be checked/enabled πŸ˜•
                                  Sorry to be a pain, thanks for your input
                                    That suggests an incorrect installation. Read the Installing plugins sticky...
                                    404 Not Found
                                    (sketchucation.com)
                                    • C
                                      christopher shaw
                                      404 Not Found
                                      (sketchucation.com)
                                      Ive had a look through the instructions and im stuck almost instantly in that i dont have a plugins folder. Ive searched "computer" for all google sketchup 8 associated files and it only comes up with the .exe file. I have this version of pro through my university and im wondering if that has limited the capabilities? Im not very good with computers sorry, and thanks for the help once again
                                      • C
                                        christopher shaw
                                        @christopher shaw said:
                                        404 Not Found
                                        (sketchucation.com)
                                        I have just craked it with your help. I had to go through program files to find google files and inside was the sketchup files and plugins folder. Bemused why none of these would present themselves in a simple search πŸ˜•
                                        Rich many thanks for the help
                                          Which version of Windows are you using? There must be a Plugins folder or you wouldn't find cost in the Plugins menu. You must have some settings made that either don't allow the Plugins folder to be shown or you are looking in the wrong place. Do you have administrative rights on your machines?
                                          Edit: you shouldn't need to run a search for the folder since the path was given.
                                            Search and ye shall find...
                                            Not withstanding that the Plugins folder path for PC and MACs is given in many posts...
                                            Why didn't you search your computer for 'Plugins' ?
                                            That'd be far more obvious... πŸ˜•
                                            When I do that search on my computer I get 36 hits on folders named 'Plugins'!
                                            Of course only one matches 'Sketchup 8'...
                                            AND I have a lot of other apps !
                                            πŸ˜’
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 31
                                            • 32
                                            • 17 / 32
