    Zipped Plugins -- A Guide to Installing Them
    66 Posts 18 Posters 548.2k Views 18 Watching
      The error message you posted indicates it's parametric_grid.rb that can't load because it doesn't find parametric.rb. Nothing to do with SSB. πŸ˜’
      • yanrothwellY Offline
        yanrothwell
        Thanks for the info, I'm getting way over my head now. I'm now using the PM function with Dave to keep this thread tidy.
        http://www.ianrothwell.co.uk
          Lukas Wassberg
          I've had a hard time getting plugins to show up in Sketchup. Re installed and re-zipped, restarted etc. several times with no luck.
          But found out what the problme. This migth help other users with Mac.
          There are TWO sub folders named Plugins.
          1.) In Library/Applicaiton support/Goggle sketchup/Plugins (this is the corret folder to put your new plugins...)
          2.) If you right-click (Mac) on the Sketchup program located under Applications, you can choose to "show packaged". This lets you see the subfolders "hidden" in the the application. There is a Plugins folder here as well. (Don't put your new plugins here!)
          Thanks to all of you guys sharing all your knowledge and creating stunning plugins.
          Best,
          Lukas
            Welcome Lukas. You should have come here a long time ago. πŸ˜„ The thing about getting the right location to put the plugin files has been covered ad nauseum.
              pedropon
              Hi there,
              I am trying to install "The SCF Power Toolbar (version 1)"
              I tried to drop the "SCF Power Toolbar v1" in my plugins folder, try to install extension in the pref.
              My Plugins folder
              Content of my plugins folderContent of my plugins folder
              Nothing works
              Please help
              SU V 8.0.15157
              Mac OS X 10.8.2
                That's the wrong plugins folder shown in your second and third screenshots. Rather than rehash this again, go back and read the beginning of this thread.
                  Hi Pierre,
                  Besides what Dave suggested, as you can see from the notes at the bottom of the plugin post here: http://sketchucation.com/forums/viewtopic.php?t=14770
                  it is a buggy plugin and no-one takes the time and responsibility to trouble shoot any issues.
                  Please, try something else instead.
                    As mentioned by the others, it's the wrong location you're trying to install to.
                    have a look at this article on installing plugins: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                      pedropon
                      @Dave R, @Gaieus, @thomthom
                      Thanks guys I will definitely try to find some better plugins and not waste my time with those.
                      Can you point to some general interesting ones?
                        Interesting plugins? Well, what do you need a plugin to do? Don't just install plugins because they exist.
                          Hard to tell without know what and how you work. But you'll find the original plugins from that package you tried to install in the Plugins list: http://sketchucation.com/forums/viewtopic.php?p=250026
                            Yes, that toolbar plugin is "only" a collection of other plugins so you can actually install them (their up-to-date versions) one by one - and only that you really need.
                            • V Offline
                              villena
                              Please help i try to download plugin store download but its tell me that there is no application available to open it
                              • V Offline
                                villena
                                thats what I'm planning to as i told it doesn't download to my computer because its say i don't have application to open it. Once i download it then i can copy it to my sketch up the problem is i can't download it.
                                • TIGT Online
                                  When you download something from the SketchUcation PluginStore it is an RBZ file.
                                  You do not want to 'open' it - you want to 'download' it onto your computer...
                                  Ensure your browser's options are set to offer alternative processing and a folder location etc...
                                  I think you are on a MAC, so are you using Safari ?
                                  Here's some Safari help, there's lots about...
                                  http://www.dummies.com/how-to/content/how-to-change-safaris-default-file-download-locati.html
                                  When you have got the RBZ file downloaded onto your computer, you can then use SketchUp's Preferences > Extensions > Install... button, to automatically install its contents into your Plugins folder...
                                    blackdogsketch
                                    The sketchucation warehouse is very easy.
                                    Using Preferences/Extensions/Install Extension...is very easy.
                                    Buying extensions from Smustard is a PITA! I know they were the first but this business of having a zip folder...extracting the files manually...and having to guess which of the four different locations Sketchup 2015 now expects extensions (oh- plugins? Because 2015 STILL calls them PLUGINS!)..
                                    Is it App Data\Roaming\Sketchup2015\Sketchup\Plugins folder? Programs data\Sketchup\Sketchup 2015\Sketchup\Plugins? Why cant Trimble finally put an end to this insanity and why can't Smustard update their delivery system to standard rbz FILES?
                                    I've spend hours on this stuff...probably my chief gripe about the whole sketchup platform. The whole CONCEPT of Sketchup is that you really need scripts/plugins/extensions...but installing them can be confusing. And I'm not a rank amateur either.
                                      If you haven't got the SCF Plugin Store installed, why don't you just change the file extension from .zip to .rbz and use Install Extension from Preferences>Extensions. That's a hell of a lot easier.
                                      This thread was started long before Install Extension, Extension Warehouse and the SCF Plugin Store came about.
                                      • TIGT Online
                                        If you have the SketchUcation PluginsStore toolset installed it's even easier than renaming the .ZIP as .RBZ ! ...
                                        The SketchUcation submenu item 'Archive Installer...' lets you install the contents of a chosen RBZ file OR a selected ZIP file...
                                        'Add-ons' for SketchUp are ALL actually 'Plugins' - scripts written in Ruby.
                                        Some of them are written in such a way that they are ALSO 'Extensions' - this kind of Plugin allows you to control their activation using the clunky Preferences > Extensions options...
                                        In a moment of madness in v2015 Trimble renamed the 'Plugins' menu as 'Extensions'.
                                        The folder containing them is still named 'Plugins'.
                                        This broke all imported Shortcuts from earlier versions which were looking for Plugins/.. and offered users nothing more than confusion about naming...
                                        I can only surmise that it was during a fit of pique, since SketchUcation's toolset offered better management of activated Extensions etc, and similar management of ALL Plugins too...
                                        Their Extensions-Warehouse only hosts 'Plugins' which are written as 'Extensions' [which they also 'vet'].
                                        SketchUcation's PluginStore also hosts many of these in parallel, and also hosts many simpler 'Plugins' too...
                                        • 3 / 4
