    Perfect Isometric View in Sketchup
    20 Posts 14 Posters 90.7k Views 14 Watching
    • broomstickB Offline
      broomstick
      Hello everyone, I want to share a quick tip I concocted while doing one of my latest jobs. I had a request for a perfect isometric view and came up with a quick solution.
      What is an isometric view? It's a particular Parallel Line view where all 90Β° angles between lines are deformed to 120Β° like so:
      http://www.3dita.it/goodies/isometric/isometric1.jpg
      In this particular mode you get model views like this one:
      http://www.brynmawr.edu/cities/Cities/imgb/071/071d.gif
      source: http://www.brynmawr.edu/
      To setup this kind of view, you simply have to draw a cube starting from the Axis Origin, and then immediately view it in wireframe mode:
      http://www.3dita.it/goodies/isometric/cube1.jpg
      Now draw a line connecting the diagonal that starts from the axis origin to the opposite vertex going up (from vertex 1 to vertex 2 in the image:
      http://www.3dita.it/goodies/isometric/cube2.jpg
      And now, make sure you're using Parallel Projection and click on the "Position Camera" command
      http://www.3dita.it/goodies/isometric/cube3.jpg
      (You may find it in Camera Menu > Position camera, too)
      Now the only tricky part: click on vertex number 2, keep the mouse button pressed, and drag to point number 1. Then release.
      http://www.3dita.it/goodies/isometric/cube4.jpg
      If all is well, you will find yourself with this:
      http://www.3dita.it/goodies/isometric/cube5.jpg
      (you may need to click on zoom extents to reset the viewing clipping plane)
      Note that now vertexes 1 and 2 are overlapped!
      Try activating "Back edges" view and you get this:
      http://www.3dita.it/goodies/isometric/cube6.jpg
      Pro tip: you can save this scene to get back to it whenever you want. Also, if you save this view as 2D Autocad format, you get a perfect isometric view of your model transformed in 2D lines πŸ˜‰
      Happy isometric views, everyone πŸ˜„
      • Paul RussamP Offline
        Paul Russam
        That's so perfectly simple its almost painful that it never dawned on me before!!
        Well done on seeing the obvious and explaining it. πŸ‘ πŸ‘ πŸ‘
        Paul Russam
        English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
        • gillesG Offline
          gilles
          Brillant.
          • cottyC Offline
            cotty
            Thanks for sharing!
            my SketchUp gallery
              broomstick
              The obvious is only seen when you need it. That's what I always think πŸ˜‰
                Snowy
                Very nice tutorial Broomstick!
                Can i add one thing to this? πŸ˜„
                I have a slightly different workflow.
                here's the file that u can use/import as component for different projects.
                isometric cube placed.skp
                step 1: place the cube on the red and green axes.
                step 2: set view to parallel
                step 3: select the blue face
                step 4: right click and press align view
                and this should do the job.
                Hope this will add something and thanks for bringing the subject up.
                Greetings Erwin
                • pbacotP Offline
                  Thanks all. That's brilliant! If only I had any understanding why it works, I would know HOW brilliant. πŸ˜’
                  • H Offline
                    HPW
                    Is it not the same as menu:
                    Camera\Standardviews\Iso
                      broomstick
                      wow, now I feel like an idiot.
                      But yes, you're right. Lets just say that the metod I showed allows you to do an ISO view in the direction you prefer...
                      • H Offline
                        HPW
                        Hm, the Sketchup function let you do this also.
                        Rotate fairly into the wanted view and choose ISO and it will be aligned exactly into the prefered view.
                          For diametric and other view Stuff β˜€
                          From the Eboy site! 😎
                          http://hello.eboy.com/eboy/wp-content/uploads/2012/06/FRD-Bonn-SW-05s-FLAT-SW-882x623.png
                            broomstick
                            I did not know that, that's why I came up with my solution
                            thanks for pointing it out for me..
                              Snowy
                              by HPW Β» Thu Oct 11, 2012 11:17 pm
                              Haha that's something i completely overlooked. Thanks for the tip.
                              Got one more question about this:
                              The Architecture projects i work on are mostly world orientated so they don't follow the sketchup basic axes.
                              When i change the axes to follow the direction of the building and i want that view in isometric view. sketchup still shows the isometric view based on the basic axes.
                              Do i something wrong here? or is that the only restriction that your model has to follow the basic axes.
                                broomstick
                                In this case I imagine that my solution should work, but you would have to try it out πŸ˜‰
                                  alcohorse
                                  Thanks for the awesome tip - just what i need for some iso architectural diagrams! πŸ˜„
                                  • N Offline
                                    NZ Fire Service Training
                                    TIG also has created a great plugin for both Axometricand Isometricviews which can be found in the link below:
                                    http://sketchucation.com/forums/viewtopic.php?t=29018
                                    I've found this invaluable in my workflow
                                    • W Offline
                                      wallride
                                      Perfect!! Very thank much you!!
                                        puchengtian
                                        Perfect
                                          j03150315
                                          Thank you SOOOOO MUCH!!!!! πŸŽ‰
                                          • majidM Offline
                                            majid
                                            This is exactly, what I was searching for! Thanks for sharing the tip!
