    [Plugin Library] LibFredo6 - v16.1a - 31 Aug 26
    2.2k Posts 580 Posters 6.6m Views 582 Watching
    • fredo6F Offline
      @tig said:
      Mine says 4.6c NOT d...
      It's a clean install - I removed the old files/subfolder...
      LibFredo6.plugin says 4.6d in Plugins BUT 4.6c in the Lib subfolder !
      Did you come through a confirmation about "Thumb.db" when uzipping ?
        driven
        Moved the .plugin and all is fine...
        @dave r said:
        So that .plugin file shouldn't have been outside the folder?
        it's a text file that just looks like a plugin on a mac, because of it's extension.
          There is/was a 'Thumbs.db' in the subfolder within the zip BUT no issues with it's extraction. The .plugins inside the original zipped set is 4.6c NOT like the one in the zip [Plugins folder level] ?
          As I said in the previous post, that leapfrogged this... copying the newer '4.6d' .plugins file into the subfolder makes it work fine 😕
            mrossk
            if I place the ".plugin" file inside the "LibFredo" subfolder it works. So thanks for that,
            Michael
            https://www.mkaplanfinefurniture.com/
              Should the .plugins file be in the Plugins folder and/or in the LibFredo subfolder... ???
              OR just in the subfolder ?
              I don't see the Plugins located version in any of the earlier zip archives, except inside the subfolder...
              The current version works fine IF the newer version .plugins file is only inside the subfolder, and NOT in the Plugins folder at all. ☀
              • fredo6F Offline
                TIG,
                For whatever reason, the LibFredo6.plugin file was not in the right place. It should be in LIBFREDO6_Dir_46 subfolder. This is the file I modified, as it holds the address of the Sketchucation web site for checking updates.
                I hopefully fixed that problem with LibFredo6 4.6e
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v4.6e - 03 Oct 12
                  LibFredo6 4.6e is a minor release which essentially fixes a problem in the functionality "Check for Updates". The issues comes from the change in URL schema of the new SKetchucation web site.
                  PS: there was a wrong manipulation with version 4.6d. One file (LibFredo6.plugin) was misplaced. So update with a clean version of LibFredo6 4.6e
                    It's all fine now 😉
                    Presumably the unused/older "LibFredo6.plugins" file that is now left behind in the Plugins folder can be removed from there without any issues...
                    The similar/newer file within the subfolder is the one doing the work ...
                    • fredo6F Offline
                      @tig said:
                      It's all fine now 😉
                      Yes the LibFredo6.plugin file in the main Plugins directory is useless (and harmless). It can be safely removed.
                        mwm5053
                        Just updated to 4.6e and noticed I have 4-joint push pull files and 4- LibTraductor files are they needed ? or should I be deleting them before an update.
                        2011 iMac
                        SU 2015 Pro, 2017 Make
                        V2 Twilight
                        macOS Sierra 10.12.5
                        • fredo6F Offline
                          How can you have 4 files? In which directories? Isn't it folders instead.
                            mwm5053
                            It's probably my mistake as I was dealing wit some computer problems and reinstalling apps and some of the plugins that I use, are they just copies of the same file?
                            2011 iMac
                            V2 Twilight
                            • fredo6F Offline
                              Strange. Normally files should be overwritten.
                              Anyway, I suggest you delete all files and folders that are indexed with a suffix and keep the ones with the valid names.
                                pro saudi
                                thanks Fredo6 for these plugins ...
                                i found out that the update link has changed...(i get an error wen i update)
                                the old link is
                                http://sketchucation.com/viewtopic.php?f=180&t=3263
                                but the new link has to be
                                http://sketchucation.com/forums/viewtopic.php?f=180&t=3263
                                i hope that you can fix it as fast as Possible
                                (i am pretty sour that it is easy for you)
                                and thanks ... Again 😄
                                • fredo6F Offline
                                  the old link is
                                  Which links?
                                  Did you install V4.6e ?
                                    pro saudi
                                    Which links?
                                    yeah now it works like charm ... thanks
                                    • sbpronhS Offline
                                      sbpronh
                                      Hello,
                                      De plugins are loading very well! Except for a few ones. I get one of the following errors:
                                      PLUGIN: building_structure_tool.rb
                                      FOLDER: H:/Privat/#ibDH/SketchUp/Plugins
                                      ERROR: private method ´gsub! called for nil:NilClass
                                      or from another plugin:
                                      ERROR: undefined method ´+' for nil:NilClass
                                      Can you tell me what is wrong?
                                      Regards
                                      Harry
                                      • fredo6F Offline
                                        @sbpronh said:
                                        Hello,
                                        Regards
                                        Harry
                                        building_structure_tool is not a plugin of mine.
                                        For the other one, you have at least to tell what plugin the error is coming from.
                                          tulacong
                                          thank you ....oh zeeeeeeee
                                            clownwhisper
                                            This site is the most vague crap that I have ever seen. You click on links that would seem to take you to the plugin downloads and you go to message boards.
                                            what a stupid pain in my ass....
                                            Guess I wont by buying the pro version after all.
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 111
                                            • 112
                                            • 24 / 112
