    [Plugin] TT_Lib²
    310 Posts 66 Posters 486.2k Views 66 Watching
    • P
      pololo
      @thomthom said:
      @pololo said:
      Excellent Thom!!! 👍 👍 👍 I hope the next update includes icons, it would be great! 😉
      For what plugin?
      Sorry thom, I was wrong, that post was for Guide Tools.... 😒
      • H
        hygicell
        Hello Thomas,
        I can't seem to get the installation right
        these are the errror messages
        in 3 sequences,
        Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/bim-tools/clsBtEntity.rb
        undefined local variable or method `' for #<Object:0x3d2618c @cmd=#UI::Command:0xf857c30>Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_edgetools - 2.0.4/TT_EdgeTools/core.rb
        no such file to load -- TT_Lib2/core.rbError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_edgetools - 2.0.4/tt_edgetools.rb
        no such file to load -- TT_Lib2/core.rbError Loading File tt_cleanup.rb
        no such file to load -- TT_Lib2/core.rbError Loading File tt_guide_tools.rb
        no such file to load -- TT_Lib2/core.rbError Loading File tt_layer.rb
        no such file to load -- TT_Lib2/core.rbError Loading File tt_plan_tools.rb
        no such file to load – TT_Lib2/core.rb
        after I thought to understand that TT_Lib2 folder should be directly in the plugins folder I copied it there (not move)
        new error messages:
        undefined local variable or method `' for main:ObjectError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_edgetools - 2.0.4/TT_EdgeTools/core.rb
        no such file to load – TT_EdgeTools/divider.rb
        after I thought to understand that TT_EdgeTools folder should be directly in the plugins folder I copied it there (not move)
        new error messages:
        Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/close_gaps.rb
        uninitialized constant TTError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/core.rb
        uninitialized constant TT::Plugins::EdgeTools::PREF_KEYError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/divider.rb
        undefined method add_item' for nil:NilClassError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/make_colinear.rb undefined method add_separator' for nil:NilClassError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/simplify.rb
        undefined method add_separator' for nil:NilClassError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/bim-tools/clsBtEntity.rb undefined local variable or method ' for main:Object
        it might be that the fact that I copied and not moved the folders is causing the problems
        please help
        Frank
          Can you show a screenshot of your Plugins folder?
          The errors are odd, because they reference another plugin 'BIM Tools'.
            Looking at the error messages I'm pretty sure the plugins are not installed correctly.
            You can either go back to the description of the plugins and very closely check the footprint examples, or you can remove the plugins you installed and install them with this utility: http://forums.sketchucation.com/viewtopic.php?t=42315
            That is just one single .rb file you place in the Plugins folder, and then you get menu items to install other plugins, be it .rb, .rbs, .zip or .rbz.
            (If you want to use the manual route I recommend you read through this article that breaks down plugin installation: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/)
            • N
              nektares
              hey Thomas! i don´t know why but karspersky confused an element of your library with malicious software, i added it to the exclusions because every time i reinstalled it the same warning was displayed. Maybe some over careful kaspersky update caused it!
              http://i249.photobucket.com/albums/gg239/nektares/Irrelephant/ttapi.jpg
                I don't know why Kaspersky blocked it. I've never used that AV. Did you just update it?
                This is the first time anyone has reported the file being blocked by any AV. (And we have a very agressive AV at work - not even that triggered it.)
                Regardless - the file is harmless. It's a false positive.
                • N
                  nicasiojoel
                  Yes, that's true. thanks for reporting this. I thought I was the only one affected. After updating my Kaspersky lately, ttguide, ttedge, ttcleanup's icon was gone in sketchup and some error appeared on screen.
                    Sigh Now there'll be a flood of Kaspersky support queries.
                    Tell Kaspersky to ignore tt_api.so. And are you able to report back to the developers of KAspersky about false positives?
