    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
      I still get an error.
      The error is because of the new SCF format, presumably the thread's code has changed... ๐Ÿ˜•
      Might it be TT's tools causing issues, rather than the updated Fredo tools.
      http://sketchucation.com/forums/viewtopic.php?p=358315#p358315
      Unfortunately the error message isn't very precise...
      ๐Ÿ˜’
        I did it just now. It worked fine for me but told me that 4.6c is out of date. It did that after I installed 4.6d.
          driven
          hi Fredo,
          all working on the mac, from London... john
          • fredo6F
            @mrossk said:
            Has anyone else successfully tried this? I just installed it, overwrote the exisitng files, and get the same error messages. Thank you,
            Michael
            When you call the CheckForUpdate dialog box (without updating), which version of LibFredo6 do you see ? LibFredo6 4.6c or LibFredo6 4.6d ?
              Mine says 4.6c NOT d...
              It's a clean install - I removed the old files/subfolder...
              LibFredo6.plugin says 4.6d in Plugins BUT 4.6c in the Lib subfolder !
                I get the same thing as TIG. After seeing it the first time, I removed the files and did a clean install.
                  driven
                  LibFredo6 4.6c 11 Jul 12 Info 4.6d 03 Oct 12
                  Update for fixing Check For Updates
                  pasted from dialog 'after' installing LibFredo6%204.6d%20-%2003%20Oct%2012
                    I copied the Plugins '.plugins' file into the Lib subfolder, overwriting the older one, and now it reports 4.6d in the checker dialog and all works fine !
                      So that .plugin file shouldn't have been outside the folder? This is the way the file looked when I opened it.
                      Easily moved, though.
                      Fixed.
                      • fredo6F
                        Did you come through a confirmation about "Thumb.db" when uzipping ?
                          driven
                          Moved the .plugin and all is fine...
                          it's a text file that just looks like a plugin on a mac, because of it's extension.
                            There is/was a 'Thumbs.db' in the subfolder within the zip BUT no issues with it's extraction. The .plugins inside the original zipped set is 4.6c NOT like the one in the zip [Plugins folder level] ?
                            As I said in the previous post, that leapfrogged this... copying the newer '4.6d' .plugins file into the subfolder makes it work fine ๐Ÿ˜•
                              mrossk
                              if I place the ".plugin" file inside the "LibFredo" subfolder it works. So thanks for that,
                              Michael
                              https://www.mkaplanfinefurniture.com/
                                Should the .plugins file be in the Plugins folder and/or in the LibFredo subfolder... ???
                                OR just in the subfolder ?
                                I don't see the Plugins located version in any of the earlier zip archives, except inside the subfolder...
                                The current version works fine IF the newer version .plugins file is only inside the subfolder, and NOT in the Plugins folder at all. โ˜€
                                • fredo6F
                                  TIG,
                                  For whatever reason, the LibFredo6.plugin file was not in the right place. It should be in LIBFREDO6_Dir_46 subfolder. This is the file I modified, as it holds the address of the Sketchucation web site for checking updates.
                                  I hopefully fixed that problem with LibFredo6 4.6e
                                  • fredo6F
                                    NEW RELEASE: LibFredo6 v4.6e - 03 Oct 12
                                    LibFredo6 4.6e is a minor release which essentially fixes a problem in the functionality "Check for Updates". The issues comes from the change in URL schema of the new SKetchucation web site.
                                    PS: there was a wrong manipulation with version 4.6d. One file (LibFredo6.plugin) was misplaced. So update with a clean version of LibFredo6 4.6e
                                      It's all fine now ๐Ÿ˜‰
                                      Presumably the unused/older "LibFredo6.plugins" file that is now left behind in the Plugins folder can be removed from there without any issues...
                                      The similar/newer file within the subfolder is the one doing the work ...
                                      • fredo6F
                                        Yes the LibFredo6.plugin file in the main Plugins directory is useless (and harmless). It can be safely removed.
                                          mwm5053
                                          Just updated to 4.6e and noticed I have 4-joint push pull files and 4- LibTraductor files are they needed ? or should I be deleting them before an update.
                                          2011 iMac
                                          SU 2015 Pro, 2017 Make
                                          V2 Twilight
                                          macOS Sierra 10.12.5
                                          • fredo6F
                                            How can you have 4 files? In which directories? Isn't it folders instead.
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 115
                                            • 116
                                            • 23 / 116
