    Complex scripting/plugin - to create a component library
    52 Posts 2 Posters 3.1k Views 2 Watching
      Needs testing - but looks reasonably convincing...
      Indent the various parts of the code to make it 'readable'...
      [Get Notepad++ - recommended for code editing etc]
      Put your code inside a module thus:
      module LukeR
        def self.importer()
          ### add your code here
      Usage: in the Ruby Console type LukeR.importer + <enter>
      Change its name[s] as desired...
      Later you can add your own new methods too like LukeR.discombobulator ๐Ÿ˜‰
        Last couple of points.
        Using jpeg images as textures allows the faces to display received shadows [provided the containing object is set to do so too].
        Using png images means they don't take shadows at all - the advantage is that they can have a transparent background so small 'holes' will be 'see-through' even if the face has no corresponding small hole.
        The other issue is hiding the edges of the faces within the component.
        This easily done by adding a block of code near the end of each definition's processing...
        d.entities.each{|e|e.hidden=true if e.is_a?(Sketchup::Edge)}
        Only the component's faces are visible.
        If View > Hidden Geometry is set ON the edges display as 'dotted' lines
          Lersince1991
          Managed to use a batch action in illustrator to successfully ungroup/explode all the components so that issue is solved.
          Just tried saving the file as a .rb in the plugins folder and got and error. I am really not sure what I sould really do? Does the file name matter?
          module LukeR
            def self.importer()
          ### PURGE UNUSED COMPONENTS
          Sketchup.active_model.definitions.purge_unused
          ### SETUP LIST OF NAMES
          model=Sketchup.active_model
          defs=model.definitions
          cnames=[]
          defs.each{|d|cnames << d.name}
          cnames.sort!
          f='P;\02 General\Resource Library\People\JPEG'
          cnames.each{|name|
          	d=defs[name]
          	bb=Gem;;Boundingbox.new
          	d.entities.each{|e|bb.add(e.bounds)}
          	### ADD IMAGE TEXTURES
          	img=d.entities.add_image(File.join(f, File.basename(f, ".*")+".jpg"), [-1.mm,-1.mm,0], bb.width+2.mm, bb.height+2.mm)
          	img.explode
          	togos=[]
          	d.entities.each{|e|togos << e if e.valid? and e.is_a?(Sketchup;;Edge) and e.faces.length<2}
          	d.entities.erase_entities(togos)
          	d.entities.each{|e|e.reverse! if e.is_a?(Sketchup;;Face) && e.normal!=Z_AXIS}
          	### STAND COMPONENT CONTENTS TO VERTICAL
          	tr=Geom;;Transformation.rotation(ORIGIN, X_AXIS, -90.degrees)
          	d.entities.transform_entities(tr, d.entities.to_a)
          ### FACE ME
          cnames.each{|name|
          	defs[name].save_as(File.join(f, File.basename(f, ".*")+".skp"))
          ### REMOVE OUTER EDGE LEFT FROM EXPLODED IMAGE
          img.explode
          	togos=[]
          ### REMOVE HOLES
          faces=[]
          d.entities.each{|e|faces << e if e.is_a?(Sketchup;;Face)}
          (faces.length-1).times{
             for face in faces
              if face.valid?
                for edgeuse in face.outer_loop.edgeuses
                   if not edgeuse.partners[0] ### outermost face
                      faces = faces - [face]
                      loops = face.loops
                      for loop in loops
                         for fac in faces
                            if fac.valid? and (fac.outer_loop.edges - loop.edges) == []
                               faces = faces - [fac]
                               fac.erase! if fac.valid?
                               ### fac abutts kept face so it must be erased...
                            end #if fac
                         end #for fac
                      end #for loop
                   end #if outermost
                end #for edgeuse
              end #if valid
             end #for face
          }#times
          ERROR
          LukeR.importer
          Error; #<NameError; C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;17;in `importer'; uninitialized constant LukeR;;Gem>
          C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;15;in `each'
          C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;15;in `importer'
          (eval);0
          Nearly there now!
          Thanks again TIG ๐Ÿ˜„
            Typo
            bb=Gem::Boundingbox.new
            should be
            bb=Geom::Boundingbox.new
            ๐Ÿ˜’
            The error messages show what's wrong 'Gem' and the line number - here '17'...
              Lersince1991
              Ahh thank you. Will try again.
