    [Plugin] TT_Lib²
    310 Posts 66 Posters 479.5k Views 66 Watching
    • H
      hygicell
      @thomthom said:
      @hygicell said:
      Error Loading File tt_bitmap2mesh.rb
      no such file to load -- C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/libraries/win32/tt_apiError Loading File tt_cleanup.rb
      no such file to load -- C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/libraries/win32/tt_apiError Loading File tt_guide_tools.rb
      I checked, and in
      there is a tt_api-readme file, not an actual tt_api file
      I'm guessing you have Kaspersky installed - and it recently updated?
      For some reason the latest update removes the tt_api.so file. You need to tell Kaspersky to leave it alone. And please report the false positive to Kaspersky so they can correct this. The more that reports it the quicker we can hopefully see a fix.
      You're not the only one: http://sketchucation.com/forums/viewtopic.php?f=323&t=30503&start=60#p432963
      indeed, Kapersky, but apparently they have solved the problem:
      upon deleting and reinstalling TTlib with your installer, the previous errors disappeared
      I checked, the file is in place
      and this time no alarm from Kapersky
      now I had other error messages:
      Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/loader.rb
      uninitialized constant TT_Vertex
      so I deleted TT vertex, and used again your installer to install it again
      but the problem stays:
      • H
        hygicell
        by the way, many thanks for your fabulous plugins
        Frank
          What OS do you have?
          Do you have Vista or Win7?
          Could there perhaps be some files that's ended up in virtualstore? (Do you see a Compatibility Files button in Explorer when you view the content of your Plugins folder?)
          Can you post a screenshot of the content of your plugins folder?
          The error message seem to indicate that TT_Vertex/loader.rb loads before tt_vertex.rb ... are you sure you haven't accidentally moved some files out of the TT_Vertex folder?
          Do you see a loader.rb file directly in your Plugins folder?
          • H
            hygicell
            win7 dutch language
            no compatibility files button as far as I can see
            only used your installer, did not move any files
            Kaspersky might still be the culprit:
            all of a sudden it again quarantained the other file
            • H
              hygicell
              threw out Kaspersky, installed ZoneAlarm
              reinstalled TT lib
              Kaspersky was a trial version without support, so I could not poke them, sorry
              Frank
                Does it work now? Or still any errors?
                  Sure you can - one should be able to ask questions about the software you evaulate. Such as "When evaluating the trial of your software I experienced a false positive - will this be fixed?"
                  • H
                    hygicell
                    had to fill in a complicated form
                    ... done !
                    still the same error messages:
                    the previously missing file is in place:
                      Vertex Tools isn't related to TT_Lib2 at all. This is something different.
                      I have no idea why you are getting that error at all. 😕
                      How does the folder for Vertex Tools look like?
                        Oh - you had a screenshot there. Everything look normal. ...I'm baffled... I've never had that error reported and I cannot make sense of it.
                        It's like something is loading "loader.rb" before "tt_vertex.rb" .... 😕
                        hmm... Maybe Kaspersky also removed the .so file from Vertex Tools? There should be two files in the CEXT folder under TT_Vertex - can you confirm?
                        • H
                          hygicell
                          sure, screenhunter (free version) works like a fiddle 😛
                          I checked first, but did not know what exactly to look for
                          so, just to make sure, I deleted TT Vertex, both the file and the .rb
                          then downloaded a fresh copy and re-installed it, using your install plugin
                          the result:
                          alas:
                          oh, and by the way: I did not simply uninstall Kaspersky, I used Revo Uninstaller (free version), which removes every trace of the program. Good riddance ! 😆
                            After you get that error, can you try a couple of things:
                            Open the Ruby Console - report back the output of these commands:
                            TT_Vertex
                            load 'TT_Vertex/loader.rb'
                            TT_Vertex.debug_info
                            I'm really stomped here... I'm starting to wonder if there's some plugin conflict going on.
                            • H
                              hygicell
                              TT_Vertex
                              TT_Vertex
                              true
                              ===== Vertex Tools Debug Info =====
                              PLUGIN_NAME: Vertex Tools
                              PLUGIN_VERSION: 1.1.4
                              PLUGIN_BUILD_DATE: 2012-24-09
                              SketchUp: 8.0.15158 (Pro)
                              RUBY_VERSION: 1.8.6
                              RUBY_PATCHLEVEL: 287
                              RUBY_RELEASE_DATE: 2008-08-11
                              RUBY_PLATFORM: i386-mswin32
                              FILE: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_vertex.rb
                              PROXY_LOADER: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/loader.rb
                              ROOT_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins
                              PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex
                              CEXT_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/CExt/win32
                              CURSOR_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Cursors
                              ICONS_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Icons
                              L10N_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Localisation
                              WEBDIALOG_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/webdialog
                              CEXT_VERSION: <undefined>
                              nil
                                Something is wrong with the C-Extension. (The .so file) It's not being loaded.
                                Though why it doesn't load I do not know. 😕
                                Maybe there's something else on your machine blocking it... ?
                                What happens when you type:
                                require File.join(::TT_Vertex::CEXT_PATH, 'VT_CEXT')
                                or...
                                require File.join(TT_Vertex::CEXT_PATH, 'VT_CEXT')
                                  Also, what does the File Properties for the VT_CEXT.so file look like?
                                    Do you have admin rights?
                                    Do you have UAC enabled?
                                    Are the permissions of the Plugin folder correct?
                                    • H
                                      hygicell
                                      whow Thomtom, you are really driving me to a much higher level than I possess or ever would imagine to reach 😞
                                      the learning grade is steep 🤓
                                      but with a good teacher 😄
                                      you are an extremely good toourist guide in this wonderful land ☀
                                      Do you have admin rights? yes
                                      Do you have UAC enabled? ???
                                      Are the permissions of the Plugin folder correct? I suppose so
                                      or...
                                        I'm utterly stomped.... 😞
                                        The C Extension loads when you load it manually...
                                        If you run these after each other:
                                        require File.join(::TT_Vertex::CEXT_PATH, 'VT_CEXT') TT_Vertex.debug_info
                                        Then it should report at the end the version number of the C Extension - which does then appear to work.
                                        The big puzzle is why you are getting that error when you start SketchUp... Nothing is making any sense. It all look to be working ok - and it does when you load things manually. 😕
                                        • H
                                          hygicell
                                          😢 what do you want me to do ? ❓
                                            Can you type this into the console:
                                            After you typed load 'TT_Vertex/loader.rb' then the Vertex Tools menus and toolbars should be available, right?
                                            Can you try with an empty Plugins folder? Temporarily rename your Plugins folder and create a fresh one. Then install Vertex Tools. (Use the RBZ package and install with SketchUp's native installer utility. http://www.thomthom.net/software/vertex_tools/manual/getting_started#installing_rbz )
                                            Sorry that there's nothing much of a result so far - but I've never had this error reported in the 2+ years of Vertex Tools. 😕
                                            • 15
                                            • 16
                                            • 5 / 16
