    Complex scripting/plugin - to create a component library
    52 Posts 2 Posters 4.3k Views 2 Watching
      Lersince1991
      Ahh thank you. Will try again.
      I looked there and thought it was the double "::" that was the issue ๐Ÿ˜„
        Lersince1991
        I got the same error:
        LukeR.importer
        Error; #<NoMethodError; undefined method `new' for ;Boundingbox;Symbol>
        C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;17
        C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;15;in `each'
        C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;15;in `importer'
        (eval);17
        module LukeR
          def self.importer()
        ### PURGE UNUSED COMPONENTS
        Sketchup.active_model.definitions.purge_unused
        ### SETUP LIST OF NAMES
        model=Sketchup.active_model
        defs=model.definitions
        cnames=[]
        defs.each{|d|cnames << d.name}
        cnames.sort!
        f='P;\02 General\Resource Library\People\JPEG'
        cnames.each{|name|
         d=defs[name]
         bb=Geom;;Boundingbox.new
         d.entities.each{|e|bb.add(e.bounds)}
         ### ADD IMAGE TEXTURES
         img=d.entities.add_image(File.join(f, File.basename(f, ".*")+".jpg"), [-1.mm,-1.mm,0], bb.width+2.mm, bb.height+2.mm)
         img.explode
         togos=[]
         d.entities.each{|e|togos << e if e.valid? and e.is_a?(Sketchup;;Edge) and e.faces.length<2}
         d.entities.erase_entities(togos)
         d.entities.each{|e|e.reverse! if e.is_a?(Sketchup;;Face) && e.normal!=Z_AXIS}
         ### STAND COMPONENT CONTENTS TO VERTICAL
         tr=Geom;;Transformation.rotation(ORIGIN, X_AXIS, -90.degrees)
         d.entities.transform_entities(tr, d.entities.to_a)
        ### FACE ME
        cnames.each{|name|
        	defs[name].save_as(File.join(f, File.basename(f, ".*")+".skp"))
        ### REMOVE OUTER EDGE LEFT FROM EXPLODED IMAGE
        img.explode
        	togos=[]
        ### REMOVE HOLES
        faces=[]
        d.entities.each{|e|faces << e if e.is_a?(Sketchup;;Face)}
        (faces.length-1).times{
           for face in faces
            if face.valid?
              for edgeuse in face.outer_loop.edgeuses
                 if not edgeuse.partners[0] ### outermost face
                    faces = faces - [face]
                    loops = face.loops
                    for loop in loops
                       for fac in faces
                          if fac.valid? and (fac.outer_loop.edges - loop.edges) == []
                             faces = faces - [fac]
                             fac.erase! if fac.valid?
                             ### fac abutts kept face so it must be erased...
                          end #if fac
                       end #for fac
                    end #for loop
                 end #if outermost
              end #for edgeuse
            end #if valid
           end #for face
        }#times
          If you read it although it's the same line of code it is ANOTHER error!
          Another daft typo!
          It should actually be Bounding**B**ox
          NOT
          Boundingbox
          So the line should be
          bb=Geom::BoundingBox.new
          I didn't spot that either... ๐Ÿ˜’
          Incidentally the double :: is used to show the Module::Class
          A . shows the method [def] thus:
          Module::Class.method()
          You can also have a Module.method()
          Sketchup and its related modules, like Geom, have both classes/methods and methods...
          The 'o' was simply missed out of the 'Geom' module's name, causing the error...
          When testing a script the line references in errors are very useful [Notepad++ will display line numbers under one of it's Settings...]
          A , instead of a . [or vice versa], a missing ( or } etc, a simple spelling error etc, can mess everything up big time... But if you know the line you can usually find the error easily...
            Lersince1991
            Ah ok Thankyou, I didn't realise it was case sensitive on commands! Will try again ๐Ÿ˜„
              Lersince1991
              Can't work this one out:
              LukeR.importer
              C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;21; warning; Could not create Image for P;/02 General/Resource Library/People/JPEG/JPEG.jpg
              Error; #<NoMethodError; undefined method `explode' for nil;NilClass>
              C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;22
              (eval);0
              module LukeR
                def self.importer()
              cnames=[]
              cnames.sort!
              cnames.each{|name|
               d=defs[name]
               bb=Geom;;BoundingBox.new
               img.explode
               togos=[]
              ### FACE ME
              cnames.each{|name|
              img.explode
              	togos=[]
              ### REMOVE HOLES
              faces=[]
                 for face in faces
                  if face.valid?
