    [Plugin] Material_Maintenance v2.2 - 2013-01-13
    155 Posts 19 Posters 79.9k Views 19 Watching
      Myhand
      @thomthom said:
      When I send parameters back from WebDialogs I've used combo characters like || or ||| which I know is very unlikely to appear in the data I send. (In the context of what I've done I've been sure they'd not appear.)
      In a system where there is user input you'd want to create your own escape sequence where you pick a character as array separator and ensure to escape any occurrence in the data - which then is un-escaped when you receive it on the other end.
      Escaping is the best way, and also what I am using in my Simple Jason serializer. I'll probably just implement the de-serialiser and then this whole problem will go away.
      Your short cut of using ||| etc. is also a good option and I will probably use that in the short term if my latest attempt to fix the problem does not work.
      http://www.keepingmyhandin.com/
        Myhand
        John, CMD, do you mind testing the attached version please?
        The previous debug version did not change the JS code as I thought it did. This one does. It is the last try with the current control chars, and if this does not work I will create a patch with a multiple chars in the standard ascii range.
        Again this requires a uninstall of the old plugin, restart of Sketchup and a install of the new debug version.
        Again please send me the output.
        Debug version
          driven
          same problem p1 = >>73-0Â<<
            You replaced teh character with String.fromCharCode(183) ?
            And from what Driven says, that didn´t work either.
            Why don´t you just split the param string with the proper UTF-8 sequence? You are after all dealing with UTF-8 within SketchUp - and also from the WebDialog. So to ensure you avoid encoding problems, which you have right now, just consistently treat everything as UTF-8. If you go back to where you had ¶ in your JS all you need to do is split the param string by the byte by the UTF-8 sequency 194, 182.
            Trying to force it through a different encoding, in this case ANSI, is just asking for problems.
              Btw, did you see my comment at the end of the prevous page regarding ASCII vs ANSI vs UTF-8? (Not sure if you missed it, as my last comment will make less sense if you missed it.)
              http://sketchucation.com/forums/viewtopic.php?f=323&t=48933&start=45#p442858
                Myhand
                Thank you everyone for your help and good advice. Here is a version with noth of the protocol chars in the normal ascii range. I have chosen 30, and 31 the record and unit separator characters. They are not printable so there is a small chance there might again be problems on the MAC I guess, but this works fine on Windows.
                John, CMD do you mind trying again please? Debug is still on, so if this works I will publish a version without the tracing code.
                Debug version
                  driven
                  the good news is
                  # SU returns  =>
                   RUBY_VERSION = 1.8.5
                  (eval);3119; warning; parenthesize argument(s) for future version
                  (eval);3142; warning; parenthesize argument(s) for future version
                  key = Units
                  value = 0.0
                  key = StampOffset
                  value = 12.0
                  key = GridSpacingX
                  value = 120.0
                  key = SmooveRadius
                  value = 360.0
                  key = GridSpacingY
                  value = 120.0
                  !!!=> fromUIHandler; parameter string = 73-0__vzrefreshMaterialstruefalsefalse
                  p1 = >>73-0<<
                  p1 = >>__vz<<
                  p1 = >>refreshMaterials<<
                  p1 = >>true<<
                  p1 = >>false<<
                  p1 = >>false<<
                  calling function >>refreshMaterials<<
                  String Time = 5.9e-05
                  Total Entities = 1
                  # SU returns  =>
                   RUBY_VERSION = 1.8.7
                  key = Units
                  value = 0.0
                  p1 = >>73-0<<
                  p1 = >>__vz<<
                  p1 = >>true<<
                  p1 = >>false<<
                  p1 = >>false<<
                  String Time = 6.4e-05
                  seems to work with either RUBY_VERSION, but the verbosity level is higher in 1.8.5
                  • cmdC
                    cmd
                    Myhand,
                    Attached is the output immediately after launching the Material Maintenance plugin.
                    CMD
                    MM_Ruby output.txt
                    • CMD
                      The text file when opened in 'Notepad++.exe' as 'UTF-8 without BOM' shows this: Capture.PNG BUT when the same text is pasted into here it displays differently...
                      !!!=> fromUIHandler: parameter string = 73-0__vzrefreshMaterialstruefalsefalse Error: #<NoMethodError: private methodputs' called for "73-0":String>`
                      Presumably the 'RS' record-separator character [ASCII-030] is non-printing...
