    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 929.8k Views 175 Watching
      pureinhere
      Hello all, first post here. Love the plugin and all the others I found hear. I have a quick question.
      When I use the extrude edges by faces command, say an oval on the end of a curve, and a circle at the beginning of the curve, I often get a flat spot when the two merge together at a certain point in the middle. Is there a way for it to stay perpinddicular to the path at all times? If someone can let me know how to post an image I can do that as well. Thanks for the great plugins and your time as well.
      DC
        You need to fix the start of both curves; otherwise the 'real start' gets taken and as these might not be near each other, you'll get a 'twist' as the surface is bent around...
        So if you add a line square to each of the circle/oval perimeter so that it 'splits' it where it meets, then this tool should start each surface aligned at the same place and therefore not 'twist' it...
        The alternative is to try one of Fredo's CurviLoft tools, which can give similar results...
        • V Offline
          victor hugo
          Hi TIG.
          Is there any pdf documentation for this really cool πŸ‘ plugins?
          Thanks.
            Each individual tool has its own thread - each of which is linked through the zipped set's download page.
            On each tool's page are detailed explanations, images etc; there are some videos for some of them too...
              redgray
              Wow, this is what I'm looking for, thanks for this excellent tool!!!
                christopher shaw
                Hi, ive downloaded and unzipped but nothing seems to have changed in sketchup, there doesnt appear to be a plugin menu. Can anyone help? Mnay thanks πŸ˜„
                  Is it enabled under preferences?
                    christopher shaw
                    Yes i believe plugins are enabled as there is a tab fro plugins between "window" and "help" at the top of the screen. But when i click on the plugin tab the dropdown only offers "cost" and there is no extrude sub heading. Any jelp much appreciated
                      go to Window > Preferences > Extensions and see if Extrude Tools is listed and checked/enabled
                        christopher shaw
                        I've checked as you suggested but extrude is not in the list to be checked/enabled πŸ˜•
                        Sorry to be a pain, thanks for your input
                          That suggests an incorrect installation. Read the Installing plugins sticky...
                          (sketchucation.com)
                            christopher shaw
                            (sketchucation.com)
                            Ive had a look through the instructions and im stuck almost instantly in that i dont have a plugins folder. Ive searched "computer" for all google sketchup 8 associated files and it only comes up with the .exe file. I have this version of pro through my university and im wondering if that has limited the capabilities? Im not very good with computers sorry, and thanks for the help once again
                              christopher shaw
                              @christopher shaw said:
                              (sketchucation.com)
                              I have just craked it with your help. I had to go through program files to find google files and inside was the sketchup files and plugins folder. Bemused why none of these would present themselves in a simple search πŸ˜•
                              Rich many thanks for the help
                                Which version of Windows are you using? There must be a Plugins folder or you wouldn't find cost in the Plugins menu. You must have some settings made that either don't allow the Plugins folder to be shown or you are looking in the wrong place. Do you have administrative rights on your machines?
                                Edit: you shouldn't need to run a search for the folder since the path was given.
                                  Search and ye shall find...
                                  Not withstanding that the Plugins folder path for PC and MACs is given in many posts...
                                  Why didn't you search your computer for 'Plugins' ?
                                  That'd be far more obvious... πŸ˜•
                                  When I do that search on my computer I get 36 hits on folders named 'Plugins'!
                                  Of course only one matches 'Sketchup 8'...
                                  AND I have a lot of other apps !
                                  πŸ˜’
                                    christopher shaw
                                    πŸ˜’
                                    Hi guys, thats precisely what im getting at. Im using vista and when i click on start at the bottom left and type plugins into the search bar, it doesn't find the plugins folder. In fact it doesn't return any results for plugins (should return results for plugins for ArchiCAD, autoCAD, firefox etc, all installed). Which is bizarre as when i search for other items (folders, pictures, files) from time to time i have no problem locating them with a search of the computer. Apologies, im quite amateurish when it comes to this kind of thing, but thanks for the help
                                      Perhaps you have some security setting that prevents the folder from showing? I just ran a search on my XP machine's C:\ and it turned up the Plugins folder for SketchUp and a number of other applications in seconds.
                                      Try searching for Materials or Styles. Do those turn up?
                                        A 'Start' bar's 'Search' will probably start looking in the "User"'s own folder-tree, so it finds things in your Documents, Pictures etc... but it won't find anything useful with 'plugins'; BUT if you open 'My Computer', change to the 'C:' drive and then 'Search' in the top-bar of that window for 'plugins' you'll get hits, because then it's looking through all files/folders on that drive - not limiting itself to your "User" folders...
                                          christopher shaw
                                          I have gone to the OS(C): drive and searched that and i have found all the plugin folders now. Thank you all for the help, its much appreciated.
                                          On another note, the reason i wanted the extrude plugin was to draw up some galvanised steel tube gates for a patent application. I had drawn the gate with the line tool and was having trouble getting the follow me tool to cross other tube sections. I noticed a youtube video with the extrude tool in operation and it looked as though it would solve all my problems. But ive struggled with it. Lets say ive drawn a waffle with just lines and i want to turn the lines into 40mm diameter tube (solid tube is fine for this purpose) is it possible to select the entire waffle and use the extrude tool to turn all the lines into tube, perfecting all the junctions?
                                            There's nothing that I know of that does what you want 😞
                                            Didier Bur has a "lines to tubes" tool [ http://sketchucation.com/forums/viewtopic.php?p=88592#p88592 ] that'll make all of the selected edges into tubes.
                                            You can then Intersect them to make edges around their intersections... BUT the trimming of them to each other needs manual labor.
                                            As the innards are unlikely to be seen then that might not be as issue [remember that 'Sufficient is fit.'].
                                            Also if there are several repeated elements then these can be copied across, rather than made individually...
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 31
                                            • 32
                                            • 17 / 32
