    [Plugin] TT_Lib²
    310 Posts 66 Posters 486.2k Views 66 Watching
      What OS do you have?
      Do you have Vista or Win7?
      Could there perhaps be some files that's ended up in virtualstore? (Do you see a Compatibility Files button in Explorer when you view the content of your Plugins folder?)
      Can you post a screenshot of the content of your plugins folder?
      The error message seem to indicate that TT_Vertex/loader.rb loads before tt_vertex.rb ... are you sure you haven't accidentally moved some files out of the TT_Vertex folder?
      Do you see a loader.rb file directly in your Plugins folder?
      • H
        hygicell
        win7 dutch language
        no compatibility files button as far as I can see
        only used your installer, did not move any files
        Kaspersky might still be the culprit:
        all of a sudden it again quarantained the other file
        • H
          hygicell
          threw out Kaspersky, installed ZoneAlarm
          reinstalled TT lib
          Kaspersky was a trial version without support, so I could not poke them, sorry
          Frank
            Does it work now? Or still any errors?
              Sure you can - one should be able to ask questions about the software you evaulate. Such as "When evaluating the trial of your software I experienced a false positive - will this be fixed?"
              • H
                hygicell
                had to fill in a complicated form
                ... done !
                still the same error messages:
                the previously missing file is in place:
                  Vertex Tools isn't related to TT_Lib2 at all. This is something different.
                  I have no idea why you are getting that error at all. 😕
                  How does the folder for Vertex Tools look like?
                    Oh - you had a screenshot there. Everything look normal. ...I'm baffled... I've never had that error reported and I cannot make sense of it.
                    It's like something is loading "loader.rb" before "tt_vertex.rb" .... 😕
                    hmm... Maybe Kaspersky also removed the .so file from Vertex Tools? There should be two files in the CEXT folder under TT_Vertex - can you confirm?
                    • H
                      hygicell
                      sure, screenhunter (free version) works like a fiddle 😛
                      I checked first, but did not know what exactly to look for
                      so, just to make sure, I deleted TT Vertex, both the file and the .rb
                      then downloaded a fresh copy and re-installed it, using your install plugin
                      the result:
                      alas:
                      oh, and by the way: I did not simply uninstall Kaspersky, I used Revo Uninstaller (free version), which removes every trace of the program. Good riddance ! 😆
                        After you get that error, can you try a couple of things:
                        Open the Ruby Console - report back the output of these commands:
                        TT_Vertex
                        load 'TT_Vertex/loader.rb'
                        TT_Vertex.debug_info
                        I'm really stomped here... I'm starting to wonder if there's some plugin conflict going on.
                        • H
                          hygicell
                          TT_Vertex
                          TT_Vertex
                          true
                          ===== Vertex Tools Debug Info =====
                          PLUGIN_NAME: Vertex Tools
                          PLUGIN_VERSION: 1.1.4
                          PLUGIN_BUILD_DATE: 2012-24-09
                          SketchUp: 8.0.15158 (Pro)
                          RUBY_VERSION: 1.8.6
                          RUBY_PATCHLEVEL: 287
                          RUBY_RELEASE_DATE: 2008-08-11
                          RUBY_PLATFORM: i386-mswin32
                          FILE: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_vertex.rb
                          PROXY_LOADER: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/loader.rb
                          ROOT_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins
                          PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex
                          CEXT_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/CExt/win32
                          CURSOR_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Cursors
                          ICONS_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Icons
                          L10N_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Localisation
                          WEBDIALOG_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/webdialog
                          CEXT_VERSION: <undefined>
                          nil
                            Something is wrong with the C-Extension. (The .so file) It's not being loaded.
                            Though why it doesn't load I do not know. 😕
                            Maybe there's something else on your machine blocking it... ?
                            What happens when you type:
                            require File.join(::TT_Vertex::CEXT_PATH, 'VT_CEXT')
                            or...
                            require File.join(TT_Vertex::CEXT_PATH, 'VT_CEXT')
                              Also, what does the File Properties for the VT_CEXT.so file look like?
                                Do you have admin rights?
                                Do you have UAC enabled?
                                Are the permissions of the Plugin folder correct?
                                • H
                                  hygicell
                                  whow Thomtom, you are really driving me to a much higher level than I possess or ever would imagine to reach 😞
                                  the learning grade is steep 🤓
                                  but with a good teacher 😄
                                  you are an extremely good toourist guide in this wonderful land ☀
                                  Do you have admin rights? yes
                                  Do you have UAC enabled? ???
                                  Are the permissions of the Plugin folder correct? I suppose so
                                  or...
                                    I'm utterly stomped.... 😞
                                    The C Extension loads when you load it manually...
                                    If you run these after each other:
                                    require File.join(::TT_Vertex::CEXT_PATH, 'VT_CEXT') TT_Vertex.debug_info
                                    Then it should report at the end the version number of the C Extension - which does then appear to work.
                                    The big puzzle is why you are getting that error when you start SketchUp... Nothing is making any sense. It all look to be working ok - and it does when you load things manually. 😕
                                    • H
                                      hygicell
                                      😢 what do you want me to do ? ❓
                                        Can you type this into the console:
                                        After you typed load 'TT_Vertex/loader.rb' then the Vertex Tools menus and toolbars should be available, right?
                                        Can you try with an empty Plugins folder? Temporarily rename your Plugins folder and create a fresh one. Then install Vertex Tools. (Use the RBZ package and install with SketchUp's native installer utility. http://www.thomthom.net/software/vertex_tools/manual/getting_started#installing_rbz )
                                        Sorry that there's nothing much of a result so far - but I've never had this error reported in the 2+ years of Vertex Tools. 😕
                                        • H
                                          hygicell
                                          thanks for your patience too ❗
                                          we are slowly getting somewhere:
                                          not anywhere to be found
                                          the box is checked in the preferences/extensions window
                                          emptied plugins folder as suggested
                                          new errors:
                                          but now the menus and toolbars are available
                                            Say what? With a completely empty Plugins folder you're getting errors??
                                            I'm thinking this is a VirtualStore issue. Though I couldn't immediately see a "Compatibility Files" button in your screenshots. But it could be because my German isn't that strong.
                                            Can you enter this path into Explorer:
                                            C:\Users\%USERNAME%\AppData\Local\VirtualStore\Program Files (x86)\Google\Google SketchUp 8
                                            If there's anything there, then they should be moved to the real Plugin folder.
                                            (But since we're debugging here - move any files out of the way. Just so we can ensure the basic is working.)
                                            • 15
                                            • 16
                                            • 5 / 16