                          loops = face.loops
                          for loop in loops
                             for fac in faces
                                end #if fac
                             end #for fac
                          end #for loop
                       end #if outermost
                    end #for edgeuse
                  end #if valid
                 end #for face
              }#times
                It's because it's another typo !
                Line#21 should read
                img=d.entities.add_image(File.join(f, File.basename(**name**, ".*")+".jpg"), [-1.mm,-1.mm,0], bb.width+2.mm, bb.height+2.mm)
                ๐Ÿ˜• sorry...
                  Lersince1991
                  Got some more issues TIG ๐Ÿ˜„
                  Its getting there!
                  1. It was rotating them the wrong angle so I change "-90" to "90" - so this is solved.
                  2. The result is just one component left - dont know where everything else went ๐Ÿ˜ฎ
                  3. For the one component that is left the face me doesnt seem to be working
                  4. I don't think it likes the img.explode on line 39
                  LukeR.importer
                  Error; #<NameError; undefined local variable or method `img' for LukeR;Module>
                  C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;39
                  (eval);0
                  module LukeR
                    def self.importer()
                  cnames=[]
                  cnames.sort!
                  cnames.each{|name|
                   d=defs[name]
                   img=d.entities.add_image(File.join(f, File.basename(name, ".*")+".jpg"), [-1.mm,-1.mm,0], bb.width+2.mm, bb.height+2.mm)
                   img.explode
                   togos=[]
                   tr=Geom;;Transformation.rotation(ORIGIN, X_AXIS, 90.degrees)
                  ### FACE ME
                   cnames.each{|name|
                   img.explode
                  	togos=[]
                  ### REMOVE HOLES
                  faces=[]
                     for face in faces
                      if face.valid?
                              loops = face.loops
                              for loop in loops
                                 for fac in faces
                                    end #if fac
                                 end #for fac
                              end #for loop
                           end #if outermost
                        end #for edgeuse
                      end #if valid
                     end #for face
                  }#times
                    I would have thought -90.degrees was the correct angle... but if +90 works use it ๐Ÿ˜‰
                    I'm not sure how you are adding the initial components - importing as dxf/dwg outline ?
                    Before you add the images to their matching components made from the CAD files... do you have one of every type of component in the model ?? Remember this code is just to add an image to each preexisting component with the same name...
                    You have a spurious img.explode line of code at line#39 remove it: it must have got copied down from where it's used earlier... and I'd not noticed it before...
                    There's currently no code to make each component a 'faceme' type...
                    If you want that, then in the block {} that's processing the definition 'd' add a line
                    d.behavior.always_face_camera=true
                    ๐Ÿค“
                      Lersince1991
                      The .dwg files are imported into sketchup pro. But I used a batch import command I found elsewhere and it seems to work well. It will import every .dwg file in a selected folder, it imports all of these files into the current model - I used a new file so theres nothing else in it (apart from the default 2d woman!, but she got deleted). Each .dwg file is made into a component with the same name as the .dwg file. - so this should all match up with the file names of the jpegs in P:\02 General\Resource Library\People\JPEG
                      I have also attached an image that should help show what the sketchup model is like.
                      These components are all just outlines with no faces. just lines.
                      example:
                      goes with
                      0001 vyonyx_couple_001.dwg
                      Hope this helps.
                      Ok will delete it.
                      ๐Ÿค“
                      Sorry I dont understand this ๐Ÿ˜„
                      Shall I copy d.behavior.always_face_camera=true into the script? where does it go?
                      If it helps I have also found that it is creating a file in "P:\02 General\Resource Library\People\JPEG" called "JPEG.skp" - this is empty though.
                      If something is trying to save the components as .skp files, dont worry about this as long as they are in the same model I can just save all the components in the model via the components window.
                      Heres the current code:
                      module LukeR
                        def self.importer()
                      cnames=[]
                      cnames.sort!
                      cnames.each{|name|
                       d=defs[name]
                       img.explode
                       togos=[]
                      ### FACE ME
                       cnames.each{|name|
                      	togos=[]
                      ### REMOVE HOLES
                      faces=[]
                         for face in faces
                          if face.valid?
                                  loops = face.loops
                                  for loop in loops
                                     for fac in faces
                                        end #if fac
                                     end #for fac
                                  end #for loop
                               end #if outermost
                            end #for edgeuse
                          end #if valid
                         end #for face
                      }#times
                        You have got some of your coding steps in a tangle...
                        I'll fix it and post a working [hopefully] version soonest...
                        Incidentally, you don't need to open SketchUp with 'the 2d-woman' etc.
                        You can delete her, Model Info > Statistics > Purge Unused...
                        Then set other values exactly as desired - Units, number of dp's, no-snapping, no-unit-suffix, Text font/size, Dimension defaults etc.
