    Sectioncutface
    17 Posts 7 Posters 1.0k Views 7 Watching
    • cottyC
      cotty
      You have to select one standard SU section cut and get the described entry in the right click context menu...
      my SketchUp gallery
        schaferron1
        I'm sorry I don't understand -
        Thanks,
        Ron
        • Chris FullmerC
          Sketchup has a section cut tool. Looks like you must first put a section cut into the model. So dig around through the toolbars until you find the section cut tool.
            schaferron1
            oh, ok, select the section plane, I was trying to select the cut on the model.
            thanks,
            Ron
              schaferron1
              oh, no... this sectioncutface plugin has been "working" for 7mins already!!! OMG I can't use this. Does anyone have another solution for filling section cuts?
              Thanks,
              Ron
                mwm5053
                You may want to use what is called poche you can find more about here
                Error 404 (Not Found)!!1
                (sketchupdate.blogspot.com)
                2011 iMac
                SU 2015 Pro, 2017 Make
                V2 Twilight
                macOS Sierra 10.12.5
                • Chris FullmerC
                  7 minutes isn't that bad if you have a lot of geometry. What are you trying to cut? If its a simple box then yeah, that might be a bad sign πŸ˜„
                    schaferron1
                    Just a simple house plan of 1200 sq ft. - had to force quit, it never worked.
                    Thanks,
                    Ron
                    • Chris FullmerC
                      it was working. You canceled it. SketchUp will crash on its own if it's not going to work. So its unfair to say it didn't work when you cut it off before it finished.
                        schaferron1
                        Chris, thanks for your help and comments. Sectioncutface is probably a good plugin, but I personally do not have the time to wait for the process to complete. Once TIG has updated it, maybe I will try it again.
                        Thanks,
                        R
                        • cottyC
                          cotty
                          You can try it by hand and see who is faster 😎
                          my SketchUp gallery
                            πŸ‘
                              What version of SketchUp are you using? Is it Free or Pro?
                              Regardless, your patience is probably what is failing here and not the tool. Used properly it works wonders.
                              • GaieusG
                                Also, this tool - like any tool in SketchUp - has to depend on the model - i.e. how "well" that model was built,how efficiently you organize it and keep it "clean" etc. Everything and anything can fail in a sloppy model.
                                In the below examples, the poly-count of this building is around the million (each corner is rounded - even the wood-work of the roof, the arched windows etc) and the SectionCutFace plugin did not fail or was even working for any unusually long time before doing its job.
                                https://lh6.googleusercontent.com/-BvQR1bGCixw/S9albKtTOwI/AAAAAAAAEBs/6yWobJFHovw/s1024/Bazilika_Metszet0000.jpg
                                https://lh6.googleusercontent.com/-bODN6SktZOQ/S9albxTYWtI/AAAAAAAAEB0/Fnez9jBM3qc/s1024/Bazilika_Metszet0001_hatter.jpg
                                https://lh6.googleusercontent.com/-k1-DeAbF5fY/S9alc410jLI/AAAAAAAAEB8/axZ0IIqRVqc/s1024/Bazilika_Metszet2_hatter.jpg
                                But of course,it's your right to wit for an update. πŸ˜‰
                                  schaferron1
                                  Thanks everybody for your input and also thanks for helping me, a real "newbee" with Layout and SU.
                                  TIG, thanks for making the sectioncutface plugin and allowing us to download it for free.
                                  I am a bit of a cry baby sometimes, especially when a process doesn't work immediately. So, sorry about that. I believe in SU + LO and Google. I think this platform will get stronger and stronger.
                                  Ron
                                  Gaieus, your sections are beautiful.
                                  • GaieusG
                                    Thanks. πŸ˜‰
                                    @schaferron1 said:
                                    I believe in SU + LO and Google...
                                    I don't know if you are aware of the fact that Google sold SketchUp to Trimble about half a year ago now. πŸ˜„
                                    Never mind, thanks or thanking. TIG is indeed exceptionally generous with his plugins πŸ‘
