    [Plugin] Stair Maker
    110 Posts 37 Posters 126.2k Views 37 Watching
      rv1974
      @tig said:
      @rv1974 said:
      There must be ability to set up the net gap between railing posts .
      But that's a 'balustrade' tool not a stair tool ?
      The 4"/100mm sphere gap rule will then apply too...
      This plug-in generates some kind of primitive railing&posts system doesn't it?
      My local safety regulations demand <= 10cm net gap between posts so getting it automatically (not through additional plugins) would be really great.
      • sdmitchS Offline
        sdmitch
        Yes, the railing and post system is premitive but I never intended it to be more and my intentions have not changed.
        http://sdmitch.blogspot.com/
        • utilerU Offline
          utiler
          @utiler said:
          Ok, the last post was sent at 2am this morning on my iPad so I didn't have the option to run the plugin....
          Sam, I wasn't aware you weren't in the industry so here's a quick glossary of terms which I expect is pretty universal.
          I've chosen to make an example of the U-shape in-situ stair as it covers most terms.
          [attachment=0:263t8gtv]<!-- ia0 -->Stairmaker.png<!-- ia0 -->[/attachment:263t8gtv]
          My crude attempt at a Dialogue Box
          Stair Width: 2600
          Stair Height: 3900
          Flight 1 Width: 1200
          Flight 2 Width: 1200
          Tread Depth: 275
          Total No. or Risers: 24
          Riser Height: 162.5 [I expect this is a system variable that changes as No. of Riser input is changed. This gives the user a visual guide as to their final stair ratio...]
          No. risers to Landing: 12 [this locates the landing in the overall flight...]
          Rail Height: 900
          Rail Offset: 50
          Sam, Any chance of looking into this I posted a while back...?
          Many thanks, Andrew
          Just Curious...
          • dereiD Offline
            derei
            Please explain each input element, for who has no specialized terms knowledge
            For example, what is Risers2Landing? or Gap Run2Run, Step Depth, Riser Height,Tread Depth and so on...
            Thank you very much.
            DESIGNER AND ARTIST DEREI.UK
            • sdmitchS Offline
              sdmitch
              Risers2Landing is the number of steps or risers going up to the landing of a U-shape stair.
              Gap Run2Run is the space between the sets of stairs in a U-shape stair.
              Step Depth is the front to back dimension of each step.
              Riser Height is the vertical distance between each step.
              Tread Depth is the thickness of the individual steps.
              • utilerU Offline
                utiler
                [attachment=0:2etuiebv]<!-- ia0 -->Stairmaker.png<!-- ia0 -->[/attachment:2etuiebv]
                Stair Width: 2600
                Stair Height: 3900
                Tread Depth: 275
                Rail Height: 900
                Rail Offset: 50
                Many thanks, Andrew
                Sam?
                Just Curious...
                • sdmitchS Offline
                  sdmitch
                  U, it is a little more than just changing the labels in the inputbox. Allowing a variable number of steps to/from the landing of U-shape stairs would require extensive re-write.
                  • utilerU Offline
                    utiler
                    Thanks Sam, thought it was worth asking anyway....
                    Just Curious...
                      AlainBo
                      Hello,
                      It could be interesting to be able to create L shape also.
                      Regards,
                      Alain
                      • sdmitchS Offline
                        sdmitch
                        Hello,
                        Regards,
                        Alain
                        That might be a simple add. I'll give it some thought.
                        • sdmitchS Offline
                          sdmitch
                          Hello,
                          Regards,
                          Alain
                          Alain, The L shape option has been added.
                          • guanjinG Offline
                            guanjin
                            sdmitch:Hello
                            What is the above parameters, why no change。
                            L-shaped and U-shaped running very slow。
                            The previous version,Normal。
                            The ladder can not be changed to a pipe or a rectangle, the only line.
                              AlainBo
                              Cool,
                              thanks sdmitch
                              • charly2008C Offline
                                charly2008
                                Hi sdmitch,
                                thanks for the extension.
                                Charly
                                  luhrzeznik
                                  Hi, I'm having a bit of trouble here!
                                  I used the plugin once and it worked fine. But when I tried to use it again, it doesn't get past the Stair Type. I click my option and the screen just disappear and then nothing. Do you have any idea why that could be happening?
                                  • sdmitchS Offline
                                    sdmitch
                                    I assume this happens regardless of which stair option is selected?
                                    Locate and delete the Stair Maker.txt file and try the plugin again.
                                    What Units system are you using, 1.00 or 1,00?
                                      lexje
                                      Thanks for the tool!
                                      I've been looking around for stair plug ins but could not find many. (1001bit but it does not contain L-shaped or quarter-turn stairs)
                                      TIG,would you mind posting some links to the plug-ins you referenced?
                                      Thanks a lot!
                                      Erwin
                                        A simple SCF Search http://sketchucation.com/forums/searchgoogle.php?keyword=stair+plugin returns 430 hits!
                                        This thread is ~1 year old...
                                        There are new stair tools on the block...
                                        Look at...
                                        http://www.youtube.com/watch?v=PMWwlmsmNAs
                                        http://sketchucation.com/forums/viewtopic.php?p=509033#p509033 [links off to http://cabmaker32.com/?s=stair%26amp;submit=Go ]
                                        • H Offline
                                          hajasulthan
                                          its not working in sketchup 2013
                                            How is it not working?
                                            A few more details would help us help you...
                                            Your User-Profile says you are using v8, but you speak of v2013, when the latest version available is v2014... and also what OS are you now using?
                                            How did you install this, exactly?
                                            From RBZ+Install-button, from the PluginStore, copied from an older PLugins folder, manually from RBZ>ZIP etc ???
                                            Do you have FULL security permissions to your version's Plugins folder? [important if <v2014]
                                            etc.
                                            Are there errors when SketchUp loads?
                                            Is this tool in the menu?
                                            If it runs what error messages do you get?
                                            What shows in the Ruby Console when you run it?
                                            Do you get a BugSplat?
                                            etc..
                                            etc...
                                            We are not psychics...
                                            • 4 / 6
