    Perfect Isometric View in Sketchup
    20 Posts 14 Posters 93.7k Views 14 Watching
      Snowy
      Very nice tutorial Broomstick!
      Can i add one thing to this? πŸ˜„
      I have a slightly different workflow.
      here's the file that u can use/import as component for different projects.
      isometric cube placed.skp
      step 1: place the cube on the red and green axes.
      step 2: set view to parallel
      step 3: select the blue face
      step 4: right click and press align view
      and this should do the job.
      Hope this will add something and thanks for bringing the subject up.
      Greetings Erwin
      • pbacotP
        Thanks all. That's brilliant! If only I had any understanding why it works, I would know HOW brilliant. πŸ˜’
        • H
          HPW
          Is it not the same as menu:
          Camera\Standardviews\Iso
          • broomstickB
            broomstick
            wow, now I feel like an idiot.
            But yes, you're right. Lets just say that the metod I showed allows you to do an ISO view in the direction you prefer...
            • H
              HPW
              Hm, the Sketchup function let you do this also.
              Rotate fairly into the wanted view and choose ISO and it will be aligned exactly into the prefered view.
                For diametric and other view Stuff β˜€
                From the Eboy site! 😎
                http://hello.eboy.com/eboy/wp-content/uploads/2012/06/FRD-Bonn-SW-05s-FLAT-SW-882x623.png
                • broomstickB
                  broomstick
                  I did not know that, that's why I came up with my solution
                  thanks for pointing it out for me..
                    Snowy
                    by HPW Β» Thu Oct 11, 2012 11:17 pm
                    Haha that's something i completely overlooked. Thanks for the tip.
                    Got one more question about this:
                    The Architecture projects i work on are mostly world orientated so they don't follow the sketchup basic axes.
                    When i change the axes to follow the direction of the building and i want that view in isometric view. sketchup still shows the isometric view based on the basic axes.
                    Do i something wrong here? or is that the only restriction that your model has to follow the basic axes.
                    • broomstickB
                      broomstick
                      In this case I imagine that my solution should work, but you would have to try it out πŸ˜‰
                        alcohorse
                        Thanks for the awesome tip - just what i need for some iso architectural diagrams! πŸ˜„
                        • N
                          NZ Fire Service Training
                          TIG also has created a great plugin for both Axometricand Isometricviews which can be found in the link below:
                          404 Not Found
                          (sketchucation.com)
                          I've found this invaluable in my workflow
                          • W
                            wallride
                            Perfect!! Very thank much you!!
                            • P
                              puchengtian
                              Perfect
                                j03150315
                                Thank you SOOOOO MUCH!!!!! πŸŽ‰
                                • majidM
                                  majid
                                  This is exactly, what I was searching for! Thanks for sharing the tip!
