    [Plugin] TT_Lib²
    310 Posts 66 Posters 479.5k Views 66 Watching
      @angelorea_arq said:
      look
      Your profile says you use SU8, but exactly what version. The error was triggered in a part for SketchUp prior to SU8M1. Can you post your exact SketchUp version number in addition to the settings you used when you got the error?
        Version 2.6.0
        • LibFredo Update Checker support.
        • Lots of new features and fixes.
        Important!
        QuadFace Tools users need to update to this version!
          mamoune12345
          Hello
          Can you tell me please how can i install the TT lib on the sketchup ?
          Thank you and sorry for my english 😄
          • mitcorbM
            mitcorb
            Hi mamoune:
            Go to the first post in the thread. Right click on the file tt_lib.zip, Save Link as... and save it to your computer, say, Desktop. Unzip the files to your Sketchup Plugins subfolder. As ThomThom says, this is not a stand alone plugin. It is a reference file for his other plugins.
            • T
              trinhsongoku
              thank you man[quote]
              • P
                pololo
                Excellent Thom!!! 👍 👍 👍 I hope the next update includes icons, it would be great! 😉
                  For what plugin?
                  • E
                    exchange
                    Excelent Plugin,
                    Thank you very much! Saved me from a lot work cleaning up some Chairs from Bene.
                    Have a nice Weekend
                    Greetings form Austria
                    • P
                      pololo
                      @thomthom said:
                      For what plugin?
                      Sorry thom, I was wrong, that post was for Guide Tools.... 😒
                      • H
                        hygicell
                        Hello Thomas,
                        I can't seem to get the installation right
                        these are the errror messages
                        in 3 sequences,
                        Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/bim-tools/clsBtEntity.rb
                        undefined local variable or method `' for #<Object:0x3d2618c @cmd=#UI::Command:0xf857c30>Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_edgetools - 2.0.4/TT_EdgeTools/core.rb
                        no such file to load -- TT_Lib2/core.rbError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_edgetools - 2.0.4/tt_edgetools.rb
                        no such file to load -- TT_Lib2/core.rbError Loading File tt_cleanup.rb
                        no such file to load -- TT_Lib2/core.rbError Loading File tt_guide_tools.rb
                        no such file to load -- TT_Lib2/core.rbError Loading File tt_layer.rb
                        no such file to load -- TT_Lib2/core.rbError Loading File tt_plan_tools.rb
                        no such file to load – TT_Lib2/core.rb
                        after I thought to understand that TT_Lib2 folder should be directly in the plugins folder I copied it there (not move)
                        new error messages:
                        undefined local variable or method `' for main:ObjectError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_edgetools - 2.0.4/TT_EdgeTools/core.rb
                        no such file to load – TT_EdgeTools/divider.rb
                        after I thought to understand that TT_EdgeTools folder should be directly in the plugins folder I copied it there (not move)
                        new error messages:
                        Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/close_gaps.rb
                        uninitialized constant TTError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/core.rb
                        uninitialized constant TT::Plugins::EdgeTools::PREF_KEYError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/divider.rb
                        undefined method add_item' for nil:NilClassError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/make_colinear.rb undefined method add_separator' for nil:NilClassError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/simplify.rb
                        undefined method add_separator' for nil:NilClassError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/bim-tools/clsBtEntity.rb undefined local variable or method ' for main:Object
                        it might be that the fact that I copied and not moved the folders is causing the problems
                        please help
                        Frank
                          Can you show a screenshot of your Plugins folder?
                          The errors are odd, because they reference another plugin 'BIM Tools'.
                            Looking at the error messages I'm pretty sure the plugins are not installed correctly.
                            You can either go back to the description of the plugins and very closely check the footprint examples, or you can remove the plugins you installed and install them with this utility: http://forums.sketchucation.com/viewtopic.php?t=42315
                            That is just one single .rb file you place in the Plugins folder, and then you get menu items to install other plugins, be it .rb, .rbs, .zip or .rbz.
                            (If you want to use the manual route I recommend you read through this article that breaks down plugin installation: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/)
                            • N
                              nektares
                              hey Thomas! i don´t know why but karspersky confused an element of your library with malicious software, i added it to the exclusions because every time i reinstalled it the same warning was displayed. Maybe some over careful kaspersky update caused it!
                              http://i249.photobucket.com/albums/gg239/nektares/Irrelephant/ttapi.jpg
                                I don't know why Kaspersky blocked it. I've never used that AV. Did you just update it?
                                This is the first time anyone has reported the file being blocked by any AV. (And we have a very agressive AV at work - not even that triggered it.)
                                Regardless - the file is harmless. It's a false positive.
                                • N
                                  nicasiojoel
                                  Yes, that's true. thanks for reporting this. I thought I was the only one affected. After updating my Kaspersky lately, ttguide, ttedge, ttcleanup's icon was gone in sketchup and some error appeared on screen.
                                    Sigh Now there'll be a flood of Kaspersky support queries.
                                    Tell Kaspersky to ignore tt_api.so. And are you able to report back to the developers of KAspersky about false positives?
                                    There is really nothing I can do here. It's Kaspersky being over-zealous.
                                      http://forum.kaspersky.com/index.php?showtopic=242725
                                      Also, license holders should submit their false positives and samples via My Kaspersky or Personal Cabinet, instead of newvirus.
                                      • N
                                        nektares
                                        In fact you have to add the whole SketchUp folder to the exclusions to be sure, I will report it Thomas. silly Kaspersky.
                                          Thank you.
                                          • N
                                            nektares
                                            done! let´s hope they fix it soon!
                                            http://i249.photobucket.com/albums/gg239/nektares/Irrelephant/report.jpg
                                            • 15
                                            • 16
                                            • 4 / 16