                      Not sure how 'puts' seems broken 😕
                      Are you parsing the string using split and the 'RS' as at splitter ?
                      You should then be able to 'puts' the array elements ??
                        Myhand
                        @tig said:
                        The text file when opened in 'Notepad++.exe' as 'UTF-8 without BOM' shows this: [attachment=0:2y0lvhlv]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:2y0lvhlv] BUT when the same text is pasted into here it displays differently...
                        Yes I am splitting the string with the 'RS' char. Very strange error message indeed. The code snippet where it fails is:
                        ` puts "!!!=> fromUIHandler: parameter string = #{parameterString}";
                          params = unmarshalParams(parameterString);
                          params.each { |p|
                            p.puts "p1 = >>#{p}<<";   // This is line 109
                        Again this works fine on Windows, and appears to now also work for driven on his MAC so at a bit of a loss here.
                        One other strange thing with this is that the output should look like this:
                        !!!=> fromUIHandler; parameter string = 75-0__materialsRefreshedrefreshMaterialstruefalsefalse
                        p1 = >>75-0<<
                        p1 = >>__materialsRefreshed<<
                        p1 = >>true<<
                        p1 = >>false<<
                        p1 = >>false<<
                        i.e. the second parameter should be "__materialsRefreshed" not "__vz" which it appears to be for both the MAC implementations. Strictly speaking this should not work even for driven.
                        CMD, are you sure you have done a clean uninstall and install?
                          But params.each{|p|puts "p1 = >>#{p}<<"}
                          should be the way ?
                          NOT p.puts
                            Myhand
                            should be the way ?
                            NOT p.puts
                            😳 thanks TIG!
                            Still strange it worked on windows and driven's MAC and that the second parameter comes looks wrong but as long as it works.
                            I am making a new build without the trace code which I will upload soon.
                              Myhand
                              Bug fix version V2.1.1 released.
                              Can be found here:
                              http://www.keepingmyhandin.com/Downhome/Sketchup/material_maintenance_2
                              CMD this should fix your problem also as the trace code that had the bug in is also now removed.
                              • T
                                Tpdart
                                It may be me, but I've put the .rbz in the plugins folder, restarted SU but I cannot find the command or interface. Any thoughts?
                                • GaieusG
                                  You do not use an RBZ file like that. Please, read this tutorial on installing plugins:
                                  http://sketchucation.com/resources/tutorials/37-beginner/108-installing-sketchup-plugins
                                  • T
                                    Tpdart
                                    DOH!
                                    I didn't install the extension- once I PROPERLY followed the instructions it looks great I can't wait to try it out on an inherited complex model with many similar materials.
                                    • cmdC
                                      cmd
                                      ... CMD this should fix your problem also as the trace code that had the bug in is also now removed.
                                      Myhand,
                                      Good stuff! no more errors!
                                      .... but I am not getting material thumbnails nor am I getting component images to display.
                                      Is this due to the change for mac?
                                      • CMD
                                        @cmd
                                        If you write this in the Ruby Console ENV['TMPDIR'] + <enter> it gives the path to your 'temp' folder.
                                        In that folder ought to be a subfolder named 'material_maintenance' and in that the xxx.png material thumbnails and xxx.comp.png component thumbnails ? They might have weird looking 'id' type names...
                                        The subfolder is emptied when the tool runs, or it's made if it is missing.
                                        It could be that the files are getting made but some enduring issue in the html/js on MAC is preventing them displaying ??
                                        Can you confirm if the subfolder/files exist...
                                          Myhand
                                          @cmd said:
                                          Myhand,
                                          I suspect it can be to do with the temp folder location on your MAC. I save the thumbs in a folder I create within the system temp folder. I use a technique (from ThomThom's very good article on materials http://www.thomthom.net/thoughts/2012/03/the-secrets-of-sketchups-materials/)
                                          to "guess" the temp folder.
                                          temp_path = File.expand_path( ENV['TMPDIR'] || ENV['TMP'] || ENV['TEMP'] )
                                          It might be that this does not work on your system and we might have to add some options to the list.
                                          driven, did you see the thumbs on your system?
                                            The ENV['TMPDIR'] should work on MAC, with the other two for PCs.
                                            CMD needs to go look see if the subfolder/thumbnails are getting made...
                                            If they aren't there's an issue with this bit; if they are the issue is with the html/js end ?
                                            • 4 / 8
