    [Plugin] Material_Maintenance v2.2 - 2013-01-13
    155 Posts 19 Posters 79.9k Views 19 Watching
      Myhand
      @thomthom said:
      SketchUp return strings in UTF-8. Anything above the ASCII character range will be multi-byte characters - which is easily mangled by Ruby 1.8's string manipulation methods as it treats 'characters' as single bytes.
      But my characters are well within the ASCII range...? i.e. they still fit within a byte. from which value does it convert them to multi byte?
      http://www.keepingmyhandin.com/
        Myhand
        Ok so here is a debug version with the the token chars explicitly specified in both JS and Ruby. Unfortunately you will have to un-install the whole plugin and install the debug version.
        It still has tracing code in, so will still be a bit slow.
        John, CMD can you test again please?
        Debug version
          driven
          !!!=> fromUIHandler: parameter string = 73-0¶__vz¶refreshMaterials¶true¶false¶false p1 = >>73-0Â<< p1 = >>__vzÂ<< p1 = >>refreshMaterialsÂ<< p1 = >>trueÂ<< p1 = >>falseÂ<< p1 = >>false<< calling function >>refreshMaterialsÂ<< Error: #<NoMethodError: undefined methodrefreshMaterials' for #<MH_KeepingMyHandIn::MaterialMaintenance:0x11b2f898>>
          /Users/johns_iMac/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/Material_Maintenance/Material_Maintenance.rb:121:in send' /Users/johns_iMac/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/Material_Maintenance/Material_Maintenance.rb:121:in fromUIHandler'`
            Myhand
            Hi John, thanks for testing is this output from the latest Material_Maintenance_debug.rbz file?
            If so did you fully delete the previous version, install and restart Sketchup?
              driven
              Yes, I did it manually to start and when the results appeared to go backwards I deleted those and used SU to install the .rbz
              exactly the same results
              BTW. if you can put a 20px margin around your html, I can attach web Inspector to look at the js, I need a crack to get in...
                driven
                !!!=> fromUIHandler: parameter string = 73-0|__vz|refreshMaterials|true|false|false p1 = >>73-0<< p1 = >>__vz<< p1 = >>refreshMaterials<< p1 = >>true<< p1 = >>false<< p1 = >>false<< calling function >>refreshMaterials<< String Time = 6.0e-05 Total Entities = 1
                I changed the js and the ruby ¶ into |
                  driven
                  next error... !!!=> fromUIHandler: parameter string = 73-0|__vE|findComponents|·147713020 p1 = >>73-0<< p1 = >>__vE<< p1 = >>findComponents<< p1 = >>·147713020<< calling function >>findComponents<< Error: #<ArgumentError: invalid value for Integer: "·147713020">
                    Myhand
                    Good work! This one is because the "·" char (183) char is used as an array token, and is also passed as a double byte char. So you would need to change that also.
                    BTW, I have just seen that the debug.rbz I attached earlier was not built properly. So it might well be that the fix I put in earlier will work, but I cannot get the build to work yet.
                    Appologies for wasting your time with testing that version! 😳
                      You seem to be using the ANSI range - you use bytes 182 and 183 which is not ASCII.
                      ASCII is just 0-127 - while ANSI is a sub-set that extends that with 128-255.
                      UTF-8 matches the ASCII character encoding - but does not match ANSI. In UTF-8 bytes 128-255 are control characters. So when you feed a UTF-8 system (like SketchUp) ANSI strings you get messed up characters.
                      ¶ encoded in UTF-8 is [194, 182] - which is why when you split by just 182 you get the extra 194 byte ( Â).
                        When I send parameters back from WebDialogs I've used combo characters like || or ||| which I know is very unlikely to appear in the data I send. (In the context of what I've done I've been sure they'd not appear.)
                        In a system where there is user input you'd want to create your own escape sequence where you pick a character as array separator and ensure to escape any occurrence in the data - which then is un-escaped when you receive it on the other end.
                          Another way is to restrict what a user can enter - e.g.
