    [Plugin] TT_Lib²
    310 Posts 66 Posters 440.3k Views 66 Watching
      After you get that error, can you try a couple of things:
      Open the Ruby Console - report back the output of these commands:
      TT_Vertex
      load 'TT_Vertex/loader.rb'
      TT_Vertex.debug_info
      I'm really stomped here... I'm starting to wonder if there's some plugin conflict going on.
      • H Offline
        hygicell
        TT_Vertex
        TT_Vertex
        true
        ===== Vertex Tools Debug Info =====
        PLUGIN_NAME: Vertex Tools
        PLUGIN_VERSION: 1.1.4
        PLUGIN_BUILD_DATE: 2012-24-09
        SketchUp: 8.0.15158 (Pro)
        RUBY_VERSION: 1.8.6
        RUBY_PATCHLEVEL: 287
        RUBY_RELEASE_DATE: 2008-08-11
        RUBY_PLATFORM: i386-mswin32
        FILE: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_vertex.rb
        PROXY_LOADER: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/loader.rb
        ROOT_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins
        PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex
        CEXT_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/CExt/win32
        CURSOR_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Cursors
        ICONS_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Icons
        L10N_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Localisation
        WEBDIALOG_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/webdialog
        CEXT_VERSION: <undefined>
        nil
          Something is wrong with the C-Extension. (The .so file) It's not being loaded.
          Though why it doesn't load I do not know. 😕
          Maybe there's something else on your machine blocking it... ?
          What happens when you type:
          require File.join(::TT_Vertex::CEXT_PATH, 'VT_CEXT')
          or...
          require File.join(TT_Vertex::CEXT_PATH, 'VT_CEXT')
            Also, what does the File Properties for the VT_CEXT.so file look like?
              Do you have admin rights?
              Do you have UAC enabled?
              Are the permissions of the Plugin folder correct?
              • H Offline
                hygicell
                whow Thomtom, you are really driving me to a much higher level than I possess or ever would imagine to reach 😞
                the learning grade is steep 🤓
                but with a good teacher 😄
                you are an extremely good toourist guide in this wonderful land ☀
                Do you have admin rights? yes
                Do you have UAC enabled? ???
                Are the permissions of the Plugin folder correct? I suppose so
                or...
                  I'm utterly stomped.... 😞
                  The C Extension loads when you load it manually...
                  If you run these after each other:
                  require File.join(::TT_Vertex::CEXT_PATH, 'VT_CEXT') TT_Vertex.debug_info
                  Then it should report at the end the version number of the C Extension - which does then appear to work.
                  The big puzzle is why you are getting that error when you start SketchUp... Nothing is making any sense. It all look to be working ok - and it does when you load things manually. 😕
                  • H Offline
                    hygicell
                    😢 what do you want me to do ? ❓
                      Can you type this into the console:
                      After you typed load 'TT_Vertex/loader.rb' then the Vertex Tools menus and toolbars should be available, right?
                      Can you try with an empty Plugins folder? Temporarily rename your Plugins folder and create a fresh one. Then install Vertex Tools. (Use the RBZ package and install with SketchUp's native installer utility. http://www.thomthom.net/software/vertex_tools/manual/getting_started#installing_rbz )
                      Sorry that there's nothing much of a result so far - but I've never had this error reported in the 2+ years of Vertex Tools. 😕
                      • H Offline
                        hygicell
                        thanks for your patience too ❗
                        we are slowly getting somewhere:
                        not anywhere to be found
                        the box is checked in the preferences/extensions window
                        emptied plugins folder as suggested
                        new errors:
                        but now the menus and toolbars are available
                          Say what? With a completely empty Plugins folder you're getting errors??
                          I'm thinking this is a VirtualStore issue. Though I couldn't immediately see a "Compatibility Files" button in your screenshots. But it could be because my German isn't that strong.
                          Can you enter this path into Explorer:
                          C:\Users\%USERNAME%\AppData\Local\VirtualStore\Program Files (x86)\Google\Google SketchUp 8
                          If there's anything there, then they should be moved to the real Plugin folder.
                          (But since we're debugging here - move any files out of the way. Just so we can ensure the basic is working.)
                          • H Offline
                            hygicell
                            closer and closer, I believe:
                            there was a file in there:
                            plugins, with a subfile 1001bitpro
                            deleted those
                            then completely deleted 1001bitpro and reinstalled it
                            tried again, same errors
                            again deleted 1001bitpro completely
                            new situation:
                            alas, still:
                              I don't know if this has anything to do with it but what is in the Google folder under Adobe?
                              • H Offline
                                hygicell
                                  Hang on - previously you got an error where 'tt_solid_inspector.rb' would not load. Now that error is gone and the 'loader.rb' error is back??
                                  And how the VirtualStore Plugins folder is empty?
                                  Even when you turn on Hidden Files?
                                  • H Offline
                                    hygicell
                                    I have tried so many things, and I don't remember the sequence
                                    I am learning to master solids, which is why I installed solid inspector
                                    at a certain moment it did work
                                    later I installed fixSolid, which does a nice job
                                    too bad it doesn't work on components yet
                                    since I am working on an important drawing for which I need my plugins I have reinstated the original plugins folder, but with 1001bit removed
                                    that didn't seem to help
                                    the virtualstore plugins folder is now deleted, but I guess reinstalling 1001bit will recreate it
                                    for the moment I don't need 1001bit
                                    I can easily again rename both plugins folders (mine and the empty one)
                                    just tell me what to do
                                    thanks for your efforts and fast replies
                                    Frank
                                      I'd like to test the following:
                                      1:
                                      • Empty VirtualStore
                                      • Empty Plugins Folder
                                        Does any error appear then?
                                      2: (If #1 doesn't produce any error)
                                      • Empty Plugins folder
                                      • Install Vertex Tools - using the Install Extension feature in SketchUp
                                        Any errors then?
                                      • H Offline
                                        hygicell
                                        1.a do you mean completely empty visualstore (or rename it and create an empty one)?
                                        1.b I think you mean: rename plugins folders, so that plugins is empty?
                                        2.a do you mean completely empty visualstore (or rename it and create an empty one)?
                                        2.b I think I tried that (without 2.a) with good results (see page 7, 2/3 down) except for the solid inspector error
                                        and, as said, I don't need solid inspector for the moment
                                          I want to see what happens when you have nothing in the VirtualStore folder and the Plugins folder. Because it's was very odd how it previously seemed to indicate something was still loading. (the solid inspector)
                                          Re: 2.b Yes, we tried that, but before checking the VirtualStore.
                                          • H Offline
                                            hygicell
                                            ... and it might be that I had installed solid inspector in between tests, as I was in the learning curve for solids
                                            which would probably explain the error
                                            please be more specific for both folders: empty completely or temporarily rename and create an emty one
                                            • 15
                                            • 16
                                            • 6 / 16
