    Reason why Sketchup 8 may crash
    29 Posts 7 Posters 4.3k Views 7 Watching
      @kachupp said:
      @dave r said:
      Is there a way to identify which registry entry belongs to which toolbar? I just had a look at the registry on my computer here at work. It shows ToolbarsUser-Bar0 through ToolbarsUser-Bar55 and then ToolbarsUserCustom-Bar0 through ToolbarsUserCustom-Bar53. There seem to be only 43 toolbars in the list under View>Toolbars so I think some of these registry entries probably aren't needed.
      Key HKCU\Software\Google\Sketchup8\ToolBarsUserCustom-Summary\Bars
      same goes for the ToolbarsUser-Bar#
      That doesn't appear to list which toolbars are given what number which is what I was asking for.
      • kachuppK Offline
        kachupp
        What it tells you is the number REG_DWORD HEX (DECIMAL) the number of valid toolbars so if your registry tells you
        you have 55 then you have 55 if its says 55 but 45 is the highest number of ToolBarsUser/Custom-Bar# entries then
        the last ten are invalid .. They will be empty if its truely invalid
        • kachuppK Offline
          kachupp
          SUReset.CMD
          REG EXPORT HKCU\Software\Google UPDATE.REG
          REG DELETE HKCU\Software\Google /va /f
          : Create Backup Restore Google Sketchup8 to DayOne
          • kachuppK Offline
            kachupp
            @kachupp said:
            SUReset.CMD
            Has any one CONFIRMED this works ? other than my self 😲
              The problem with all of ths Registry hacking is that it brings us full circle back to where we were BEFORE Google 'fixed' the toolbar issue. Pre v8 you simply has a cmd script that backed up the full SUp v8 registry entry which had the toolbars set as you wanted. When everything went wrong you ran another cmd file that erased and immediately replaced the Registry entry with the 'good' one...
              Surely the fixed v8 code needs to keep proper track of the changes it's making to the Registry and purge the redundant parts - we should NOT be having to do this ourselves - otherwise it's not much of an improvement 😒
              • kachuppK Offline
                kachupp
                I disagree because of the registry hack; The problems don’t exist when the dodgy registry entries don’t exist. DayOne!
                Which makes me think it’s an introduced problem ala plug-ins. They “Google” didn’t think for one minute it couldn’t be abused. 😐
                  It seems that plugin loading errors might throws things out of state.
                  I think Jim maybe found something in regard to enabling/disabling extensions.
                    KottonKing
                    I am having serious issues with Skethcup crashing. Last night I had a total of 23 crashes. Of all versions of Sketchup, version 8 is by far the most buggy. I can do some of the same things in an older version and no crashes... My crashes usually occur while using Sketchy Physics. It gets extremely frustrating while in the middle of making a model and BAM!!! Crash!
                    I make very complex Sketchy Physics models using all kinds of joints and literaly hundreds of grouped objects. I do understand that having such complex models broadens the way for more and more crashes and more often. But as I said I have made similar models in older versions of Sketchup and Physics with little to no crashes.
                    • kachuppK Offline
                      kachupp
                      I have a new Batch file (BTM 4nt/tcc only) solution.
                      : # Programmatically simplified description of what the batch file does.
                      : # add default loop variable or user specified
                      : # make sure variable is numeric if not display error and quit
                      : # display task
                      : # start loop
                      : # hit anykey to cancel loop and batch file.
                      : # if the registry key exist .and. the registry entry does not have the required key BarID
                      : # delete the registry entry (per :ToolBar_Label)
                      : # show loop counter
                      : # loop
                      : # endloop
                      : # display valid #COUNT entries
                      : # clean up environment
                      : # end batch file.
                      Extract and open the batch file in any text editor. Read the notes!
                      Advanced Batch file
                        @kachupp
                        This tool requires a not inexpensive 3rd-party add-on to Windows to be usable...
                        Can't it be done in a normal cmd/bat format ?
                        • kachuppK Offline
                          kachupp
                          @tig said:
                          @kachupp
                          Hi TIG .. The functions I used in the script are available in the FREE TCC/LE "light" version
                          @isdigit[] .. @regexist[] .. @regdelkey[] ..@regquery[]
                            OK.
                            That's not so bad.
                            Might have been a good idea to explain that in the original post though 😒
                            AND it's limited to 'home use'...
                              Reading your code it doesn't seem to overcome the ever growing list of Toolbar entries which are made from unused entries as a new toolbar arrangement is saved and supersedes the current one. This is what slows SketchUp's startup as all of the entries are read - even those that are subsequently unused...
                              For that you probably need to remove all toolbar entries with duplicate BarID values, but how do you decide which is the more current to retain? The highest ...BarN might work, but then because there are holes in the numbering do newly made ones with the same BarID fill the gaps to confuse the next use of this cleanup tool, or could you perhaps remake the lone BarID entry with the most recent values using oldest number [lowest] of BarN and erase the other higher numbered exact duplicate version ?
                              This gets us into a terrible tangle as several entries seem to refer to one another, so it'd be all too easy to cross-thread the Registry ! Aaargh!
