    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    335 Posts 107 Posters 468.3k Views 107 Watching
      tak2hata
      Hi,All.
      I update to version1.2. in Sep17,2012.
      v1.2:2012.09.17:
      Bugs? fixed.and Improves.
      #Fix:Undo when Multi(Extend/Chamfer/Grow).
      #Fix:Undo when change properties of many entities.
      #Fix:(Extend/Chamfer/Grow) Structure entity which have devided side by user.
      #Improve about create slab.
      Hi,Sumaster.
      In your file ,there was no compound wall.
      But the wall's edge was cutted by your manipulation.It do not good for "Extend tool" in previous version.
      It was improved in this ver.
      Thanks.
      by TAK2HATA
      • sumasterS Offline
        sumaster
        @tak2hata said:
        Hi,All.
        v1.2:2012.09.17:
        Thanks.
        Hi Tak2hata
        Thanks you πŸ‘ πŸ˜‰
        And I'm CHKing Now
        @tak2hata said:
        Hi,Sumaster.
        Thanks.
        Oh. . . .
        and here the new tool get random color
        how i fix the color means ( Walls get White, Steel Member get Medium Red, . . etc )
        Thank you,
        SUmaster
          tak2hata
          Hi,all.
          I attach CTMan's UK Steel pflist file on top of this thread.
          It will helps Building structure tool users.
          Thanks.
          by TAK2HATA
            SUFractal
            I just upgraded to the latest version, but am no longer able to access "steel columns" in the North American List? Other elements appear to work fine.
              tak2hata
              Hi,Sufractal.
              In my enviroment,"Steel Column" shown from "North American pflist" no problem.
              Check the line include "##" in the csv file, If you edited it.
              "##STEEL_COLUMN" is needed.
              so, send to me your profile list or upload here it.
              and I will look it.
              Thanks.
              by TAK2HATA
              • sumasterS Offline
                sumaster
                HI ,
                How i fix the color of BST wall . . . ?
                now its get random color . . .
                Thank you,
                SUmaster
                  SUFractal
                  @tak2hata said:
                  Hi,Sufractal.
                  and I will look it.
                  Thanks.
                  i believe I used the correct text in the file?
                    tak2hata
                    @sufractal said:
                    @tak2hata said:
                    Hi,Sufractal.
                    and I will look it.
                    Thanks.
                    I tested it working fine.
                    Steel Column shown fine.
                    I judge that it is fine by looking only that picture.
                    The last advice I say is "Change Profile list path" and select it again.
                    The information about this problem is too small.
                    Is there anyone had same problem?
                    and please reply here.
                    Thanks.
                    by TAK2HATA
                    • H Offline
                      hygicell
                      excellent tool, but not (yet) working for me:
                      I cannot find an installation manual
                      nor a user manual
                      and where do I put the .csv files?
                      please help
                      Frank
                      • MasterhandM Offline
                        Masterhand
                        Excellent tool. I worked great.
                        Does anyone know if there is a plugin that allows easily verify whether a modulation structure, or structure, if feasible or still standing?.
                        To just have a quick overview or a quick sample of what model can work it without having to do the entire calculation of the structure (which will be done later).
                        So, I mean, for example: look, without calculating it yet, I can show that it may be feasible or holds
                          tak2hata
                          nor a user manual
                          please help
                          Frank
                          Hi, hygicell.
                          Please puts ".csv"file to folder you like.but windows special folder is not recommended.
                          The windows special folder is like "C:\program files" "C:\Windows".
                          Mac user do not mind this.
                          After puts it,You must "Change profile list path" from plugins menu.
                          and select the file.
                          Hi,Mastarhand.
                          Me,too.
                          Hi,all.
                          I will update this script after few days.
                          Thanks.
                          by TAK2HATA
                            tak2hata
                            I update to version 1.4beta.
                            I add usefull function "Table Editor".
                            and improves.
                            enjoy. πŸ˜„
                            by TAK2HATA
                            • sumasterS Offline
                              sumaster
                              Hello Tak2hata,
                              1st Thank you. Its too good and very useful . . . . πŸ‘ πŸ˜„ πŸ˜„
                              Nice one UPDATE Query Attributes and Table Editor
                              ****** CHK the Axies locking
                              when draw 1st time its work perfectly
                              but 2nd time not working
                              ****** CHK the Grow To Face tool
                              Select the object and use the Grow To Face tool . . .
                              and select the ground NOT WORKING . . . .
                              Here it is SKP File
                              123 .skp
                              Thank you,
                              SUmaster
                                tulacong
                                thank you...thank you ....oh zeeee
                                  tak2hata
                                  Hi,tulacong.
                                  I am happy for your word!
                                  Hi,SUMASTER.
                                  I will improve it and update it after two weeks.
                                  Thnx. πŸ˜‰
                                  by TAK2HATA
                                  • V Offline
                                    victor hugo
                                    Hello.
                                    My MWALL is not working, is on the list but it does not work, has any one had this problem too?
                                      tak2hata
                                      Hello.
                                      Hi ,HUGO.
                                      I knew it and "SHAPES" class ,too.
                                      I have small time ,so I will update in head of next week.
                                      Please wait.
                                      by TAK2HATA
                                      • maxmarjamaaM Offline
                                        maxmarjamaa
                                        Thanks you! β˜€
                                          tak2hata
                                          I update to version1.5 in Oct 28,2012.
                                          Bugfix and Improves.
                                          1. inference axes.
                                          2. extending with already selected single entity.
                                          3. query attributes.
                                          4. Work well about MWALLS and SHAPES.
                                          Next update will take more than 2 weeks.
                                          Thanks.
                                          by TAK2HATA
                                          • sumasterS Offline
                                            sumaster
                                            HI tak2hata,
                                            Please chk this . . . .
                                            1st create the L type wall and applying the Set Axis Point tool (thomthom Sir tool)
                                            http://sketchucation.com/forums/viewtopic.php?t=30508
                                            and click APPLY ALL button . . . . .
                                            This is the Final Result . . . .
                                            another way is you can create the mark button . . .
                                            Sketchup File :
                                            Align SKP File.skp
                                            THanks πŸ‘ πŸ‘
                                            Thank you,
                                            SUmaster
                                            • 16
                                            • 17
                                            • 7 / 17
