    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      @tig said:
      It's all fine now 😉
      Presumably the unused/older "LibFredo6.plugins" file that is now left behind in the Plugins folder can be removed from there without any issues...
      The similar/newer file within the subfolder is the one doing the work ...
      Yes the LibFredo6.plugin file in the main Plugins directory is useless (and harmless). It can be safely removed.
        mwm5053
        Just updated to 4.6e and noticed I have 4-joint push pull files and 4- LibTraductor files are they needed ? or should I be deleting them before an update.
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
        • fredo6F Offline
          How can you have 4 files? In which directories? Isn't it folders instead.
            mwm5053
            It's probably my mistake as I was dealing wit some computer problems and reinstalling apps and some of the plugins that I use, are they just copies of the same file?
            2011 iMac
            V2 Twilight
            • fredo6F Offline
              Strange. Normally files should be overwritten.
              Anyway, I suggest you delete all files and folders that are indexed with a suffix and keep the ones with the valid names.
                pro saudi
                thanks Fredo6 for these plugins ...
                i found out that the update link has changed...(i get an error wen i update)
                the old link is
                http://sketchucation.com/viewtopic.php?f=180&t=3263
                but the new link has to be
                http://sketchucation.com/forums/viewtopic.php?f=180&t=3263
                i hope that you can fix it as fast as Possible
                (i am pretty sour that it is easy for you)
                and thanks ... Again 😄
                • fredo6F Offline
                  the old link is
                  Which links?
                  Did you install V4.6e ?
                    pro saudi
                    Which links?
                    yeah now it works like charm ... thanks
                    • sbpronhS Offline
                      sbpronh
                      Hello,
                      De plugins are loading very well! Except for a few ones. I get one of the following errors:
                      PLUGIN: building_structure_tool.rb
                      FOLDER: H:/Privat/#ibDH/SketchUp/Plugins
                      ERROR: private method ´gsub! called for nil:NilClass
                      or from another plugin:
                      ERROR: undefined method ´+' for nil:NilClass
                      Can you tell me what is wrong?
                      Regards
                      Harry
                      • fredo6F Offline
                        @sbpronh said:
                        Hello,
                        Regards
                        Harry
                        building_structure_tool is not a plugin of mine.
                        For the other one, you have at least to tell what plugin the error is coming from.
                          tulacong
                          thank you ....oh zeeeeeeee
                            clownwhisper
                            This site is the most vague crap that I have ever seen. You click on links that would seem to take you to the plugin downloads and you go to message boards.
                            what a stupid pain in my ass....
                            Guess I wont by buying the pro version after all.
                            • Chris FullmerC Offline
                              Hi Clownwhisper, sorry its giving you such a headache. Care to elaborate a little more? What exact plugin are you trying to download?
                              SketchUcation is (amongst other things) a forum, and does not have at this moment a true plugin library. So plugins are just added to forum threads like this one. For Fredo's plugins, he typically has a thread for each specific plugin, and then this thread is devoted to a standard library of files need to run all of his plugins.
                              So, the first post in this thread has the zip file link, you should download that and extract it into your plugins folder. Then do the same for the specific plugin of his that you were trying to download.
                              Anyhow, hope that helps. If not, help us out a little bit by saying which plugin you were trying to download. Thanks!
                                schaferron1
                                will not load into Mac Sketchup pro 8. I have loaded it directly into the plugins folder. When I download this file to my desktop, there is no zip file. Just a folder with a folder and a file inside. I have tried putting the main folder in the plugins. Doesn't work. I have taken the sub file and the file out of the main file and put only those file/folder still does not load.
                                R
                                  Yes. It will load into Mac SketchUp pro 8. 😒
                                  That isn't the correct way to install it.
                                  Does the footprint match what is shown in the first post? Did you put the files into the correct Plugins folder? Did you install any of Fredo's other plugins?
                                    Trogluddite
                                    @Clownwhisper.
                                    Please try not to look a gift horse in the mouth. Almost all of the plugins here are provided by guys who take hours out of their free time to code amazing tools for us all to use FOR FREE. For the most part, they make every effort to make the plugins easy to download and install, given the limitations of the forum format (also provided for you FOR FREE).
                                    The small effort required to find the attachment links, and follow the installation instructions that these guys usually make clear is surely not much of a price to pay in order to enhance your software FOR FREE.
                                    (I have had many programs that cost big $$$$ in the past that were much more difficult to get working!)
                                    Upgrade to SU8? Well that is your choice - but please bear in mind that this site is not provided by the official developers of Sketchup, nor do the plugin writers have any ties to the developers. So you should not choose whether to upgrade based on the forum plugins - most of them will function just as well in the free version - that choice should be based on the standard stuff provided by the official developers (they are the ones who want your money, not the kind folks here).
                                    • pbacotP Offline
                                      Is there a way to turn off the update plugin. It keeps coming up, although I set it only to check every couple weeks.
                                      Peter
                                        Set it for something like 99 days.
                                          clownwhisper
                                          I am an ASP.net programmer among other things.... You need to add popups to warn people that they need to be registered and logged in to download plugins.
                                          Talk about a convoluted pile of spaghetti
                                          wow....
                                            Nobody is holding a gun to your head. You don't have to be here at all. 😒
                                            Perhaps we should put all the plugins on the Premium side. Then everyone would get to pay to have access to them and we could afford to have a proper repository for them and the authors would all make some money for their hard work instead of just getting whiners complaining.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 108
                                            • 109
                                            • 18 / 109
