    [Plugin] TT_Lib²
    310 Posts 66 Posters 486.2k Views 66 Watching
      @nektares said:
      I will report it Thomas.
      Thank you.
      • N
        nektares
        done! let´s hope they fix it soon!
        http://i249.photobucket.com/albums/gg239/nektares/Irrelephant/report.jpg
          • H
            hygicell
            Hello Thomthom,
            upon my first try, I recieved the following error messages:
            Error Loading File tt_bitmap2mesh.rb
            no such file to load -- TT_Lib2/core.rbError Loading File tt_cleanup.rb
            no such file to load -- TT_Lib2/core.rbError Loading File tt_guide_tools.rb
            I checked and realised TT_Lib2 was not directly in the plugins folder, but in a subfolder TT_Lib2 2.6.0 (or similar name, I did not write it down)
            I moved the TT_Lib2 folder to the plugins folder and erased the TT_Lib2 2.6.0 or similar name, I did not write it down
            now I get other error messages:
            no such file to load -- C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/libraries/win32/tt_apiError Loading File tt_cleanup.rb
            no such file to load -- C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/libraries/win32/tt_apiError Loading File tt_guide_tools.rb
            I checked, and in
            there is a tt_api-readme file, not an actual tt_api file
            please help
            Frank
              Check you Plugins folder has FULL security Permissions set under Properties.
              Your system might not be allowing all files to be properly installed by you [even if you're an an Admin] - so give yourself FULL rights.
              A link button near the top of the Plugins folder's Explorer Window saying something like 'Compatibility Files...' is a clear indicator of issues with your systems settings...
              Ensure it's right and then continue...
              Note that the same rights should pertain on the Materials, Components and Styles folders, because one day you will want to write to those too...
              Why not remove the suspect subfolder/files and get thomthom's Simple Installer from the Plugins Index, install that and then restart and use it to install the files/subfolders from the zip file automatically - that way you won't get into a tangle with mis-installed files etc...
                I checked, and in
                I'm guessing you have Kaspersky installed - and it recently updated?
                For some reason the latest update removes the tt_api.so file. You need to tell Kaspersky to leave it alone. And please report the false positive to Kaspersky so they can correct this. The more that reports it the quicker we can hopefully see a fix.
                You're not the only one: http://sketchucation.com/forums/viewtopic.php?f=323&t=30503&start=60#p432963
                • H
                  hygicell
                  I checked, and in
                  indeed, Kapersky, but apparently they have solved the problem:
                  upon deleting and reinstalling TTlib with your installer, the previous errors disappeared
                  I checked, the file is in place
                  and this time no alarm from Kapersky
                  now I had other error messages:
                  Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/loader.rb
                  uninitialized constant TT_Vertex
                  so I deleted TT vertex, and used again your installer to install it again
                  but the problem stays:
                  • H
                    hygicell
                    by the way, many thanks for your fabulous plugins
                    Frank
                      What OS do you have?
                      Do you have Vista or Win7?
                      Could there perhaps be some files that's ended up in virtualstore? (Do you see a Compatibility Files button in Explorer when you view the content of your Plugins folder?)
                      Can you post a screenshot of the content of your plugins folder?
                      The error message seem to indicate that TT_Vertex/loader.rb loads before tt_vertex.rb ... are you sure you haven't accidentally moved some files out of the TT_Vertex folder?
                      Do you see a loader.rb file directly in your Plugins folder?
                      • H
                        hygicell
                        win7 dutch language
                        no compatibility files button as far as I can see
                        only used your installer, did not move any files
                        Kaspersky might still be the culprit:
                        all of a sudden it again quarantained the other file
                        • H
                          hygicell
                          threw out Kaspersky, installed ZoneAlarm
                          reinstalled TT lib
                          Kaspersky was a trial version without support, so I could not poke them, sorry
                          Frank
                            Does it work now? Or still any errors?
                              Sure you can - one should be able to ask questions about the software you evaulate. Such as "When evaluating the trial of your software I experienced a false positive - will this be fixed?"
                              • H
                                hygicell
                                had to fill in a complicated form
                                ... done !
                                still the same error messages:
                                the previously missing file is in place:
                                  Vertex Tools isn't related to TT_Lib2 at all. This is something different.
                                  I have no idea why you are getting that error at all. 😕
                                  How does the folder for Vertex Tools look like?
                                    Oh - you had a screenshot there. Everything look normal. ...I'm baffled... I've never had that error reported and I cannot make sense of it.
                                    It's like something is loading "loader.rb" before "tt_vertex.rb" .... 😕
                                    hmm... Maybe Kaspersky also removed the .so file from Vertex Tools? There should be two files in the CEXT folder under TT_Vertex - can you confirm?
                                    • H
                                      hygicell
                                      sure, screenhunter (free version) works like a fiddle 😛
                                      I checked first, but did not know what exactly to look for
                                      so, just to make sure, I deleted TT Vertex, both the file and the .rb
                                      then downloaded a fresh copy and re-installed it, using your install plugin
                                      the result:
                                      alas:
                                      oh, and by the way: I did not simply uninstall Kaspersky, I used Revo Uninstaller (free version), which removes every trace of the program. Good riddance ! 😆
                                        After you get that error, can you try a couple of things:
                                        Open the Ruby Console - report back the output of these commands:
                                        TT_Vertex
                                        load 'TT_Vertex/loader.rb'
                                        TT_Vertex.debug_info
                                        I'm really stomped here... I'm starting to wonder if there's some plugin conflict going on.
                                        • H
                                          hygicell
                                          TT_Vertex
                                          TT_Vertex
                                          true
                                          ===== Vertex Tools Debug Info =====
                                          PLUGIN_NAME: Vertex Tools
                                          PLUGIN_VERSION: 1.1.4
                                          PLUGIN_BUILD_DATE: 2012-24-09
                                          SketchUp: 8.0.15158 (Pro)
                                          RUBY_VERSION: 1.8.6
                                          RUBY_PATCHLEVEL: 287
                                          RUBY_RELEASE_DATE: 2008-08-11
                                          RUBY_PLATFORM: i386-mswin32
                                          FILE: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_vertex.rb
                                          PROXY_LOADER: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/loader.rb
                                          ROOT_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins
                                          PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex
                                          CEXT_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/CExt/win32
                                          CURSOR_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Cursors
                                          ICONS_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Icons
                                          L10N_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/Localisation
                                          WEBDIALOG_PATH: C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/webdialog
                                          CEXT_VERSION: <undefined>
                                          nil
                                            Something is wrong with the C-Extension. (The .so file) It's not being loaded.
                                            Though why it doesn't load I do not know. 😕
                                            Maybe there's something else on your machine blocking it... ?
                                            What happens when you type:
                                            require File.join(::TT_Vertex::CEXT_PATH, 'VT_CEXT')
                                            or...
                                            require File.join(TT_Vertex::CEXT_PATH, 'VT_CEXT')
                                            • 15
                                            • 16
                                            • 5 / 16