                        Then under File > Save as Template. Under Preferences set that as your default template, thereafter every time you open a new SKP it will be empty and have the exact settings you prefer...
                          Lersince1991
                          Ok Thank you!!!!!!!!
                          ~~I have used sketchup for 5 years and never bothered to change the default style! ๐Ÿ˜ฎ
                          Thanks ~~
                          CHANGED!
                            Here it is:
                            I can't try it because I have no paired dwg/image sets...
                            ### Usage; Ruby Console type LukeR.importer
                            require('sketchup.rb')
                            module LukeR
                              def self.importer()
                            	### PURGE UNUSED COMPONENTS [NOT NEEDED IF YOU DO IT MANUALLY FIRST]
                            	#defs.purge_unused
                            	### SETUP LIST OF NAMES etc
                            	cnames=[]
                            	defs.each{|d|cnames << d.name if File.extname(d.name).downcase == '.dwg'}
                            	cnames.sort!
                            	fj='P;\02 General\Resource Library\People\JPEG' ### for images
                            	ff='P;\02 General\Resource Library\People' ### for saved SKPs
                            	cnames.each{|name|
                            		puts name
                            		### SET UP defn etc
                            		d=defs[name]
                            		img=d.entities.add_image(File.join(fj, File.basename(name, ".*")+".jpg"), [-1.mm,-1.mm,0], bb.width+2.mm, bb.height+2.mm)
                            		img.explode
                            		### REMOVE img's UNWANTED PERIMETER
                            		togos=[]
                            		### ENSURE FACES ARE 'UP'
                            		### STAND COMPONENT'S CONTENTS TO BE VERTICAL
                            		### MAKE IT A FACE-ME COMPONENT
                            		### REMOVE ANY 'HOLES'
                            		faces=[]
                            		   for face in faces
                            			if face.valid?
                            					loops = face.loops
                            					for loop in loops
                            					   for fac in faces
                            						  end #if fac
                            					   end #for fac
                            					end #for loop
                            				 end #if outermost
                            			  end #for edgeuse
                            			end #if valid
                            		   end #for face
                            		}#times
                            		### FINALLY... SAVE IT INTO 'PEOPLE' AS A' SKP'
                            		d.save_as(File.join(ff, File.basename(name, ".*")+".skp"))
                            	}#names
                            	end#def
                            end#module
                              Lersince1991
                              SO MUCH BETTER!
                              Ok its getting there!
                              Its not working fully.
                              I have deleted parts of the script and tried it again at various stages.
                              I think the deleting the img edges after exploding isnt working. I think the newly created face needs to be intersected with the rest of the outline (found that the whole rectangle is one face and currently ignores the outline).
                              Can we add an intersect just after ### ADD IMAGE TEXTURES?
                                The img.explode ought to auto-intersect the image's face and the rest of the edges [I assume that the component 'outline' consists of just edges ??]
                                However, as you suggest... the following code inserted immediately after the 'img.explode' line of code, should ensure proper intersection, if it's possible...
                                t=Geom::Transformation.new() d.entities.intersect_with(false, t, d.entities, t, true, d.entities.to_a)
                                Things that might stop this being always effective are:
                                that the outline edges are not quite coplanar and therefore don't split the newly added image face:
                                the outline contains edges that are tiny in length, and thereby the Sketchup intersect method fails as both ends are deemed to be coincident and therefore the edge is not recognized and therefore no full loop is made as needed to hold a face...
                                If that's the case we can try to 'heal' tiny edges... but let's first see how the current fix-up ideas work... ๐Ÿ˜•
                                  Lersince1991
                                  Yeah the components are just faces after being importer as dwg.
                                  I tried just to add the textures them intersect them individually and that worked hence the suggestion of an intersect.
                                  So that should work!
                                  But I did this and got an error:
                                  LukeR.importer
                                  Error; #<NoMethodError; undefined method `transformation' for Geom;Module>
                                  C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;32
                                  C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;20;in `each'
                                  C;/Program Files/Google/Google SketchUp 8/Plugins/component_import.rb;20;in `importer'
                                  (eval);0
                                  I obviously put them in wrong! Sorry ๐Ÿ˜ž
                                  UPDATE: My guess is it needs a capital T on transformation
                                  testing now
                                  module LukeR
                                    def self.importer()
                                     #defs.purge_unused
                                     cnames=[]
                                     cnames.sort!
