    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.1m Views 585 Watching
      driven
      Moved the .plugin and all is fine...
      @dave r said:
      So that .plugin file shouldn't have been outside the folder?
      it's a text file that just looks like a plugin on a mac, because of it's extension.
        @tig said:
        Mine says 4.6c NOT d...
        It's a clean install - I removed the old files/subfolder...
        LibFredo6.plugin says 4.6d in Plugins BUT 4.6c in the Lib subfolder !
        Did you come through a confirmation about "Thumb.db" when uzipping ?
        There is/was a 'Thumbs.db' in the subfolder within the zip BUT no issues with it's extraction. The .plugins inside the original zipped set is 4.6c NOT like the one in the zip [Plugins folder level] ?
        As I said in the previous post, that leapfrogged this... copying the newer '4.6d' .plugins file into the subfolder makes it work fine 😕
          mrossk
          if I place the ".plugin" file inside the "LibFredo" subfolder it works. So thanks for that,
          Michael
          https://www.mkaplanfinefurniture.com/
            Should the .plugins file be in the Plugins folder and/or in the LibFredo subfolder... ???
            OR just in the subfolder ?
            I don't see the Plugins located version in any of the earlier zip archives, except inside the subfolder...
            The current version works fine IF the newer version .plugins file is only inside the subfolder, and NOT in the Plugins folder at all. ☀
            • fredo6F
              TIG,
              For whatever reason, the LibFredo6.plugin file was not in the right place. It should be in LIBFREDO6_Dir_46 subfolder. This is the file I modified, as it holds the address of the Sketchucation web site for checking updates.
              I hopefully fixed that problem with LibFredo6 4.6e
              • fredo6F
                NEW RELEASE: LibFredo6 v4.6e - 03 Oct 12
                LibFredo6 4.6e is a minor release which essentially fixes a problem in the functionality "Check for Updates". The issues comes from the change in URL schema of the new SKetchucation web site.
                PS: there was a wrong manipulation with version 4.6d. One file (LibFredo6.plugin) was misplaced. So update with a clean version of LibFredo6 4.6e
                  It's all fine now 😉
                  Presumably the unused/older "LibFredo6.plugins" file that is now left behind in the Plugins folder can be removed from there without any issues...
                  The similar/newer file within the subfolder is the one doing the work ...
                  • fredo6F
                    @tig said:
                    It's all fine now 😉
                    Yes the LibFredo6.plugin file in the main Plugins directory is useless (and harmless). It can be safely removed.
                      mwm5053
                      Just updated to 4.6e and noticed I have 4-joint push pull files and 4- LibTraductor files are they needed ? or should I be deleting them before an update.
                      2011 iMac
                      SU 2015 Pro, 2017 Make
                      V2 Twilight
                      macOS Sierra 10.12.5
                      • fredo6F
                        How can you have 4 files? In which directories? Isn't it folders instead.
                          mwm5053
                          It's probably my mistake as I was dealing wit some computer problems and reinstalling apps and some of the plugins that I use, are they just copies of the same file?
                          2011 iMac
                          V2 Twilight
                          • fredo6F
                            Strange. Normally files should be overwritten.
                            Anyway, I suggest you delete all files and folders that are indexed with a suffix and keep the ones with the valid names.
                            • P
                              pro saudi
                              thanks Fredo6 for these plugins ...
                              i found out that the update link has changed...(i get an error wen i update)
                              the old link is
                              http://sketchucation.com/viewtopic.php?f=180&t=3263
                              but the new link has to be
                              http://sketchucation.com/forums/viewtopic.php?f=180&t=3263
                              i hope that you can fix it as fast as Possible
                              (i am pretty sour that it is easy for you)
                              and thanks ... Again 😄
                              • fredo6F
                                the old link is
                                Which links?
                                Did you install V4.6e ?
                                • P
                                  pro saudi
                                  Which links?
                                  yeah now it works like charm ... thanks
                                  • sbpronhS
                                    sbpronh
                                    Hello,
                                    De plugins are loading very well! Except for a few ones. I get one of the following errors:
                                    PLUGIN: building_structure_tool.rb
                                    FOLDER: H:/Privat/#ibDH/SketchUp/Plugins
                                    ERROR: private method ´gsub! called for nil:NilClass
                                    or from another plugin:
                                    ERROR: undefined method ´+' for nil:NilClass
                                    Can you tell me what is wrong?
                                    Regards
                                    Harry
                                    • fredo6F
                                      @sbpronh said:
                                      Hello,
                                      Regards
                                      Harry
                                      building_structure_tool is not a plugin of mine.
                                      For the other one, you have at least to tell what plugin the error is coming from.
                                      • T
                                        tulacong
                                        thank you ....oh zeeeeeeee
                                        • C
                                          clownwhisper
                                          This site is the most vague crap that I have ever seen. You click on links that would seem to take you to the plugin downloads and you go to message boards.
                                          what a stupid pain in my ass....
                                          Guess I wont by buying the pro version after all.
                                          • Chris FullmerC
                                            Hi Clownwhisper, sorry its giving you such a headache. Care to elaborate a little more? What exact plugin are you trying to download?
                                            SketchUcation is (amongst other things) a forum, and does not have at this moment a true plugin library. So plugins are just added to forum threads like this one. For Fredo's plugins, he typically has a thread for each specific plugin, and then this thread is devoted to a standard library of files need to run all of his plugins.
                                            So, the first post in this thread has the zip file link, you should download that and extract it into your plugins folder. Then do the same for the specific plugin of his that you were trying to download.
                                            Anyhow, hope that helps. If not, help us out a little bit by saying which plugin you were trying to download. Thanks!
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 112
                                            • 113
                                            • 24 / 113
