    Reason why Sketchup 8 may crash
    29 Posts 7 Posters 4.7k Views 7 Watching
      It's a real pain trying to untangle the registry mess. In your case ~10 entries you suspect might not be used - don't worry. Not worth the hassle. The problem appear when you find houndreds or thousands - as that slows down SU.
      In my case it wasn't just the loading time, but general performance of SU that got affected.
        So I wonder what's different between your installation and mine. Is it an operating system thing or could it be somehow caused by a script?
          It could be several causes. In my case I think it's related to script loading errors - and since I can easily get such errors while developing it is one of the causes which I ran into.
          I think Jim has found some other triggers.
            I know it could be made as a reg or cmd file but currently I manually export the Sketchup HCU registry entry and make a copy of that reg file.
            Then I edit the copy with Notepad++ to remove all of the Toolbar entries - which are in a 'block'.
            I then delete the original registry entry and reload the edited reg file that no longer has any toolbar entries.
            When Sketchup first restarts all toolbars are removed and need resetting / saving...
            The original exported version is my insurance policy in case I mess up...
            Sketchup then loads so much faster after the cleanup as it's hundreds of toolbar entries lighter !
            Whenever you save the toolbar settings it seems to duplicate a set... Sketchup should purge its toolbar registry entries but it doesn't... ๐Ÿ˜’
            • kachuppK
              kachupp
              @dave r said:
              Is there a way to identify which registry entry belongs to which toolbar? I just had a look at the registry on my computer here at work. It shows ToolbarsUser-Bar0 through ToolbarsUser-Bar55 and then ToolbarsUserCustom-Bar0 through ToolbarsUserCustom-Bar53. There seem to be only 43 toolbars in the list under View>Toolbars so I think some of these registry entries probably aren't needed.
              Key HKCU\Software\Google\Sketchup8\ToolBarsUserCustom-Summary\Bars
              same goes for the ToolbarsUser-Bar#
              • kachuppK
                kachupp
                @kachupp said:
                ๐Ÿ˜Ž 4nt batch script to fix
                do r=0 to 2000
                if %@regexist[HKCU\Software\Google\Sketchup8\ToolbarsUser-Bar%r] == 1 set _C=%@regdelkey[HKCU\Software\Google\Sketchup8\ToolbarsUser-Bar%r]
                if %@regexist[HKCU\Software\Google\Sketchup8\ToolbarsUserCustom-Bar%r] == 1 set _C=%@regdelkey[HKCU\Software\Google\Sketchup8\ToolbarsUserCustom-Bar%r]
                enddo
                if statements are ONELiners
                I know ya'll are ruby fans but the above 4nt/tcmd batch script removes all ToolBars-User/Custom registry keys
                "if key exist then del registry key"
                It has the effect of returning the GUI to Day 1 standard getting started toolbars
                  That doesn't appear to list which toolbars are given what number which is what I was asking for.
                  • kachuppK
                    kachupp
                    What it tells you is the number REG_DWORD HEX (DECIMAL) the number of valid toolbars so if your registry tells you
                    you have 55 then you have 55 if its says 55 but 45 is the highest number of ToolBarsUser/Custom-Bar# entries then
                    the last ten are invalid .. They will be empty if its truely invalid
                    • kachuppK
                      kachupp
                      SUReset.CMD
                      REG EXPORT HKCU\Software\Google UPDATE.REG
                      REG DELETE HKCU\Software\Google /va /f
                      : Create Backup Restore Google Sketchup8 to DayOne
                      ๐ŸŽ‰
                      • kachuppK
                        kachupp
                        @kachupp said:
                        SUReset.CMD
                        ๐ŸŽ‰
                        Has any one CONFIRMED this works ? other than my self ๐Ÿ˜ฒ
                          The problem with all of ths Registry hacking is that it brings us full circle back to where we were BEFORE Google 'fixed' the toolbar issue. Pre v8 you simply has a cmd script that backed up the full SUp v8 registry entry which had the toolbars set as you wanted. When everything went wrong you ran another cmd file that erased and immediately replaced the Registry entry with the 'good' one...
                          Surely the fixed v8 code needs to keep proper track of the changes it's making to the Registry and purge the redundant parts - we should NOT be having to do this ourselves - otherwise it's not much of an improvement ๐Ÿ˜’
                          • kachuppK
                            kachupp
                            I disagree because of the registry hack; The problems donโ€™t exist when the dodgy registry entries donโ€™t exist. DayOne!
                            Which makes me think itโ€™s an introduced problem ala plug-ins. They โ€œGoogleโ€ didnโ€™t think for one minute it couldnโ€™t be abused. ๐Ÿ˜
                              It seems that plugin loading errors might throws things out of state.