                                     ff='P;\02 General\Resource Library\People\Sketchup People' ### for saved SKPs
                                     cnames.each{|name|
                                        puts name
                                        ### SET UP defn etc
                                        d=defs[name]
                                        img.explode
                                        t=Geom;;transformation.new()
                                        togos=[]
                                        ### REMOVE OUTER EDGES LEFT FROM EXPLODED IMAGE
                                        togos=[]
                                        faces=[]
                                           for face in faces
                                           if face.valid?
                                                 loops = face.loops
                                                 for loop in loops
                                                    for fac in faces
                                                      end #if fac
                                                    end #for fac
                                                 end #for loop
                                               end #if outermost
                                             end #for edgeuse
                                           end #if valid
                                           end #for face
                                        }#times
                                     }#names
                                     end#def
                                  end#module
                                  It didnt do that before I added the intersect command
                                    You are right it needs to be t=Geom::**T**ransformation.new()
                                      Lersince1991
                                      WOW!
                                      ๐Ÿ˜„))))))))))
                                      Ok So a few things, very nearly perfect now!
                                      I have attached an image showing a new model which i dropped approx 50 people into (in less than a minute ๐Ÿ˜„)))))))
                                      Issues:
                                      1 - I believe some of the jpegs need cutting out better as some have tiny artifacts where they should be transparent. This is causing the bounding box of the outline and the jpeg of some images to be off. I will look into a quick way of doing this i photoshop. (They have all been trimmed but not sure how to batch trim/crop/remove the artifacts and images when all the image sizes are different etc... Might go to the photoshop forums for this.)
                                      2 - I removed some of the script to try and correct it as it was not working before. It seems to delete everything so all the skp files are empty. I thought this was the removing holes script but I beleive it to be either: "### REMOVE img's UNWANTED PERIMETER", "### REMOVE OUTER EDGES LEFT FROM EXPLODED IMAGE" or "### REMOVE ANY 'HOLES'"
                                      Further testing is needed to determine the culprite of the mass deleting issue.
                                      HOWEVER (dont ask me why, I will look into it though)
                                      All the components have successfully saved as perfect components with the exception of off centered jpeg textures - issue one as above. Something deleted the img borders but not sure what!
                                      1. Would be useful to get better thumbnails of the components. As they are currently shown in the component library window as the original dwg outlines - needs updating? (see attached image)
                                      2. The odd few are out of scale for example groups of people and people sitting down. This is not an issue as they are just odd ones and will be scaled down manually after ๐Ÿ˜„
                                      module LukeR
                                        def self.importer()
                                         #defs.purge_unused
                                         cnames=[]
                                         cnames.sort!
                                         ff='P;\02 General\Resource Library\Sketchup People' ### for saved SKPs
                                         cnames.each{|name|
                                            puts name
                                            ### SET UP defn etc
                                            d=defs[name]
                                            img.explode
                                            t=Geom;;Transformation.new()
                                         }#names
                                         end#def
                                      end#module
                                      This code worked:
                                      After import WOW!
                                        I noticed you aren't 'hiding edges' anywhere...
                                        In this code
                                        d.entities.each{|e|e.reverse! if e.is_a?(Sketchup::Face) && e.normal!=Z_AXIS}
                                        adjust it to read like this
                                        d.entities.each{|e|e.reverse! if e.is_a?(Sketchup::Face) && e.normal!=Z_AXIS**; e.hidden=true if e.is_a?(Sketchup::Edge)**}
                                        This saves iterating everything another time, to optimize speed...
                                        Using a PNG image with a transparent background avoids the 'white-fringe' issues of poorly trimmed JPG images. It also allows potential holes to remain 'see-through', although the cutout's shadows won't then match, and PNG textured materials on faces never 'receive shadows' either...
                                        You should also add...
                                        **d.refresh_thumbnail**
                                        to get an updated thumbnail image ?
                                        Insert it just before the line that saves the SKP externally...
                                        d.save_as(...)
                                        Hope this helps...
                                          Lersince1991
                                          I'm not sure I want to hide edges. Will have a think about that one!
                                          Mainly because I can always turn edges off on the style for the whole model.
                                          I will ask a collegue what they would prefer to do but nice to have the code there if he wants them hidden so thanks again! - I quite like the option of having them as silhuettes as well for more concept images (change style to hidden line)
                                          I will add the refresh thumbnail, cheers!
                                          I'm trying to think if I need them to receive shadows or not! - i dont think it matters, in which case I will probably change to png images. However it will solve half the issue; fill the white with transparency. But it wont get rid of the small artifacts so there will still be lots of images with off axis images. - a photoshop issue. But yeah I think your right, use pngs!
                                            Lersince1991
                                            As an alternative to hiding edges, Is it easy to move the edges to another layer to allow easy on/off of them? Just a thought.
                                            • 2 / 3
