    Materials lose the characteristics
    renderpluginsextensions
    26 Posts 5 Posters 3.8k Views 5 Watching
    • panixiaP Offline
      panixia
      @thomthom said:
      People with problem where layers are lost: what version are you using? I experienced this in older versions of V-Ray, but I've not had this lately.
      i use 1.49etc.. the last one.
      this strange behaviour appens sometimes.
      • andybotA Offline
        andybot
        A lot of buggy things happen if you have more than one window of SU open and have vray loaded twice... so just don't do it. Know that if you open a second window of SU with vray, you'll crash vray more likely than not.
          I've not seen that behaviour - but if you copy and paste (or import) between windows while V-Ray is loaded I've seen strange things happen. That's one of the reasons why I model with V-Ray unloaded - and load it only when I need to render.
          • andybotA Offline
            andybot
            This is apart from the copy and paste bug. Try opening a second instance sometime if you have a model you already have backed up: open the material editor and run a render or two in different windows, and I can guarantee you'll end up with some vray materials lost or render not able to start...
              Oh, you mean you render simultaneously multiple times??
              • andybotA Offline
                andybot
                actually, no, I don't think I've ever done that. I mean open the material editor in separate windows, or run a render in one and the editor in another.
                • panixiaP Offline
                  panixia
                  i know about it, and i NEVER run 2 instances of vray, also i use thomthom's vray tool to load vray only in the final phases, when really is needed.
                  but under some circumstances (the ones i listed before, or most likely some odd combination of them) strange things MAY appens (luckly not always, but sometimes)..
                  • andybotA Offline
                    andybot
                    @panixia: I was responding to the OP. But I agree, the material editor by itself can be unreliable. I've found material property layers missing, and I have on occasion run into textures that get messed up, but that's usually been fixed when I change the color space of the texture to RGB.
                    • V Offline
                      valerostudio
                      It does happen in 1.49.01 and not consistently. I have heard that it can happen when you move a layer in material up or down, I have had it happen if a render crashes and I get that VRay could not start render dialog. It doesnt happen often but I have certainly had all of my material layers disappear on me. I think this was discussed in the Chaod forums and I thought I heard someone say they had a workaround. Something about opening the options dialog and closing before saving your SU file and restarting???
                      Whatever it is, I am confident that the latest release has fixed it.
                      • V Offline
                        valerostudio
                        Here is the discussion on the Chaos forums
                        http://www.chaosgroup.com/forums/vbulletin/showthread.php?63554-Losing-material-layers
                        • panixiaP Offline
                          panixia
                          what do you mean by this? i can't understand 😳
                            I'm guessing he's talking about this:
                            • panixiaP Offline
                              panixia
                              yes sir, this is right, it appened to me in a recent project.
                              i had some emissive glasses with four different level of intensity. they had to be reflective in sunny scenes and emissive in night scenes.
                              so i created the firt "emissive glass" moved the reflection layer on top of emissive and than using "duplicate material" i created emissive glass 1/2/3 and only modified the emissive layer intensity for each one.
                              once saved and reopened project, they were corrupted forever. all the newely created variations were replaced in model from the original "emissive glass" and "emissive glass 1/2/3" disappeared at all from the list.
                              so i created them back again and this time, at saving reopening file, the reflection/emissive layers were all gone..
                              the only way to get rid of this behaviour was to create the materials out of the project, save them, use flat-diffuse red,blue and pink color for the 3 galss variation (to be sure from sketchup view they were not merged again 😑 ) and "load material" one by one every time before hit renderng.
                              this was SUPER annoyng.
                              • panixiaP Offline
                                panixia
                                while (re)thinking on this fact, i'm having sort of "doo-moment" because actually you don't need to move layers at all to do this. just playng with emissive layer transparency is right enough. πŸ‘Š
                                • sketcpeppe75S Offline
                                  sketcpeppe75
                                  my version is a 1.49 and with regard to the plug-ins ... I installed only two knowing possible problems. I just know that vray is a great program, but the management of materials (materialstudio create them, recall etc ... without the possibility of an archive visible) is absurd! I'd rather create a material. vismat and have a chance to copy it into the program folder and find a menu with thumbnails visible (and of adequate size).
                                  other strange thing ... I noticed that the bump mapping only works if you apply a material to a group. ok reorganization ideas and try to post some pictures explanatory;) thanks to all.
                                    sketcpeppe75
                                    in the picture you can see what was said....I wanted it to work as vray for 3dsmax, where you can import models from Evermotion with the materials already set. in this way we can create for ourselves object libraries with materials already, without having to apply, map each time. this thing confuses me instead. πŸ˜„ Maybe I just need to find a more comprehensive manual?
                                    • panixiaP Offline
                                      panixia
                                      to do this you can still save your object properly mapped and save your .vismat material apart.
                                      then load model and vray will load it without vray layers, but the regualar "diffuse only" SU material texture mapping will stay in place. once imported the model, reload your material by right clicking on it in VFSU material editor and selecting "import material" and chose the .vismat material you saved before.
                                      this workaround works for me when i want to reuse object, furniture, trees from previous projects. and you don't need to remap textures.
                                      meglio feriti che morti.
                                      • andybotA Offline
                                        andybot
                                        I'm not sure the materials made with material studio are compatible with the current version of vfsu. That studio editor is quite a few versions back, and the way materials are defined has been significantly changed since then. I would only edit materials in the vray material editor window in Sketchup.
                                        • V Offline
                                          valerostudio
                                          I agree with Andy. I would not use the Material Studio with the 1.49.01 VRay. That Studio is from the old 1.05.30 version and there were significant changes to how materials are handled between those 2 releases. You will have issues if importing the old materials.
                                          We are close to new release from the looks of it. Let's just be patient and just deal with the bugs for just a little while longer.
                                          • V Offline
                                            valerostudio
                                            With that said, I would like the say that I wish that one day we have a material editor that looks and works more like Maxwell's. It's very slick and intuitive to use. It also has a bunch of presets like plastic, glass, satin, etc. Super easy to use and make materials in SU. Unfortunately, it's slower than molasses when rendering, so I have stayed clear.
