    [Plugin] TT_Lib²
    310 Posts 66 Posters 499.0k Views 66 Watching
      Vertex Tools isn't related to TT_Lib2 at all. This is something different.
      I have no idea why you are getting that error at all. 😕
      How does the folder for Vertex Tools look like?
        Oh - you had a screenshot there. Everything look normal. ...I'm baffled... I've never had that error reported and I cannot make sense of it.
        It's like something is loading "loader.rb" before "tt_vertex.rb" .... 😕
        hmm... Maybe Kaspersky also removed the .so file from Vertex Tools? There should be two files in the CEXT folder under TT_Vertex - can you confirm?
        • H
          hygicell
          sure, screenhunter (free version) works like a fiddle 😛
          I checked first, but did not know what exactly to look for
          so, just to make sure, I deleted TT Vertex, both the file and the .rb
          then downloaded a fresh copy and re-installed it, using your install plugin
          the result:
          alas:
          oh, and by the way: I did not simply uninstall Kaspersky, I used Revo Uninstaller (free version), which removes every trace of the program. Good riddance ! 😆
            After you get that error, can you try a couple of things:
            Open the Ruby Console - report back the output of these commands:
            TT_Vertex
            load 'TT_Vertex/loader.rb'
            TT_Vertex.debug_info
            I'm really stomped here... I'm starting to wonder if there's some plugin conflict going on.
            • H
              hygicell
              TT_Vertex
              TT_Vertex
              true
              ===== Vertex Tools Debug Info =====
              PLUGIN_NAME: Vertex Tools
              PLUGIN_VERSION: 1.1.4
              PLUGIN_BUILD_DATE: 2012-24-09
              SketchUp: 8.0.15158 (Pro)
              RUBY_VERSION: 1.8.6
              RUBY_PATCHLEVEL: 287
              RUBY_RELEASE_DATE: 2008-08-11
              RUBY_PLATFORM: i386-mswin32
              FILE: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_vertex.rb
              PROXY_LOADER: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/loader.rb
              ROOT_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins
              PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex
              CEXT_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/CExt/win32
              CURSOR_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Cursors
              ICONS_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Icons
              L10N_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Localisation
              WEBDIALOG_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/webdialog
              CEXT_VERSION: <undefined>
              nil
                Something is wrong with the C-Extension. (The .so file) It's not being loaded.
                Though why it doesn't load I do not know. 😕
                Maybe there's something else on your machine blocking it... ?
                What happens when you type:
                require File.join(::TT_Vertex::CEXT_PATH, 'VT_CEXT')
                or...
                require File.join(TT_Vertex::CEXT_PATH, 'VT_CEXT')
                  Also, what does the File Properties for the VT_CEXT.so file look like?
                    Do you have admin rights?
                    Do you have UAC enabled?
                    Are the permissions of the Plugin folder correct?
                    • H
                      hygicell
                      whow Thomtom, you are really driving me to a much higher level than I possess or ever would imagine to reach 😞
                      the learning grade is steep 🤓
                      but with a good teacher 😄
                      you are an extremely good toourist guide in this wonderful land ☀
                      Do you have admin rights? yes
                      Do you have UAC enabled? ???
                      Are the permissions of the Plugin folder correct? I suppose so
                      or...
                        I'm utterly stomped.... 😞
                        The C Extension loads when you load it manually...
                        If you run these after each other:
                        require File.join(::TT_Vertex::CEXT_PATH, 'VT_CEXT') TT_Vertex.debug_info
                        Then it should report at the end the version number of the C Extension - which does then appear to work.
                        The big puzzle is why you are getting that error when you start SketchUp... Nothing is making any sense. It all look to be working ok - and it does when you load things manually. 😕
                        • H
                          hygicell
                          😢 what do you want me to do ? ❓
                            Can you type this into the console:
                            After you typed load 'TT_Vertex/loader.rb' then the Vertex Tools menus and toolbars should be available, right?
                            Can you try with an empty Plugins folder? Temporarily rename your Plugins folder and create a fresh one. Then install Vertex Tools. (Use the RBZ package and install with SketchUp's native installer utility. http://www.thomthom.net/software/vertex_tools/manual/getting_started#installing_rbz )
                            Sorry that there's nothing much of a result so far - but I've never had this error reported in the 2+ years of Vertex Tools. 😕
                            • H
                              hygicell
                              thanks for your patience too ❗
                              we are slowly getting somewhere:
                              not anywhere to be found
                              the box is checked in the preferences/extensions window
                              emptied plugins folder as suggested
                              new errors:
                              but now the menus and toolbars are available
                                Say what? With a completely empty Plugins folder you're getting errors??
                                I'm thinking this is a VirtualStore issue. Though I couldn't immediately see a "Compatibility Files" button in your screenshots. But it could be because my German isn't that strong.
                                Can you enter this path into Explorer:
                                C:\Users\%USERNAME%\AppData\Local\VirtualStore\Program Files (x86)\Google\Google SketchUp 8
                                If there's anything there, then they should be moved to the real Plugin folder.
                                (But since we're debugging here - move any files out of the way. Just so we can ensure the basic is working.)
                                • H
                                  hygicell
                                  closer and closer, I believe:
                                  there was a file in there:
                                  plugins, with a subfile 1001bitpro
                                  deleted those
                                  then completely deleted 1001bitpro and reinstalled it
                                  tried again, same errors
                                  again deleted 1001bitpro completely
                                  new situation:
                                  alas, still:
                                    I don't know if this has anything to do with it but what is in the Google folder under Adobe?
                                    • H
                                      hygicell
                                        Hang on - previously you got an error where 'tt_solid_inspector.rb' would not load. Now that error is gone and the 'loader.rb' error is back??
                                        And how the VirtualStore Plugins folder is empty?
                                        Even when you turn on Hidden Files?
                                        • H
                                          hygicell
                                          I have tried so many things, and I don't remember the sequence
                                          I am learning to master solids, which is why I installed solid inspector
                                          at a certain moment it did work
                                          later I installed fixSolid, which does a nice job
                                          too bad it doesn't work on components yet
                                          since I am working on an important drawing for which I need my plugins I have reinstated the original plugins folder, but with 1001bit removed
                                          that didn't seem to help
                                          the virtualstore plugins folder is now deleted, but I guess reinstalling 1001bit will recreate it
                                          for the moment I don't need 1001bit
                                          I can easily again rename both plugins folders (mine and the empty one)
                                          just tell me what to do
                                          thanks for your efforts and fast replies
                                          Frank
                                            I'd like to test the following:
                                            1:
                                            • Empty VirtualStore
                                            • Empty Plugins Folder
                                              Does any error appear then?
                                            2: (If #1 doesn't produce any error)
                                            • Empty Plugins folder
                                            • Install Vertex Tools - using the Install Extension feature in SketchUp
                                              Any errors then?
                                            • 15
                                            • 16
                                            • 5 / 16
