    [Plugin] Stair Maker
    110 Posts 37 Posters 119.5k Views 37 Watching
    • utilerU Offline
      utiler
      @utiler said:
      @utiler said:
      Ok, the last post was sent at 2am this morning on my iPad so I didn't have the option to run the plugin....
      Sam, I wasn't aware you weren't in the industry so here's a quick glossary of terms which I expect is pretty universal.
      I've chosen to make an example of the U-shape in-situ stair as it covers most terms.
      [attachment=0:2etuiebv]<!-- ia0 -->Stairmaker.png<!-- ia0 -->[/attachment:2etuiebv]
      My crude attempt at a Dialogue Box
      Stair Width: 2600
      Stair Height: 3900
      Flight 1 Width: 1200
      Flight 2 Width: 1200
      Tread Depth: 275
      Total No. or Risers: 24
      Riser Height: 162.5 [I expect this is a system variable that changes as No. of Riser input is changed. This gives the user a visual guide as to their final stair ratio...]
      No. risers to Landing: 12 [this locates the landing in the overall flight...]
      Rail Height: 900
      Rail Offset: 50
      Sam, Any chance of looking into this I posted a while back...?
      Many thanks, Andrew
      Sam?
      Just Curious...
      • sdmitchS Offline
        sdmitch
        U, it is a little more than just changing the labels in the inputbox. Allowing a variable number of steps to/from the landing of U-shape stairs would require extensive re-write.
        http://sdmitch.blogspot.com/
        • utilerU Offline
          utiler
          Thanks Sam, thought it was worth asking anyway....
          Just Curious...
            AlainBo
            Hello,
            It could be interesting to be able to create L shape also.
            Regards,
            Alain
            • sdmitchS Offline
              sdmitch
              Hello,
              Regards,
              Alain
              That might be a simple add. I'll give it some thought.
              • sdmitchS Offline
                sdmitch
                Hello,
                Regards,
                Alain
                Alain, The L shape option has been added.
                • guanjinG Offline
                  guanjin
                  sdmitch:Hello
                  What is the above parameters, why no change。
                  L-shaped and U-shaped running very slow。
                  The previous version,Normal。
                  The ladder can not be changed to a pipe or a rectangle, the only line.
                    AlainBo
                    Cool,
                    thanks sdmitch
                    • charly2008C Offline
                      charly2008
                      Hi sdmitch,
                      thanks for the extension.
                      Charly
                        luhrzeznik
                        Hi, I'm having a bit of trouble here!
                        I used the plugin once and it worked fine. But when I tried to use it again, it doesn't get past the Stair Type. I click my option and the screen just disappear and then nothing. Do you have any idea why that could be happening?
                        • sdmitchS Offline
                          sdmitch
                          I assume this happens regardless of which stair option is selected?
                          Locate and delete the Stair Maker.txt file and try the plugin again.
                          What Units system are you using, 1.00 or 1,00?
                            lexje
                            Thanks for the tool!
                            I've been looking around for stair plug ins but could not find many. (1001bit but it does not contain L-shaped or quarter-turn stairs)
                            TIG,would you mind posting some links to the plug-ins you referenced?
                            Thanks a lot!
                            Erwin
                              A simple SCF Search http://sketchucation.com/forums/searchgoogle.php?keyword=stair+plugin returns 430 hits!
                              This thread is ~1 year old...
                              There are new stair tools on the block...
                              Look at...
                              http://www.youtube.com/watch?v=PMWwlmsmNAs
                              http://sketchucation.com/forums/viewtopic.php?p=509033#p509033 [links off to http://cabmaker32.com/?s=stair%26amp;submit=Go ]
                              • H Offline
                                hajasulthan
                                its not working in sketchup 2013
                                  How is it not working?
                                  A few more details would help us help you...
                                  Your User-Profile says you are using v8, but you speak of v2013, when the latest version available is v2014... and also what OS are you now using?
                                  How did you install this, exactly?
                                  From RBZ+Install-button, from the PluginStore, copied from an older PLugins folder, manually from RBZ>ZIP etc ???
                                  Do you have FULL security permissions to your version's Plugins folder? [important if <v2014]
                                  etc.
                                  Are there errors when SketchUp loads?
                                  Is this tool in the menu?
                                  If it runs what error messages do you get?
                                  What shows in the Ruby Console when you run it?
                                  Do you get a BugSplat?
                                  etc..
                                  etc...
                                  We are not psychics...
                                  • H Offline
                                    hajasulthan
                                    thank you for reply am using su 2013 , i don't find any problem when its loading, but check through ruby console as below.
                                    Error: #<Errno::EACCES: Permission denied - C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.txt>
                                    C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:295:in initialize' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:295:in open'
                                    C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:295:in put_defaults' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:96:in reset'
                                    C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:68:in initialize' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:25:in new'
                                    C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/Stair Maker.rb:295:in `call'
                                    how to fix this?
                                    thank you
                                      The first line is the clue:
                                      You do not have full permission to your Plugins folder and its contents, and this particular tool makes use of a txt file kept inside that folder-tree.
                                      In PC v2014 there is no problem, because you get FULL permissions by default, but earlier PC versions put the Plugins folder within the ../Programs Files/..SketchUp folder and Windows limits your access, unless you change it manually.
                                      Read this tutorial and reset your Plugins folder's permissions to FULL - ensure all of the contents get the FULL permissions too...
                                      http://sketchucation.com/resources/tutorials/36-intermediate/811-setting-security-permissions-in-sketchup
                                        cboy1980
                                        I have the same problem here...
                                        Try to make a L-shaped stair... but after putting the measurements in the dialog box and clicking ok... nothing happens. The dialog box just dissapears. That's it. No stairs to see.
                                        Grtz
                                        cboy
                                        • KrisidiousK Offline
                                          Krisidious
                                          Thanks for updating this Mitch...
                                          By: Kristoff Rand
                                          • sdmitchS Offline
                                            sdmitch
                                            Grtz
                                            cboy
                                            After clicking OK, you need to pick the model point to locate where the stairs are to originate. You should see a red "+" at the end of the mouse pointer.
                                            • 4 / 6