                    There is really nothing I can do here. It's Kaspersky being over-zealous.
                      http://forum.kaspersky.com/index.php?showtopic=242725
                      Also, license holders should submit their false positives and samples via My Kaspersky or Personal Cabinet, instead of newvirus.
                      • N
                        nektares
                        In fact you have to add the whole SketchUp folder to the exclusions to be sure, I will report it Thomas. silly Kaspersky.
                          Thank you.
                          • N
                            nektares
                            done! let´s hope they fix it soon!
                            http://i249.photobucket.com/albums/gg239/nektares/Irrelephant/report.jpg
                              • H
                                hygicell
                                Hello Thomthom,
                                upon my first try, I recieved the following error messages:
                                Error Loading File tt_bitmap2mesh.rb
                                I checked and realised TT_Lib2 was not directly in the plugins folder, but in a subfolder TT_Lib2 2.6.0 (or similar name, I did not write it down)
                                I moved the TT_Lib2 folder to the plugins folder and erased the TT_Lib2 2.6.0 or similar name, I did not write it down
                                now I get other error messages:
                                no such file to load -- C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/libraries/win32/tt_apiError Loading File tt_cleanup.rb
                                no such file to load -- C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Lib2/libraries/win32/tt_apiError Loading File tt_guide_tools.rb
                                I checked, and in
                                there is a tt_api-readme file, not an actual tt_api file
                                please help
                                Frank
                                  Check you Plugins folder has FULL security Permissions set under Properties.
                                  Your system might not be allowing all files to be properly installed by you [even if you're an an Admin] - so give yourself FULL rights.
                                  A link button near the top of the Plugins folder's Explorer Window saying something like 'Compatibility Files...' is a clear indicator of issues with your systems settings...
                                  Ensure it's right and then continue...
                                  Note that the same rights should pertain on the Materials, Components and Styles folders, because one day you will want to write to those too...
                                  Why not remove the suspect subfolder/files and get thomthom's Simple Installer from the Plugins Index, install that and then restart and use it to install the files/subfolders from the zip file automatically - that way you won't get into a tangle with mis-installed files etc...
                                    I checked, and in
                                    I'm guessing you have Kaspersky installed - and it recently updated?
                                    For some reason the latest update removes the tt_api.so file. You need to tell Kaspersky to leave it alone. And please report the false positive to Kaspersky so they can correct this. The more that reports it the quicker we can hopefully see a fix.
                                    You're not the only one: http://sketchucation.com/forums/viewtopic.php?f=323&t=30503&start=60#p432963
                                    • H
                                      hygicell
                                      I checked, and in
                                      indeed, Kapersky, but apparently they have solved the problem:
                                      upon deleting and reinstalling TTlib with your installer, the previous errors disappeared
                                      I checked, the file is in place
                                      and this time no alarm from Kapersky
                                      now I had other error messages:
                                      Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_Vertex/loader.rb
                                      uninitialized constant TT_Vertex
                                      so I deleted TT vertex, and used again your installer to install it again
                                      but the problem stays:
                                      • H
                                        hygicell
                                        by the way, many thanks for your fabulous plugins
                                        Frank
                                          What OS do you have?
                                          Do you have Vista or Win7?
                                          Could there perhaps be some files that's ended up in virtualstore? (Do you see a Compatibility Files button in Explorer when you view the content of your Plugins folder?)
                                          Can you post a screenshot of the content of your plugins folder?
                                          The error message seem to indicate that TT_Vertex/loader.rb loads before tt_vertex.rb ... are you sure you haven't accidentally moved some files out of the TT_Vertex folder?
                                          Do you see a loader.rb file directly in your Plugins folder?
                                          • H
                                            hygicell
                                            win7 dutch language
                                            no compatibility files button as far as I can see
                                            only used your installer, did not move any files
                                            Kaspersky might still be the culprit:
                                            all of a sudden it again quarantained the other file
                                            • 15
                                            • 16
                                            • 4 / 16
