    HELP BIG MODEL
    renderpluginsextensions
    21 Posts 4 Posters 2.2k Views 4 Watching
    • V Offline
      valerostudio
      Components will not matter. I think VRay is running out of memory.
      I would not use any displacement - its not worth it with a file this big and in a crunch.
      Try increasing your dynamic memory limit under options / system. Increase will depend on how much RAM you have. Try 2500 if you have more than 6GB. Also turn off any dialog boxes in SU and set your display to wireframe before clicking render. Also, I would save your file, close it, open it fresh and do these steps before rendering, so it starts clean.
      If this doesnt work, render to file using the EXR option. If you are rendering out channel passes, you will need ProEXR and 64 bit Photoshop in order to open the file and see the channels. I like to your Preview mode so you can see progress.
      I do not miss finals. Good Luck.
      • V Offline
        valerostudio
        • V Offline
          valerostudio
          Also, for future renference, if you renders will be from a distance, you would be better off not modeling the grate and use a transparent PNG to cheat it.
          • cottyC Offline
            cotty
            Doesn't Vray use instancing for repeated components and reduce memory usage with this?
            my SketchUp gallery
            • V Offline
              valerostudio
              As far as I know, Vray does not use instancing at all. It might save on memory that the model is using, but I am not sure. I honestly think, the best way is going to be to render using the EXR method I explained. It will take all the load of the memory. The issue could be other things though, like a buggy material map or displacement.
                carconcal
                i made a exr file …it didn't work…does the distributed render help me? by the way thank you very much
                • V Offline
                  valerostudio
                  Do you have displacement set in materials in your model?
                    carconcal
                    No..i only have bumps and crystals…
                    • V Offline
                      valerostudio
                      Crystals? As in Caustics???
                      • soloS Offline
                        There was one material with displacement, I unchecked it, doing a cleanup at moment which is taking a long time unfortunately, I will try rendering normally with Vray first if that fails I'll try .exr.
                        • V Offline
                          valerostudio
                          I bet the displacement was the killer.
                          • soloS Offline
                            Afraid not, tried cleaning, .exr,etc with no success.
                            I'd suggest porting out to Max and Vray4Max if possible or using a studio based renderer.
                              carconcal
                              I already solution it … i made scenes and make a different archive for it… i erase what docent see on the scene… i had 180 mb and i reduce to 70 at each scene… know i have a problem rendering with distributed render….jaja thank you very much…aaa also cleanup help me a lot! thanks for your time
