    đź«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    HELP BIG MODEL
    renderpluginsextensions
    21 Posts 4 Posters 1.3k Views 4 Watching
      carconcal
      Hi .... i have a big big problem i dont know what to do...i present my final work at monday...i have finished alll my model its 160 m....its a tower of 17 stories i add a double facade ...know i click render and its says vray is rendering..but then nothing happens.... i wait like 8 hrs and nothing happens...i already use the pluggin clean up by thom thom which is an exellent plugin. Can anyone give me tips please?
      I am using a mac book pro with core I7 with 8 at ram.... my SU 8 and vray 1.4901
        carconcal
        this is the model i am trying to render
        my model
        the double facade
        • cottyC Offline
          cotty
          Did you use components for the repetitive parts?
          my SketchUp gallery
            carconcal
            thankyou cotty for your time…
            No i didn't use components…i use groups for the double facade
              carconcal
              Soorry i needd help pleasee..do you know if distributed rendering its a solution?? i can get 2 more macbook pros with v ray thanks
              • soloS Offline
                Can you share the model? I'll give it a try.
                  carconcal
                  it dosent allow me to upload the model… i send it by mail?? we transfer?
                  • cottyC Offline
                    cotty
                    With Thomthoms selection toys it is possible to convert different copies of groups into component instances (right clikc on one group)... eventually it reduces the filesize to something managable...
                    I would suggest dropbox or similar to share your model with Solo.
                    my SketchUp gallery
                    • V Offline
                      valerostudio
                      Components will not matter. I think VRay is running out of memory.
                      I would not use any displacement - its not worth it with a file this big and in a crunch.
                      Try increasing your dynamic memory limit under options / system. Increase will depend on how much RAM you have. Try 2500 if you have more than 6GB. Also turn off any dialog boxes in SU and set your display to wireframe before clicking render. Also, I would save your file, close it, open it fresh and do these steps before rendering, so it starts clean.
                      If this doesnt work, render to file using the EXR option. If you are rendering out channel passes, you will need ProEXR and 64 bit Photoshop in order to open the file and see the channels. I like to your Preview mode so you can see progress.
                      I do not miss finals. Good Luck.
                      • V Offline
                        valerostudio
                        • V Offline
                          valerostudio
                          Also, for future renference, if you renders will be from a distance, you would be better off not modeling the grate and use a transparent PNG to cheat it.
                          • cottyC Offline
                            cotty
                            Doesn't Vray use instancing for repeated components and reduce memory usage with this?
                            my SketchUp gallery
                            • V Offline
                              valerostudio
                              As far as I know, Vray does not use instancing at all. It might save on memory that the model is using, but I am not sure. I honestly think, the best way is going to be to render using the EXR method I explained. It will take all the load of the memory. The issue could be other things though, like a buggy material map or displacement.
                                carconcal
                                i made a exr file …it didn't work…does the distributed render help me? by the way thank you very much
                                • V Offline
                                  valerostudio
                                  Do you have displacement set in materials in your model?
                                    carconcal
                                    No..i only have bumps and crystals…
                                    • V Offline
                                      valerostudio
                                      Crystals? As in Caustics???
                                      • soloS Offline
                                        There was one material with displacement, I unchecked it, doing a cleanup at moment which is taking a long time unfortunately, I will try rendering normally with Vray first if that fails I'll try .exr.
                                        • V Offline
                                          valerostudio
                                          I bet the displacement was the killer.
                                          • soloS Offline
                                            Afraid not, tried cleaning, .exr,etc with no success.
                                            I'd suggest porting out to Max and Vray4Max if possible or using a studio based renderer.