                              • kachuppK Offline
                                kachupp
                                Hi TIG
                                What I am finding is that Getting Started and Large Tool Sets are some of the duplicated BarID values you mentioned. SU doesn’t add the BarName value to its own making it a little more tedious to sort through manually. Its either visible or not 0/1
                                Will look into more on the weekend
                                This is what I got so far
                                ToolbarsUser-Bar0 = Standard
                                ToolbarsUser-Bar1 = Principal
                                ToolbarsUser-Bar2 = Camera
                                ToolbarsUser-Bar3 = Drawing
                                ToolbarsUser-Bar4 = Modification
                                ToolbarsUser-Bar5 = Construction
                                ToolbarsUser-Bar6 = Solid Tools
                                ToolbarsUser-Bar7 = Walkthrough
                                ToolbarsUser-Bar8 = Styles
                                ToolbarsUser-Bar9 = Views
                                ToolbarsUser-Bar10=Sections
                                ToolbarsUser-Bar11=Large Tool Set
                                ToolbarsUser-Bar12=Google
                                ToolbarsUser-Bar13=Getting Started
                                ToolbarsUser-Bar14= UNKNOWN 😕
                                ToolbarsUser-Bar15=Shadows
                                ToolbarsUser-Bar16=Layers
                                ToolbarsUser-Bar17=Measurements
                                ToolbarsUser-Bar18= UNKNOWN 😕
                                ToolbarsUser-Bar19= UNKNOWN 😕
                                ToolbarsUser-Bar20= UNKNOWN 😕
                                ToolbarsUser-Bar21= UNKNOWN 😕 possible toggles for menu items
                                Values after Bar21 are allocated to Plugins "BarName"
                                These unknowns maybe Menu item toggles
                                • kachuppK Offline
                                  kachupp
                                  My findings
                                  The ToolbarUserCustom-bars appear to be backups of ToolbarsUser keys changing only x & y pos if moved.
                                  The mess in the registry is made by users trying different plugins then adbondoning the plugins because it may not be what they are after these remanences have no way of cleaning them selfs up.
                                  • danielbowringD Offline
                                    danielbowring
                                    Absolute confirm on this - went from about a minute to launch to a second or two.
                                    If you have python installed on your system, here's the script I used to remove the keys:
                                    Usage: (all values have reasonable defaults, so just executing the script is fine)
                                    $ clean_sketchup_reg.py -h
                                    usage; clean_sketchup_reg.py [-h] [--path PATH] [--root ROOT]
        [--pattern PATTERN] [--verbose VERBOSE]
                                    Sketchup Toolbar cleaner
                                    optional arguments;
                                      -h, --help         show this help message and exit
                                      --path PATH        registry path
                                      --root ROOT        root key
                                      --pattern PATTERN  remove pattern
                                      --verbose VERBOSE  verbosity
                                    Code:
                                    import _winreg as reg
                                    import re
                                    import sys
                                    import argparse
                                    def get_root_key(name);
                                        try;
                                            key = getattr(reg, name)
                                            return key
                                        except KeyError;
                                            pass
                                        raise ValueError('Root Key "%s" was not found' % name)
                                    class Cleaner(object);
                                        def __init__(self, root, path, pattern);
                                            self.root = reg.ConnectRegistry(None, root)
                                            self.set_path(path)
                                            self.pattern = pattern
                                        def set_path(self, path);
                                            current = self.root
                                            for p in path.split('/');
                                                current = reg.OpenKey(current, p)
                                            self.active_path = current
                                        def clean(self, print_errors=False);
                                            removed = 0
                                            index = 0
                                            while True;
                                                try;
                                                    key = reg.EnumKey(self.active_path, index)
                                                    if self.pattern.match(key);
                                                        try;
                                                            reg.DeleteKey(self.active_path, key)
                                                            removed += 1
                                                        except WindowsError, e;
                                                            index += 1
                                                            if print_errors;
        print 'Failed to remove', key, ';', e.message
                                                    else;
                                                        index += 1
                                                    return removed
                                    if __name__ == '__main__';
                                        parser = argparse.ArgumentParser(description='Sketchup Toolbar cleaner')
                                        parser.add_argument('--path', type=str, help='registry path', default='Software/Google/Sketchup8')
                                        parser.add_argument('--root', type=str, help='root key', default='HKEY_CURRENT_USER')
                                        parser.add_argument('--pattern', type=str, help='remove pattern', default='^ToolbarsUser(Custom)?\-Bar\d+$')
                                        parser.add_argument('--verbose', type=int, help='verbosity', default=1)
                                        args = parser.parse_args(sys.argv[1;])
                                        root = get_root_key(args.root)
                                        path = args.path
                                        try;
                                            pattern = re.compile(args.pattern)
                                        except Exception, e;
                                            raise ValueError('Invalid pattern ; ' + e.message)
                                        cleaner = Cleaner(root, path, pattern)
                                        result = cleaner.clean(args.verbose >= 2)
                                        if args.verbose >= 1;
                                            print 'removed', result, 'keys'
                                    Edit: Obligatory disclaimer, use at your own risk. I've tested it on my system and found no issues.
                                    You can also use this script to clean webdialog entries:
                                    clean_sketchup_reg.py --pattern "^WebDialog_.*$"
                                      @kachupp said:
                                      My findings
                                      Some times dead entries multiply themselves due to SketchUp bug. It's not just uninstalled plugins.
                                      • kachuppK Offline
                                        kachupp
                                        @tig said:
                                        @kachupp
                                        Yes I have found a way to do a .BAT / .CMD style way very simple indeed
                                        It appears just by deleting two specific keys instead of all has the same effect as resetting the DAY one toolbar
                                        option. Then re-instate the deleted keys restores the two deleted entries without duplicate errors. These re-instated
                                        keys do need the correct data 😕 not a problem will get to the bottom of it. "reg import whatever.reg" quick fix 😎
                                        It shouldn't in theory matter if you have thousands of useless keynames but it does because of a possible bug that's known. TT said so, I take his word as the truth 😄 Love your work Thomas 😎
                                        Will get back soon.. But the two keys we are interested in are ToolbarsUser-Summary / ToolbarsUserCustom-Summary
                                        if they don't window each other its a problem. The data stored in those keys isn't hard to comprehend.
                                        • 2 / 2