              I looked there and thought it was the double "::" that was the issue ๐Ÿ˜„
                Lersince1991
                I got the same error:
                LukeR.importer
                Error; #<NoMethodError; undefined method `new' for ;Boundingbox;Symbol>
                (eval);17
                module LukeR
                  def self.importer()
                cnames=[]
                cnames.sort!
                cnames.each{|name|
                 d=defs[name]
                 bb=Geom;;Boundingbox.new
                 img.explode
                 togos=[]
                ### FACE ME
                cnames.each{|name|
                img.explode
                	togos=[]
                ### REMOVE HOLES
                faces=[]
                   for face in faces
                    if face.valid?
                            loops = face.loops
                            for loop in loops
                               for fac in faces
                                  end #if fac
                               end #for fac
                            end #for loop
                         end #if outermost
                      end #for edgeuse
                    end #if valid
                   end #for face
                }#times
                  If you read it although it's the same line of code it is ANOTHER error!
                  Another daft typo!
                  It should actually be Bounding**B**ox
                  NOT
                  Boundingbox
                  So the line should be
                  bb=Geom::BoundingBox.new
                  I didn't spot that either... ๐Ÿ˜’
                  Incidentally the double :: is used to show the Module::Class
                  A . shows the method [def] thus:
                  Module::Class.method()
                  You can also have a Module.method()
                  Sketchup and its related modules, like Geom, have both classes/methods and methods...
                  The 'o' was simply missed out of the 'Geom' module's name, causing the error...
                  When testing a script the line references in errors are very useful [Notepad++ will display line numbers under one of it's Settings...]
                  A , instead of a . [or vice versa], a missing ( or } etc, a simple spelling error etc, can mess everything up big time... But if you know the line you can usually find the error easily...
                    Lersince1991
                    Ah ok Thankyou, I didn't realise it was case sensitive on commands! Will try again ๐Ÿ˜„
                      Lersince1991
                      Can't work this one out:
                      LukeR.importer
                      C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;21; warning; Could not create Image for P;/02 General/Resource Library/People/JPEG/JPEG.jpg
                      Error; #<NoMethodError; undefined method `explode' for nil;NilClass>
                      C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;22
                      (eval);0
                      module LukeR
                        def self.importer()
                      cnames=[]
                      cnames.sort!
                      cnames.each{|name|
                       d=defs[name]
                       bb=Geom;;BoundingBox.new
                       img.explode
                       togos=[]
                      ### FACE ME
                      cnames.each{|name|
                      img.explode
                      	togos=[]
                      ### REMOVE HOLES
                      faces=[]
                         for face in faces
                          if face.valid?
                                  loops = face.loops
                                  for loop in loops
                                     for fac in faces
                                        end #if fac
                                     end #for fac
                                  end #for loop
                               end #if outermost
                            end #for edgeuse
                          end #if valid
                         end #for face
                      }#times
                        It's because it's another typo !
                        Line#21 should read
                        img=d.entities.add_image(File.join(f, File.basename(**name**, ".*")+".jpg"), [-1.mm,-1.mm,0], bb.width+2.mm, bb.height+2.mm)
                        ๐Ÿ˜• sorry...
                          Lersince1991
                          Got some more issues TIG ๐Ÿ˜„
                          Its getting there!
                          1. It was rotating them the wrong angle so I change "-90" to "90" - so this is solved.
                          2. The result is just one component left - dont know where everything else went ๐Ÿ˜ฎ
                          3. For the one component that is left the face me doesnt seem to be working
                          4. I don't think it likes the img.explode on line 39
                          LukeR.importer
                          Error; #<NameError; undefined local variable or method `img' for LukeR;Module>
                          C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;39
                          (eval);0
                          module LukeR
                            def self.importer()
                          cnames=[]
                          cnames.sort!
                          cnames.each{|name|
                           d=defs[name]
                           img=d.entities.add_image(File.join(f, File.basename(name, ".*")+".jpg"), [-1.mm,-1.mm,0], bb.width+2.mm, bb.height+2.mm)
                           img.explode
                           togos=[]
                           tr=Geom;;Transformation.rotation(ORIGIN, X_AXIS, 90.degrees)
                          ### FACE ME
                           cnames.each{|name|
                           img.explode
                          	togos=[]
                          ### REMOVE HOLES
                          faces=[]
                             for face in faces
                              if face.valid?
