    Disappearing toolbar under OSX?
    36 Posts 6 Posters 2.6k Views 6 Watching
      @wind-borne said:
      Are we talking about the single button to activate tool?
      Yes. I'll point the user to these screenshots and see what he makes out of it.
        gt5
        @gaieus said:
        I don't have experience with Mac toolbars either but is there any chance it's floating somewhere either behind the SU window or off-screen?
        Hi, I'm the one with the problem. I've eliminated the possibility of it floating behind the SU window. I'll have to think about the off-screen possibility.
        Nope, the single button is there. It's the long toolbar that appears after one clicks the button that as wondered off.
        No, it's the toolbar not the activate button.
        • wind-borneW Offline
          wind-borne
          That toolbar does occasionally disappear for me also, usually when editing a group.
          If I close and reopen group the toolbar reappears in the same space as before when Vertex Tools is reactivated, never had toolbar move.
          I've gotten used to doing that without giving much thought.
          "To read between the lines was easier than to follow the text."OSX 10.11.6
          %(#BF80BF)[SU 8 pro
            gt5
            I've even tried a new window, 2 quads, no toolbar.
              gt5
              @driven said:
              you could check the 'defaults' position or just set a new one
              for position-
              defaults write ~/Library/Preferences/com.google.sketchuppro8.plist ALToolPalette_Vertex Tools_frame '150 797 36 304 0 0 1920 1178'``
              or what ever your toolbar is actually called.
              for visibility it's the Sketchup version to give
              <key>SketchUp.Toolbars.Vertex Tools.Visible</key>
              <string>1</string>
              should show up on restart...
              good idea, didn't work
                Really? And only with Vertex Tools? 😲 πŸ˜•
                  Try this - from Windows > Ruby Console: (Type each command and see what the results are)
                  t=UI.toolbar('Vertex Tools')
                  t.visible?
                  t.get_last_state
                  t.show
                    gt5
                    @thomthom said:
                    Try this...
                    #UI::Toolbar:0x165b4e04
                    t.visible?
                    true
                    t.get_last_state
                    t.show
                    nil
                      wind-borne
                      Now we have established gt5's problem is not the button but the toolbar inside of Vertex Tools that is missing.
                      The main toolbar and information panel within Vertex Tools have at times disappeared when editing inside of a group. Vertices will be highlighted blue as if waiting to be selected, no toolbar and nothing can be selected in Vertex Tools until I exit group and reenter group edit mode and open Vertex tools again. Then all functions normal. Select freehand initial tool. Of course I couldn't recreate today πŸ˜†
                      I use a different color for selections in SU, that blue only shows up inside of Vertex Tools.
                      I rely on 'edit vertices' shortcut to activate tool so I never have that initial toolbar button visible if that is what you are asking about.
                      %(#BF80BF)[SU 8 pro
                        Ah! I completely missed this! 😳 Sorry - now I'm with you!
                        Ok - lets debug that toolbar:
                        Can you please type:
                        TT_Vertex.settings
                          When this happens, can you please open the Ruby Console and see if you're getting any error messages?
                            gt5
                            TT_Vertex.settings
                            TT_Vertex.settings
                            #<TT_Vertex::Settings:0x169d16f4 @section="TT_Vertex", @cache={:remember_uv=>true, :view_normals=>true, :context_menu=>true, :radius=>0.0, :vertexinfo_x=>615, :axis_lock=>false, :normal_size=>20, :vertexinfo_y=>234, :gizmo_visible=>true, :l10n=>"en", :vertex_size=>6, :merge_tolerance=>0.393700787401575, :last_select_tool=>:rect, :last_tool=>"T_Select_Rectangle", :toolbar_x=>1133, :axis=>:local, :auto_smooth=>true, :ss_cos=>false, :toolbar_y=>202, :initial_tool=>"T_Select"}>
                              hm... And your monitor resolution is larger than 1133px wide? Or, is your viewport that wide?
                              Sketchup.active_model.active_view.vpwidth
                              And if you have the Ruby Console open while you use Vertex Tools, do you see any error messages appearing?
                                gt5
                                1766
                                no errors in console
                                  I'm baffled. πŸ˜•
                                  Could it be an OpenGL issue, hardware? If you disable hardware acceleration under Preferences - does that have an effect?
                                    gt5
                                    @thomthom said:
                                    I'm baffled. πŸ˜•
                                    Ok, this is just weird:
                                    Turned off HA
                                    Dialog says: The change will take effect for new windows
                                    Toolbar returns in the existing window
                                    However, now it's gone again regardless of HA setting! (I even tried restart.)
                                    I may need to reinstall the OS--not fun
                                      That is very strange. What are you hardware specs? What is the graphic card?
                                      Is it possible to update the graphic driver - or is that done automatically by OSX?
                                        Do you notice any artefacts in any other applications?
                                        What about Fredo's tools - he uses similar technique to draw the UI as I do.
                                          gt5
                                          2010 Quad-Core 2.93 GHz i7 iMac
                                          16GB RAM
                                          ATI Radeon HD 5750 1GB Graphics Ram OpenGL 3.2
                                          Can not upgrade driver
                                            gt5
                                            no problems with other apps or fredo's stuff
                                            sketchup (and only sketchup) itself crashes a lot
                                            it may, in fact, be the most poorly written high profile app ever--they know there's something terribly wrong or they wouldn't have two different, simultaneous, autosaves! (And neither of them work as advertised!)