                          <input type="text" id="project_name" value="" style="font-size:7pt; width:300px;" onKeyup="(this.value=this.value.replace(/[^-_0-9A-Za-z]/,''));" ... >
                          This example limits the user's INPUT for the 'project_name' to letters, numbers, _, - etc... Then you can be sure that any 'separator' like '|' won't get replicated in the entered text... Obviously you need to change the regexp to suit your needs...
                            Myhand
                            yes I agree you always want to constrain at the input. In this case though the input in question is the Sketchup material editor, so I unfortunately have no control over that input.
                              Myhand
                              Escaping is the best way, and also what I am using in my Simple Jason serializer. I'll probably just implement the de-serialiser and then this whole problem will go away.
                              Your short cut of using ||| etc. is also a good option and I will probably use that in the short term if my latest attempt to fix the problem does not work.
                                Myhand
                                John, CMD, do you mind testing the attached version please?
                                The previous debug version did not change the JS code as I thought it did. This one does. It is the last try with the current control chars, and if this does not work I will create a patch with a multiple chars in the standard ascii range.
                                Again this requires a uninstall of the old plugin, restart of Sketchup and a install of the new debug version.
                                Again please send me the output.
                                Debug version
                                  driven
                                  same problem p1 = >>73-0Â<<
                                    You replaced teh character with String.fromCharCode(183) ?
                                    And from what Driven says, that didn´t work either.
                                    Why don´t you just split the param string with the proper UTF-8 sequence? You are after all dealing with UTF-8 within SketchUp - and also from the WebDialog. So to ensure you avoid encoding problems, which you have right now, just consistently treat everything as UTF-8. If you go back to where you had ¶ in your JS all you need to do is split the param string by the byte by the UTF-8 sequency 194, 182.
                                    Trying to force it through a different encoding, in this case ANSI, is just asking for problems.
                                      Btw, did you see my comment at the end of the prevous page regarding ASCII vs ANSI vs UTF-8? (Not sure if you missed it, as my last comment will make less sense if you missed it.)
                                      http://sketchucation.com/forums/viewtopic.php?f=323&t=48933&start=45#p442858
                                        Myhand
                                        Thank you everyone for your help and good advice. Here is a version with noth of the protocol chars in the normal ascii range. I have chosen 30, and 31 the record and unit separator characters. They are not printable so there is a small chance there might again be problems on the MAC I guess, but this works fine on Windows.
                                        John, CMD do you mind trying again please? Debug is still on, so if this works I will publish a version without the tracing code.
                                        Debug version
                                          driven
                                          the good news is
                                          # SU returns  =>
                                           RUBY_VERSION = 1.8.5
                                          (eval);3119; warning; parenthesize argument(s) for future version
                                          (eval);3142; warning; parenthesize argument(s) for future version
                                          key = Units
                                          value = 0.0
                                          key = StampOffset
                                          value = 12.0
                                          key = GridSpacingX
                                          value = 120.0
                                          key = SmooveRadius
                                          value = 360.0
                                          key = GridSpacingY
                                          value = 120.0
                                          !!!=> fromUIHandler; parameter string = 73-0__vzrefreshMaterialstruefalsefalse
                                          p1 = >>73-0<<
                                          p1 = >>__vz<<
                                          p1 = >>true<<
                                          p1 = >>false<<
                                          p1 = >>false<<
                                          String Time = 5.9e-05
                                          Total Entities = 1
                                          # SU returns  =>
                                           RUBY_VERSION = 1.8.7
                                          key = Units
                                          value = 0.0
                                          p1 = >>73-0<<
                                          p1 = >>__vz<<
                                          p1 = >>true<<
                                          p1 = >>false<<
                                          p1 = >>false<<
                                          String Time = 6.4e-05
                                          seems to work with either RUBY_VERSION, but the verbosity level is higher in 1.8.5
                                          • cmdC
                                            cmd
                                            Myhand,
                                            Attached is the output immediately after launching the Material Maintenance plugin.
                                            CMD
                                            MM_Ruby output.txt
                                            • CMD
                                            • 4 / 8
