    [Plugin] Stair Maker
    110 Posts 37 Posters 121.6k Views 37 Watching
    • dereiD Offline
      derei
      Please explain each input element, for who has no specialized terms knowledge
      For example, what is Risers2Landing? or Gap Run2Run, Step Depth, Riser Height,Tread Depth and so on...
      Thank you very much.
      • sdmitchS Offline
        sdmitch
        Risers2Landing is the number of steps or risers going up to the landing of a U-shape stair.
        Gap Run2Run is the space between the sets of stairs in a U-shape stair.
        Step Depth is the front to back dimension of each step.
        Riser Height is the vertical distance between each step.
        Tread Depth is the thickness of the individual steps.
        http://sdmitch.blogspot.com/
        • utilerU Offline
          utiler
          @utiler said:
          @utiler said:
          Ok, the last post was sent at 2am this morning on my iPad so I didn't have the option to run the plugin....
          Sam, I wasn't aware you weren't in the industry so here's a quick glossary of terms which I expect is pretty universal.
          I've chosen to make an example of the U-shape in-situ stair as it covers most terms.
          [attachment=0:2etuiebv]<!-- ia0 -->Stairmaker.png<!-- ia0 -->[/attachment:2etuiebv]
          My crude attempt at a Dialogue Box
          Stair Width: 2600
          Stair Height: 3900
          Flight 1 Width: 1200
          Flight 2 Width: 1200
          Tread Depth: 275
          Total No. or Risers: 24
          Riser Height: 162.5 [I expect this is a system variable that changes as No. of Riser input is changed. This gives the user a visual guide as to their final stair ratio...]
          No. risers to Landing: 12 [this locates the landing in the overall flight...]
          Rail Height: 900
          Rail Offset: 50
          Sam, Any chance of looking into this I posted a while back...?
          Many thanks, Andrew
          Sam?
          Just Curious...
          • sdmitchS Offline
            sdmitch
            U, it is a little more than just changing the labels in the inputbox. Allowing a variable number of steps to/from the landing of U-shape stairs would require extensive re-write.
            • utilerU Offline
              utiler
              Thanks Sam, thought it was worth asking anyway....
              Just Curious...
                AlainBo
                Hello,
                It could be interesting to be able to create L shape also.
                Regards,
                Alain
                • sdmitchS Offline
                  sdmitch
                  Hello,
                  Regards,
                  Alain
                  That might be a simple add. I'll give it some thought.
                  • sdmitchS Offline
                    sdmitch
                    Hello,
                    Regards,
                    Alain
                    Alain, The L shape option has been added.
                    • guanjinG Offline
                      guanjin
                      sdmitch:Hello
                      What is the above parameters, why no change。
                      L-shaped and U-shaped running very slow。
                      The previous version,Normal。
                      The ladder can not be changed to a pipe or a rectangle, the only line.
                        AlainBo
                        Cool,
                        thanks sdmitch
                        • charly2008C Offline
                          charly2008
                          Hi sdmitch,
                          thanks for the extension.
                          Charly
                            luhrzeznik
                            Hi, I'm having a bit of trouble here!
                            I used the plugin once and it worked fine. But when I tried to use it again, it doesn't get past the Stair Type. I click my option and the screen just disappear and then nothing. Do you have any idea why that could be happening?
                            • sdmitchS Offline
                              sdmitch
                              I assume this happens regardless of which stair option is selected?
                              Locate and delete the Stair Maker.txt file and try the plugin again.
                              What Units system are you using, 1.00 or 1,00?
                                lexje
                                Thanks for the tool!
                                I've been looking around for stair plug ins but could not find many. (1001bit but it does not contain L-shaped or quarter-turn stairs)
                                TIG,would you mind posting some links to the plug-ins you referenced?
                                Thanks a lot!
                                Erwin
                                  A simple SCF Search http://sketchucation.com/forums/searchgoogle.php?keyword=stair+plugin returns 430 hits!
                                  This thread is ~1 year old...
                                  There are new stair tools on the block...
                                  Look at...
                                  http://www.youtube.com/watch?v=PMWwlmsmNAs
                                  http://sketchucation.com/forums/viewtopic.php?p=509033#p509033 [links off to http://cabmaker32.com/?s=stair%26amp;submit=Go ]
                                  • H Offline
                                    hajasulthan
                                    its not working in sketchup 2013
                                      How is it not working?
                                      A few more details would help us help you...
                                      Your User-Profile says you are using v8, but you speak of v2013, when the latest version available is v2014... and also what OS are you now using?
                                      How did you install this, exactly?
                                      From RBZ+Install-button, from the PluginStore, copied from an older PLugins folder, manually from RBZ>ZIP etc ???
                                      Do you have FULL security permissions to your version's Plugins folder? [important if <v2014]
                                      etc.
                                      Are there errors when SketchUp loads?
                                      Is this tool in the menu?
                                      If it runs what error messages do you get?
                                      What shows in the Ruby Console when you run it?
                                      Do you get a BugSplat?
                                      etc..
                                      etc...
                                      We are not psychics...
                                      • H Offline
                                        hajasulthan
                                        thank you for reply am using su 2013 , i don't find any problem when its loading, but check through ruby console as below.
                                        Error: #<Errno::EACCES: Permission denied - C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.txt>
                                        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:295:in initialize' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:295:in open'
                                        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:295:in put_defaults' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:96:in reset'
                                        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:68:in initialize' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:25:in new'
                                        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:295:in `call'
                                        how to fix this?
                                        thank you
                                          The first line is the clue:
                                          You do not have full permission to your Plugins folder and its contents, and this particular tool makes use of a txt file kept inside that folder-tree.
                                          In PC v2014 there is no problem, because you get FULL permissions by default, but earlier PC versions put the Plugins folder within the ../Programs Files/..SketchUp folder and Windows limits your access, unless you change it manually.
                                          Read this tutorial and reset your Plugins folder's permissions to FULL - ensure all of the contents get the FULL permissions too...
                                          http://sketchucation.com/resources/tutorials/36-intermediate/811-setting-security-permissions-in-sketchup
                                            cboy1980
                                            I have the same problem here...
                                            Try to make a L-shaped stair... but after putting the measurements in the dialog box and clicking ok... nothing happens. The dialog box just dissapears. That's it. No stairs to see.
                                            Grtz
                                            cboy
                                            • 4 / 6
