    Zipped Plugins -- A Guide to Installing Them
    66 Posts 18 Posters 548.6k Views 18 Watching
    • yanrothwellY Offline
      yanrothwell
      Hello experts.
      I have read your instructions and tried all the ways that have been suggested; I have cut and pasted the individual file from the google site, I have copied the zipped file and extracted it directly within the plugins folder (C:\Program Files (x86)\Google\Google SketchUp 8\Plugins), I have moved the file rather than copying it. I have deleted the previous files before copying them over. I do not have SU 8 loaded while doing this (I have even uninstalled skecthup and then reinstalled it!). And each time it comes up with: Error Loading File parametric_grid.rb no such file to load -- ./parametric.rb
      I have also tried different files from different sources.
      What on earth is the problem? Just how idiotic am I being?
      It wouldn't be that I have a 64 bit Win 6 installed would it?
      Any pointers will be hopeful for me.
      Ian
      http://www.ianrothwell.co.uk
        Looks to me as if you haven't installed parametric.rb. http://sketchup.google.com/intl/en/download/rubyscripts/parametric.zip
          yanrothwell
          Sorry if I 😒 sounded annoyed on the last post.
          That is indeedy indeed the file I am trying to install (parametric.rb). I have just tried using the installer, (thank you ThomThom) - which works for other .rb files - and SU still refuses to see the parametric.rb for some reason.
          I bet it'll start working randomly, but for now, I'm getting a little frustrated, as I need to use the Soap Skin plugin, and it won't work without the parametric.rb file in there too.
          Me thinkings a fresh install of the whole lot again is needed.
            I sent you a PM.
              SoapSKinBubble doesn't need Parametric.rb - pretty sure I didn't need it. Nor is it specified on their website.
              Sounds there might be some other issue in your plugins folder...
                The error message you posted indicates it's parametric_grid.rb that can't load because it doesn't find parametric.rb. Nothing to do with SSB. πŸ˜’
                  yanrothwell
                  Thanks for the info, I'm getting way over my head now. I'm now using the PM function with Dave to keep this thread tidy.
                    Lukas Wassberg
                    I've had a hard time getting plugins to show up in Sketchup. Re installed and re-zipped, restarted etc. several times with no luck.
                    But found out what the problme. This migth help other users with Mac.
                    There are TWO sub folders named Plugins.
                    1.) In Library/Applicaiton support/Goggle sketchup/Plugins (this is the corret folder to put your new plugins...)
                    2.) If you right-click (Mac) on the Sketchup program located under Applications, you can choose to "show packaged". This lets you see the subfolders "hidden" in the the application. There is a Plugins folder here as well. (Don't put your new plugins here!)
                    Thanks to all of you guys sharing all your knowledge and creating stunning plugins.
                    Best,
                    Lukas
                      Welcome Lukas. You should have come here a long time ago. πŸ˜„ The thing about getting the right location to put the plugin files has been covered ad nauseum.
                        pedropon
                        Hi there,
                        I am trying to install "The SCF Power Toolbar (version 1)"
                        I tried to drop the "SCF Power Toolbar v1" in my plugins folder, try to install extension in the pref.
                        My Plugins folder
                        Content of my plugins folderContent of my plugins folder
                        Nothing works
                        Please help
                        SU V 8.0.15157
                        Mac OS X 10.8.2
                          That's the wrong plugins folder shown in your second and third screenshots. Rather than rehash this again, go back and read the beginning of this thread.
                            Hi Pierre,
                            Besides what Dave suggested, as you can see from the notes at the bottom of the plugin post here: http://sketchucation.com/forums/viewtopic.php?t=14770
                            it is a buggy plugin and no-one takes the time and responsibility to trouble shoot any issues.
                            Please, try something else instead.
                              As mentioned by the others, it's the wrong location you're trying to install to.
                              have a look at this article on installing plugins: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                                pedropon
                                @Dave R, @Gaieus, @thomthom
                                Thanks guys I will definitely try to find some better plugins and not waste my time with those.
                                Can you point to some general interesting ones?
                                  Interesting plugins? Well, what do you need a plugin to do? Don't just install plugins because they exist.
                                    Hard to tell without know what and how you work. But you'll find the original plugins from that package you tried to install in the Plugins list: http://sketchucation.com/forums/viewtopic.php?p=250026
                                      Yes, that toolbar plugin is "only" a collection of other plugins so you can actually install them (their up-to-date versions) one by one - and only that you really need.
                                      • V Offline
                                        villena
                                        Please help i try to download plugin store download but its tell me that there is no application available to open it
                                        • V Offline
                                          villena
                                          thats what I'm planning to as i told it doesn't download to my computer because its say i don't have application to open it. Once i download it then i can copy it to my sketch up the problem is i can't download it.
                                            When you download something from the SketchUcation PluginStore it is an RBZ file.
                                            You do not want to 'open' it - you want to 'download' it onto your computer...
                                            Ensure your browser's options are set to offer alternative processing and a folder location etc...
                                            I think you are on a MAC, so are you using Safari ?
                                            Here's some Safari help, there's lots about...
                                            http://www.dummies.com/how-to/content/how-to-change-safaris-default-file-download-locati.html
                                            When you have got the RBZ file downloaded onto your computer, you can then use SketchUp's Preferences > Extensions > Install... button, to automatically install its contents into your Plugins folder...
                                            • 3 / 4