                                      loops = face.loops
                                      for loop in loops
                                         for fac in faces
                                            end #if fac
                                         end #for fac
                                      end #for loop
                                   end #if outermost
                                end #for edgeuse
                              end #if valid
                             end #for face
                          }#times
                            I would have thought -90.degrees was the correct angle... but if +90 works use it ๐Ÿ˜‰
                            I'm not sure how you are adding the initial components - importing as dxf/dwg outline ?
                            Before you add the images to their matching components made from the CAD files... do you have one of every type of component in the model ?? Remember this code is just to add an image to each preexisting component with the same name...
                            You have a spurious img.explode line of code at line#39 remove it: it must have got copied down from where it's used earlier... and I'd not noticed it before...
                            There's currently no code to make each component a 'faceme' type...
                            If you want that, then in the block {} that's processing the definition 'd' add a line
                            d.behavior.always_face_camera=true
                            ๐Ÿค“
                              Lersince1991
                              The .dwg files are imported into sketchup pro. But I used a batch import command I found elsewhere and it seems to work well. It will import every .dwg file in a selected folder, it imports all of these files into the current model - I used a new file so theres nothing else in it (apart from the default 2d woman!, but she got deleted). Each .dwg file is made into a component with the same name as the .dwg file. - so this should all match up with the file names of the jpegs in P:\02 General\Resource Library\People\JPEG
                              I have also attached an image that should help show what the sketchup model is like.
                              These components are all just outlines with no faces. just lines.
                              example:
                              goes with
                              0001 vyonyx_couple_001.dwg
                              Hope this helps.
                              Ok will delete it.
                              ๐Ÿค“
                              Sorry I dont understand this ๐Ÿ˜„
                              Shall I copy d.behavior.always_face_camera=true into the script? where does it go?
                              If it helps I have also found that it is creating a file in "P:\02 General\Resource Library\People\JPEG" called "JPEG.skp" - this is empty though.
                              If something is trying to save the components as .skp files, dont worry about this as long as they are in the same model I can just save all the components in the model via the components window.
                              Heres the current code:
                              module LukeR
                                def self.importer()
                              cnames=[]
                              cnames.sort!
                              cnames.each{|name|
                               d=defs[name]
                               img.explode
                               togos=[]
                              ### FACE ME
                               cnames.each{|name|
                              	togos=[]
                              ### REMOVE HOLES
                              faces=[]
                                 for face in faces
                                  if face.valid?
                                          loops = face.loops
                                          for loop in loops
                                             for fac in faces
                                                end #if fac
                                             end #for fac
                                          end #for loop
                                       end #if outermost
                                    end #for edgeuse
                                  end #if valid
                                 end #for face
                              }#times
                                You have got some of your coding steps in a tangle...
                                I'll fix it and post a working [hopefully] version soonest...
                                Incidentally, you don't need to open SketchUp with 'the 2d-woman' etc.
                                You can delete her, Model Info > Statistics > Purge Unused...
                                Then set other values exactly as desired - Units, number of dp's, no-snapping, no-unit-suffix, Text font/size, Dimension defaults etc.
                                Then under File > Save as Template. Under Preferences set that as your default template, thereafter every time you open a new SKP it will be empty and have the exact settings you prefer...
                                  Lersince1991
                                  Ok Thank you!!!!!!!!
                                  ~~I have used sketchup for 5 years and never bothered to change the default style! ๐Ÿ˜ฎ
                                  Thanks ~~
                                  CHANGED!
                                    Here it is:
                                    I can't try it because I have no paired dwg/image sets...
                                    ### Usage; Ruby Console type LukeR.importer
                                    require('sketchup.rb')
                                    module LukeR
                                      def self.importer()
                                    	### PURGE UNUSED COMPONENTS [NOT NEEDED IF YOU DO IT MANUALLY FIRST]
                                    	#defs.purge_unused
                                    	### SETUP LIST OF NAMES etc
                                    	cnames=[]
                                    	defs.each{|d|cnames << d.name if File.extname(d.name).downcase == '.dwg'}
                                    	cnames.sort!
