    [Plugin] Stair Maker
    110 Posts 37 Posters 128.8k Views 37 Watching
    • utilerU
      utiler
      Thanks Sam, thought it was worth asking anyway....
      Just Curious...
        AlainBo
        Hello,
        It could be interesting to be able to create L shape also.
        Regards,
        Alain
        • sdmitchS
          sdmitch
          Hello,
          Regards,
          Alain
          That might be a simple add. I'll give it some thought.
          http://sdmitch.blogspot.com/
          • sdmitchS
            sdmitch
            Hello,
            Regards,
            Alain
            Alain, The L shape option has been added.
            • guanjinG
              guanjin
              sdmitch:Hello
              What is the above parameters, why no change。
              L-shaped and U-shaped running very slow。
              The previous version,Normal。
              The ladder can not be changed to a pipe or a rectangle, the only line.
                AlainBo
                Cool,
                thanks sdmitch
                • charly2008C
                  charly2008
                  Hi sdmitch,
                  thanks for the extension.
                  Charly
                  • L
                    luhrzeznik
                    Hi, I'm having a bit of trouble here!
                    I used the plugin once and it worked fine. But when I tried to use it again, it doesn't get past the Stair Type. I click my option and the screen just disappear and then nothing. Do you have any idea why that could be happening?
                    • sdmitchS
                      sdmitch
                      I assume this happens regardless of which stair option is selected?
                      Locate and delete the Stair Maker.txt file and try the plugin again.
                      What Units system are you using, 1.00 or 1,00?
                      • L
                        lexje
                        Thanks for the tool!
                        I've been looking around for stair plug ins but could not find many. (1001bit but it does not contain L-shaped or quarter-turn stairs)
                        TIG,would you mind posting some links to the plug-ins you referenced?
                        Thanks a lot!
                        Erwin
                          A simple SCF Search http://sketchucation.com/forums/searchgoogle.php?keyword=stair+plugin returns 430 hits!
                          This thread is ~1 year old...
                          There are new stair tools on the block...
                          Look at...
                          http://www.youtube.com/watch?v=PMWwlmsmNAs
                          http://sketchucation.com/forums/viewtopic.php?p=509033#p509033 [links off to http://cabmaker32.com/?s=stair%26amp;submit=Go ]
                          • H
                            hajasulthan
                            its not working in sketchup 2013
                              How is it not working?
                              A few more details would help us help you...
                              Your User-Profile says you are using v8, but you speak of v2013, when the latest version available is v2014... and also what OS are you now using?
                              How did you install this, exactly?
                              From RBZ+Install-button, from the PluginStore, copied from an older PLugins folder, manually from RBZ>ZIP etc ???
                              Do you have FULL security permissions to your version's Plugins folder? [important if <v2014]
                              etc.
                              Are there errors when SketchUp loads?
                              Is this tool in the menu?
                              If it runs what error messages do you get?
                              What shows in the Ruby Console when you run it?
                              Do you get a BugSplat?
                              etc..
                              etc...
                              We are not psychics...
                              • H
                                hajasulthan
                                thank you for reply am using su 2013 , i don't find any problem when its loading, but check through ruby console as below.
                                Error: #<Errno::EACCES: Permission denied - C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.txt>
                                C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:295:in initialize' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:295:in open'
                                C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:295:in put_defaults' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:96:in reset'
                                C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:68:in initialize' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:25:in new'
                                C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:295:in `call'
                                how to fix this?
                                thank you
                                  The first line is the clue:
                                  You do not have full permission to your Plugins folder and its contents, and this particular tool makes use of a txt file kept inside that folder-tree.
                                  In PC v2014 there is no problem, because you get FULL permissions by default, but earlier PC versions put the Plugins folder within the ../Programs Files/..SketchUp folder and Windows limits your access, unless you change it manually.
                                  Read this tutorial and reset your Plugins folder's permissions to FULL - ensure all of the contents get the FULL permissions too...
                                  http://sketchucation.com/resources/tutorials/36-intermediate/811-setting-security-permissions-in-sketchup
                                  • C
                                    cboy1980
                                    I have the same problem here...
                                    Try to make a L-shaped stair... but after putting the measurements in the dialog box and clicking ok... nothing happens. The dialog box just dissapears. That's it. No stairs to see.
                                    Grtz
                                    cboy
                                    • KrisidiousK
                                      Krisidious
                                      Thanks for updating this Mitch...
                                      By: Kristoff Rand
                                      • sdmitchS
                                        sdmitch
                                        Grtz
                                        cboy
                                        After clicking OK, you need to pick the model point to locate where the stairs are to originate. You should see a red "+" at the end of the mouse pointer.
                                        • C
                                          cboy1980
                                          Grtz
                                          cboy
                                          Hey I still have no stair appearing... not even the red cross at the pointer.
                                          Even when clicking somewhere it does not happen.
                                          Grtz.
                                          cboy
                                          • sdmitchS
                                            sdmitch
                                            You may need to download a new copy since this plugin was recently modified to be 2014 compliant.
                                            Otherwise, open the Ruby Console window and execute the plugin to see what if any errors occur.
                                            • 4 / 6
