    Perfect Isometric View in Sketchup
    20 Posts 14 Posters 92.9k Views 14 Watching
    • cottyC Offline
      cotty
      Thanks for sharing!
      my SketchUp gallery
      • broomstickB Offline
        broomstick
        @paul russam said:
        That's so perfectly simple its almost painful that it never dawned on me before!!
        Well done on seeing the obvious and explaining it.
        The obvious is only seen when you need it. That's what I always think πŸ˜‰
          Snowy
          Very nice tutorial Broomstick!
          Can i add one thing to this? πŸ˜„
          I have a slightly different workflow.
          here's the file that u can use/import as component for different projects.
          isometric cube placed.skp
          step 1: place the cube on the red and green axes.
          step 2: set view to parallel
          step 3: select the blue face
          step 4: right click and press align view
          and this should do the job.
          Hope this will add something and thanks for bringing the subject up.
          Greetings Erwin
          • pbacotP Offline
            Thanks all. That's brilliant! If only I had any understanding why it works, I would know HOW brilliant. πŸ˜’
            • H Offline
              HPW
              Is it not the same as menu:
              Camera\Standardviews\Iso
                broomstick
                wow, now I feel like an idiot.
                But yes, you're right. Lets just say that the metod I showed allows you to do an ISO view in the direction you prefer...
                • H Offline
                  HPW
                  Hm, the Sketchup function let you do this also.
                  Rotate fairly into the wanted view and choose ISO and it will be aligned exactly into the prefered view.
                    For diametric and other view Stuff β˜€
                    From the Eboy site! 😎
                    http://hello.eboy.com/eboy/wp-content/uploads/2012/06/FRD-Bonn-SW-05s-FLAT-SW-882x623.png
                      broomstick
                      I did not know that, that's why I came up with my solution
                      thanks for pointing it out for me..
                        Snowy
                        by HPW Β» Thu Oct 11, 2012 11:17 pm
                        Haha that's something i completely overlooked. Thanks for the tip.
                        Got one more question about this:
                        The Architecture projects i work on are mostly world orientated so they don't follow the sketchup basic axes.
                        When i change the axes to follow the direction of the building and i want that view in isometric view. sketchup still shows the isometric view based on the basic axes.
                        Do i something wrong here? or is that the only restriction that your model has to follow the basic axes.
                          broomstick
                          In this case I imagine that my solution should work, but you would have to try it out πŸ˜‰
                            alcohorse
                            Thanks for the awesome tip - just what i need for some iso architectural diagrams! πŸ˜„
                            • N Offline
                              NZ Fire Service Training
                              TIG also has created a great plugin for both Axometricand Isometricviews which can be found in the link below:
                              http://sketchucation.com/forums/viewtopic.php?t=29018
                              I've found this invaluable in my workflow
                              • W Offline
                                wallride
                                Perfect!! Very thank much you!!
                                  puchengtian
                                  Perfect
                                    j03150315
                                    Thank you SOOOOO MUCH!!!!! πŸŽ‰
                                    • majidM Offline
                                      majid
                                      This is exactly, what I was searching for! Thanks for sharing the tip!
