    [Plugin] Material_Maintenance v2.2 - 2013-01-13
    155 Posts 19 Posters 63.9k Views 19 Watching
      Myhand
      Thank you everyone for your help and good advice. Here is a version with noth of the protocol chars in the normal ascii range. I have chosen 30, and 31 the record and unit separator characters. They are not printable so there is a small chance there might again be problems on the MAC I guess, but this works fine on Windows.
      John, CMD do you mind trying again please? Debug is still on, so if this works I will publish a version without the tracing code.
      Debug version
      http://www.keepingmyhandin.com/
        driven
        the good news is
        # SU returns  =>
         RUBY_VERSION = 1.8.5
        (eval);3119; warning; parenthesize argument(s) for future version
        (eval);3142; warning; parenthesize argument(s) for future version
        key = Units
        value = 0.0
        key = StampOffset
        value = 12.0
        key = GridSpacingX
        value = 120.0
        key = SmooveRadius
        value = 360.0
        key = GridSpacingY
        value = 120.0
        !!!=> fromUIHandler; parameter string = 73-0__vzrefreshMaterialstruefalsefalse
        p1 = >>73-0<<
        p1 = >>__vz<<
        p1 = >>refreshMaterials<<
        p1 = >>true<<
        p1 = >>false<<
        p1 = >>false<<
        calling function >>refreshMaterials<<
        String Time = 5.9e-05
        Total Entities = 1
        # SU returns  =>
         RUBY_VERSION = 1.8.7
        key = Units
        value = 0.0
        p1 = >>73-0<<
        p1 = >>__vz<<
        p1 = >>true<<
        p1 = >>false<<
        p1 = >>false<<
        String Time = 6.4e-05
        seems to work with either RUBY_VERSION, but the verbosity level is higher in 1.8.5
        • cmdC Offline
          cmd
          @myhand said:
          John, CMD, do you mind testing the attached version please?
          The previous debug version did not change the JS code as I thought it did. This one does. It is the last try with the current control chars, and if this does not work I will create a patch with a multiple chars in the standard ascii range.
          Again this requires a uninstall of the old plugin, restart of Sketchup and a install of the new debug version.
          Again please send me the output.
          Myhand,
          Attached is the output immediately after launching the Material Maintenance plugin.
          CMD
          MM_Ruby output.txt
          • CMD
            The text file when opened in 'Notepad++.exe' as 'UTF-8 without BOM' shows this: Capture.PNG BUT when the same text is pasted into here it displays differently...
            !!!=> fromUIHandler: parameter string = 73-0__vzrefreshMaterialstruefalsefalse Error: #<NoMethodError: private methodputs' called for "73-0":String>`
            Presumably the 'RS' record-separator character [ASCII-030] is non-printing...
            Not sure how 'puts' seems broken πŸ˜•
            Are you parsing the string using split and the 'RS' as at splitter ?
            You should then be able to 'puts' the array elements ??
              Myhand
              @tig said:
              The text file when opened in 'Notepad++.exe' as 'UTF-8 without BOM' shows this: [attachment=0:2y0lvhlv]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:2y0lvhlv] BUT when the same text is pasted into here it displays differently...
              Yes I am splitting the string with the 'RS' char. Very strange error message indeed. The code snippet where it fails is:
              ` puts "!!!=> fromUIHandler: parameter string = #{parameterString}";
                params = unmarshalParams(parameterString);
                params.each { |p|
                  p.puts "p1 = >>#{p}<<";   // This is line 109
              Again this works fine on Windows, and appears to now also work for driven on his MAC so at a bit of a loss here.
              One other strange thing with this is that the output should look like this:
              !!!=> fromUIHandler; parameter string = 75-0__materialsRefreshedrefreshMaterialstruefalsefalse
              p1 = >>75-0<<
              p1 = >>__materialsRefreshed<<
              p1 = >>true<<
              p1 = >>false<<
              p1 = >>false<<
              i.e. the second parameter should be "__materialsRefreshed" not "__vz" which it appears to be for both the MAC implementations. Strictly speaking this should not work even for driven.
              CMD, are you sure you have done a clean uninstall and install?
                But params.each{|p|puts "p1 = >>#{p}<<"}
                should be the way ?
                NOT p.puts
                  Myhand
                  should be the way ?
                  NOT p.puts
                  😳 thanks TIG!
                  Still strange it worked on windows and driven's MAC and that the second parameter comes looks wrong but as long as it works.
                  I am making a new build without the trace code which I will upload soon.
                    Myhand
                    Bug fix version V2.1.1 released.
                    Can be found here:
                    http://www.keepingmyhandin.com/Downhome/Sketchup/material_maintenance_2
                    CMD this should fix your problem also as the trace code that had the bug in is also now removed.
                      Tpdart
                      It may be me, but I've put the .rbz in the plugins folder, restarted SU but I cannot find the command or interface. Any thoughts?
                        You do not use an RBZ file like that. Please, read this tutorial on installing plugins:
                        http://sketchucation.com/resources/tutorials/37-beginner/108-installing-sketchup-plugins
                          Tpdart
                          DOH!
                          I didn't install the extension- once I PROPERLY followed the instructions it looks great I can't wait to try it out on an inherited complex model with many similar materials.
                          • cmdC Offline
                            cmd
                            ... CMD this should fix your problem also as the trace code that had the bug in is also now removed.
                            Myhand,
                            Good stuff! no more errors!
                            .... but I am not getting material thumbnails nor am I getting component images to display.
                            Is this due to the change for mac?
                            • CMD
                              @cmd
                              If you write this in the Ruby Console ENV['TMPDIR'] + <enter> it gives the path to your 'temp' folder.
                              In that folder ought to be a subfolder named 'material_maintenance' and in that the xxx.png material thumbnails and xxx.comp.png component thumbnails ? They might have weird looking 'id' type names...
                              The subfolder is emptied when the tool runs, or it's made if it is missing.
                              It could be that the files are getting made but some enduring issue in the html/js on MAC is preventing them displaying ??
                              Can you confirm if the subfolder/files exist...
                                Myhand
                                @cmd said:
                                Myhand,
                                I suspect it can be to do with the temp folder location on your MAC. I save the thumbs in a folder I create within the system temp folder. I use a technique (from ThomThom's very good article on materials http://www.thomthom.net/thoughts/2012/03/the-secrets-of-sketchups-materials/)
                                to "guess" the temp folder.
                                temp_path = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] )
                                It might be that this does not work on your system and we might have to add some options to the list.
                                driven, did you see the thumbs on your system?
                                  The ENV['TMPDIR'] should work on MAC, with the other two for PCs.
                                  CMD needs to go look see if the subfolder/thumbnails are getting made...
                                  If they aren't there's an issue with this bit; if they are the issue is with the html/js end ?
                                    I have experienced some OSX user that didn't have the environment set up correctly - there was no environment temp variable defined at all. That was a once-time thing though.
                                      OK ... then
                                      ENV.sort.each{|e|p e};p
                                      will list everything available...
                                      πŸ˜’
                                      • OxerO Offline
                                        Oxer
                                        I have the same problem like cmd, the material thumbnails don't appear, I work on Mac OSX.
                                        Other question, is it possible translate the plugin to another language?
                                        Thanks Myhand !!
                                          Myhand
                                          Can you please follow TIG's instructions below and let us know the results?
                                          @tig said:
                                          @cmd
                                          Can you also please run
                                          and attach the console output.
                                          • cmdC Offline
                                            cmd
                                            @myhand said:
                                            Myhand & TIG
                                            Yes... the folders and image files do exist.
                                            CMD
                                            • CMD
                                            • 4 / 8
