    VRAY render not working
    renderpluginsextensions
    36 Posts 12 Posters 32.0k Views 12 Watching
      What version do you use? The latest is version 1.49.01
      Does it happen on all models? Or just the one?
        candy1992
        Hi, Yes that's the version I have
          And my other questions? (More info is needed in order to provide help.)
          For instance - if it's the one model, maybe it's a big model and it needs to process for a while. How long have you waited?
            candy1992
            Its a very basic model, before when it was working it took about 2 minutes to render and i just change the view slightly and it didn't work.
            And its been an hour that ive been trying
            I just tried another model and it worked.
            • andybotA Offline
              andybot
              ❓ do you have displacement on any materials? The viewpoint can dramatically change the amount of processing needed for a material with displacement, especially if it's a metarial on a large plane.
                If you open the Ruby Console before rendering - do you get error messages?
                • N Offline
                  nitav
                  Welcome to my new post about the solution for the bug Vray and Sketchup.
                  This is really a badly rarely statement that sketchup is on high with the Modeling section & User friendly fast relaible 3D software.But only it is on low with the rendering section.Ya, i am going say that it is very bad for the Thread Optimization of the C.P.U, so it consist of 1 giant negative point.
                  O.K. lets talk about the solution.!!!
                  Many questions i found similar to this bug on various website but, all were possibly not solved.
                  And in answer to this question, you will get :-
                  1).  have you tried refreshing?
                  2).  try this: selecting all objects then copy open new file then paste then then render.
                  3).  Hide some elements & components.
                  4).  Bla, Bla, Bla .........
                  Well, I have the solution and that is very simple :-
                  ~ Explode components in your scene as much as possible while rendering the scene.
                  Means : If you are modeling or importing 3D objects to sketchup file,make sure that it
                  should not be in deep. Do not make components under components or Groups under
                  groups. Upto Level 1 to 2, it is enough but do not go beyond that. It is recommended
                  to get rid off this BUG..!!!
                    I've not had any issues with nested groups/components. And I've had some very heavily nested models.
                    In the very first V-Ray version there was a bug where some groups would not render, but in the next releases it was fixed and has never been an issue.
                    I would not sacrifice model organisation.
                    • N Offline
                      nitav
                      In sketchup all you have is Polygon or faces and Nested objects.
                      thus it reports this bug. It is better to use 3D max then pointing towards the version of sketchup and vray or just wait for that day when sketchup will become a high end software..
                        I use SketchUp and 3DsMax and I have no issues with either.
                        Doesn't matter what modeller you use as long as it can create the mesh - and SketchUp is more than capable of producing the geometry I want. Have a look around and see that people are having no problem creating images matching with SketchUp + (Insert your favorite render engine) as with any other modelling package. It's just a tool - like any other.
                        Anyway, how it this related to V-Ray for SketchUp and the original question?
                        • N Offline
                          nitav
                          I dont know what you are on about but i am sure my answer is little bit helpful to the questioner,bcoz the same problem got me 1 month before.lets stop arguing ourselves and lets wait for the questioner to comment here that he fixed his bug or not .?
                          Gotcha..?
                            Just didn't find "explode the whole model" (a completely destructive function) or "use another software" to be a reasonable solution.
                            But I agree, lets see what the OP has to say. More info is needed.
                            • N Offline
                              nitav
                              hey..! thomthom,use Shortcut key for Explode.
                              Select everything by pressing ctrl-A and keep pressing the
                              that explode shortcut until the Outliner is empty.
                              or also u can use Bomb ruby plugin from Smustard.com.
                                rspierenburg
                                Perhaps the OP can post their model for others to try.
                                Rob
                                  My objection against exploding a model (apart from being very slow operation on large models) is that's not a good workflow. When I render I don't render just once and dump the model. I often have to revise the render as the project changes. In order to make revision efficient I need to maintain group and component hierarchy.
                                  Additionally, VfSU will process a model with component instances more efficiently in contrast to an exploded model.
                                  Exploding a model to render it is like formatting the harddrive because a single program is acting strange. Using a cannot to kill a mosquito.
                                  When answering questions I try to find the best solution - that can work in a good workflow. Exploding can be ok if you're in a desperate pinch to render for a deadline - but I'd not settle with that. I'd go back and find a better solution.
                                  And I have yet to experience a situation where I need to explode a whole model to render it.
                                    Last visited: 24 May 2012, 14:05
                                    Don't think this user will come back and update us on the issue. (As often happens.)
                                    • panixiaP Offline
                                      panixia
                                      anyway, i have a question about components.. when multiple instances of the same component are painted whit multiple color, vray take advantage of it being a component or it manage it as it is made "unique"?
                                      not pretty sure in this case, but i noticed that others operations such as freedoscale etc, applyed on a component will make this unique and increase the parsing time for vray..
                                        Internally it will create a new definition for each material variation.
                                        • panixiaP Offline
                                          panixia
                                          so not advantages at all keeping it a component but then painting.. right? 😢
                                            If they all have unique instance material - then I think no.