                                    	fj='P;\02 General\Resource Library\People\JPEG' ### for images
                                    	ff='P;\02 General\Resource Library\People' ### for saved SKPs
                                    	cnames.each{|name|
                                    		puts name
                                    		### SET UP defn etc
                                    		d=defs[name]
                                    		img=d.entities.add_image(File.join(fj, File.basename(name, ".*")+".jpg"), [-1.mm,-1.mm,0], bb.width+2.mm, bb.height+2.mm)
                                    		img.explode
                                    		### REMOVE img's UNWANTED PERIMETER
                                    		togos=[]
                                    		### ENSURE FACES ARE 'UP'
                                    		### STAND COMPONENT'S CONTENTS TO BE VERTICAL
                                    		### MAKE IT A FACE-ME COMPONENT
                                    		### REMOVE ANY 'HOLES'
                                    		faces=[]
                                    		   for face in faces
                                    			if face.valid?
                                    					loops = face.loops
                                    					for loop in loops
                                    					   for fac in faces
                                    						  end #if fac
                                    					   end #for fac
                                    					end #for loop
                                    				 end #if outermost
                                    			  end #for edgeuse
                                    			end #if valid
                                    		   end #for face
                                    		}#times
                                    		### FINALLY... SAVE IT INTO 'PEOPLE' AS A' SKP'
                                    		d.save_as(File.join(ff, File.basename(name, ".*")+".skp"))
                                    	}#names
                                    	end#def
                                    end#module
                                      Lersince1991
                                      SO MUCH BETTER!
                                      Ok its getting there!
                                      Its not working fully.
                                      I have deleted parts of the script and tried it again at various stages.
                                      I think the deleting the img edges after exploding isnt working. I think the newly created face needs to be intersected with the rest of the outline (found that the whole rectangle is one face and currently ignores the outline).
                                      Can we add an intersect just after ### ADD IMAGE TEXTURES?
                                        The img.explode ought to auto-intersect the image's face and the rest of the edges [I assume that the component 'outline' consists of just edges ??]
                                        However, as you suggest... the following code inserted immediately after the 'img.explode' line of code, should ensure proper intersection, if it's possible...
                                        t=Geom::Transformation.new() d.entities.intersect_with(false, t, d.entities, t, true, d.entities.to_a)
                                        Things that might stop this being always effective are:
                                        that the outline edges are not quite coplanar and therefore don't split the newly added image face:
                                        the outline contains edges that are tiny in length, and thereby the Sketchup intersect method fails as both ends are deemed to be coincident and therefore the edge is not recognized and therefore no full loop is made as needed to hold a face...
                                        If that's the case we can try to 'heal' tiny edges... but let's first see how the current fix-up ideas work... ๐Ÿ˜•
                                          Lersince1991
                                          Yeah the components are just faces after being importer as dwg.
                                          I tried just to add the textures them intersect them individually and that worked hence the suggestion of an intersect.
                                          So that should work!
                                          But I did this and got an error:
                                          LukeR.importer
                                          Error; #<NoMethodError; undefined method `transformation' for Geom;Module>
                                          C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;32
                                          C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;20;in `each'
                                          C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;20;in `importer'
                                          (eval);0
                                          I obviously put them in wrong! Sorry ๐Ÿ˜ž
                                          UPDATE: My guess is it needs a capital T on transformation
                                          testing now
                                          module LukeR
                                            def self.importer()
                                             #defs.purge_unused
                                             cnames=[]
                                             cnames.sort!
                                             ff='P;\02 General\Resource Library\People\Sketchup People' ### for saved SKPs
                                             cnames.each{|name|
                                                puts name
                                                ### SET UP defn etc
                                                d=defs[name]
                                                img.explode
                                                t=Geom;;transformation.new()
                                                togos=[]
                                                ### REMOVE OUTER EDGES LEFT FROM EXPLODED IMAGE
                                                togos=[]
                                                faces=[]
                                                   for face in faces
                                                   if face.valid?
                                                         loops = face.loops
                                                         for loop in loops
                                                            for fac in faces
                                                              end #if fac
                                                            end #for fac
                                                         end #for loop
                                                       end #if outermost
                                                     end #for edgeuse
                                                   end #if valid
                                                   end #for face
                                                }#times
                                             }#names
                                             end#def
                                          end#module
                                          It didnt do that before I added the intersect command
                                            You are right it needs to be t=Geom::**T**ransformation.new()
                                            • 2 / 3