                              I think Jim maybe found something in regard to enabling/disabling extensions.
                              • K
                                KottonKing
                                I am having serious issues with Skethcup crashing. Last night I had a total of 23 crashes. Of all versions of Sketchup, version 8 is by far the most buggy. I can do some of the same things in an older version and no crashes... My crashes usually occur while using Sketchy Physics. It gets extremely frustrating while in the middle of making a model and BAM!!! Crash!
                                I make very complex Sketchy Physics models using all kinds of joints and literaly hundreds of grouped objects. I do understand that having such complex models broadens the way for more and more crashes and more often. But as I said I have made similar models in older versions of Sketchup and Physics with little to no crashes.
                                • kachuppK
                                  kachupp
                                  I have a new Batch file (BTM 4nt/tcc only) solution.
                                  : # Programmatically simplified description of what the batch file does.
                                  : # add default loop variable or user specified
                                  : # make sure variable is numeric if not display error and quit
                                  : # display task
                                  : # start loop
                                  : # hit anykey to cancel loop and batch file.
                                  : # if the registry key exist .and. the registry entry does not have the required key BarID
                                  : # delete the registry entry (per :ToolBar_Label)
                                  : # show loop counter
                                  : # loop
                                  : # endloop
                                  : # display valid #COUNT entries
                                  : # clean up environment
                                  : # end batch file.
                                  Extract and open the batch file in any text editor. Read the notes!
                                  Advanced Batch file
                                    @kachupp
                                    This tool requires a not inexpensive 3rd-party add-on to Windows to be usable...
                                    Can't it be done in a normal cmd/bat format ?
                                    • kachuppK
                                      kachupp
                                      @tig said:
                                      @kachupp
                                      Hi TIG .. The functions I used in the script are available in the FREE TCC/LE "light" version
                                      @isdigit[] .. @regexist[] .. @regdelkey[] ..@regquery[]
                                        OK.
                                        That's not so bad.
                                        Might have been a good idea to explain that in the original post though ๐Ÿ˜’
                                        AND it's limited to 'home use'...
                                          Reading your code it doesn't seem to overcome the ever growing list of Toolbar entries which are made from unused entries as a new toolbar arrangement is saved and supersedes the current one. This is what slows SketchUp's startup as all of the entries are read - even those that are subsequently unused...
                                          For that you probably need to remove all toolbar entries with duplicate BarID values, but how do you decide which is the more current to retain? The highest ...BarN might work, but then because there are holes in the numbering do newly made ones with the same BarID fill the gaps to confuse the next use of this cleanup tool, or could you perhaps remake the lone BarID entry with the most recent values using oldest number [lowest] of BarN and erase the other higher numbered exact duplicate version ?
                                          This gets us into a terrible tangle as several entries seem to refer to one another, so it'd be all too easy to cross-thread the Registry ! Aaargh!
                                          • kachuppK
                                            kachupp
                                            Hi TIG
                                            What I am finding is that Getting Started and Large Tool Sets are some of the duplicated BarID values you mentioned. SU doesnโ€™t add the BarName value to its own making it a little more tedious to sort through manually. Its either visible or not 0/1
                                            Will look into more on the weekend
                                            This is what I got so far
                                            ToolbarsUser-Bar0 = Standard
                                            ToolbarsUser-Bar1 = Principal
                                            ToolbarsUser-Bar2 = Camera
                                            ToolbarsUser-Bar3 = Drawing
                                            ToolbarsUser-Bar4 = Modification
                                            ToolbarsUser-Bar5 = Construction
                                            ToolbarsUser-Bar6 = Solid Tools
                                            ToolbarsUser-Bar7 = Walkthrough
                                            ToolbarsUser-Bar8 = Styles
                                            ToolbarsUser-Bar9 = Views
                                            ToolbarsUser-Bar10=Sections
                                            ToolbarsUser-Bar11=Large Tool Set
                                            ToolbarsUser-Bar12=Google
                                            ToolbarsUser-Bar13=Getting Started
                                            ToolbarsUser-Bar14= UNKNOWN ๐Ÿ˜•
                                            ToolbarsUser-Bar15=Shadows
                                            ToolbarsUser-Bar16=Layers
                                            ToolbarsUser-Bar17=Measurements
                                            ToolbarsUser-Bar18= UNKNOWN ๐Ÿ˜•
                                            ToolbarsUser-Bar19= UNKNOWN ๐Ÿ˜•
                                            ToolbarsUser-Bar20= UNKNOWN ๐Ÿ˜•
                                            ToolbarsUser-Bar21= UNKNOWN ๐Ÿ˜• possible toggles for menu items
                                            Values after Bar21 are allocated to Plugins "BarName"
                                            These unknowns maybe Menu item toggles
