    Large circular lattice work
    83 Posts 7 Posters 12.4k Views 7 Watching
    • GaieusG
      Pilou, you are a dinosaur. I think we'll collect some money for a new computer for you in BaseCamp. If you are lucky, we won't spend all the money on booze.
        The new-improved even better tool DrawHelix**14** [by Jim] is linked here http://forums.sketchucation.com/viewtopic.php?p=292183#p292183
        That appears in the 'Draw' menu NOT 'Plugins' !
          @lyconthrous said:
          Dave I did find it through a forum search, had to add .rd and it showed up. Moved it to the plug-in folder and "nothing".
          Did you restart SketchUp? Did you look in the Draw menu?
            you are a dinosaur
            Yes ๐Ÿ’š
            But I never understood why people don't save all their files posted in V6 ๐Ÿ˜ฒ
            Like this all can reload them (v6v7v8)(except when it's Dynamics components (1%) so V7 ๐Ÿ˜„
              Who is this "all" you talk about. You're the only one left using V6. ๐Ÿ˜„ ๐Ÿ˜‰
                I just replicated this without a Helix tool at all...
                All done using native-tools [from a plugins-meister ๐Ÿ˜ฎ ]...
                Make a cylinder the size of the yurt's perimeter wall.
                Center its base-circle on the origin for easy use later
                I used 24s [the default for a circle] giving 15 degrees per repeat.
                Modify the cylinder with the Smooth tool so all of its edges show - now you have a set of rectangular 'panels'.
                Group the geometry - we want to draw over it without our new geometry sticking to it.
                Draw a short horizontal line along the cylinder's base-edge, the length of a slat-width [50mm?], repeat at the top join the ends to make a 2d outline of an angled slat.
                PushPull the slat to the required thickness [25mm?].
                If needed orient the faces so they are all facing 'out' [i.e. no blue showing].
                Select all of its geometry [treble-click] and make a component of it called 'slat' or similar.
                Replacing the original geometry with the component-instance.
                Now make a Rotated copy [Rotate+Ctrl] of that slat about the center of the top edge of cylinder's panel on which slat was formed, locked to the blue-axis.
                The copy will now cross the original in the opposite direction, with them just touching.
                Erase the cylinder - we now longer need it.
                Select the two slats ans use Rotate+Ctrl to make the radial array.
                Center it on the origin locked on the blue-axis.
                Pick any point and start the rotation of the copy.
                Type in the repeat - it needs to be a multiple/division of 15 degrees [360/24] used in setting out the cylinder's panels, I chose 3.75 so there are 4 slats at an angle in each 15 degree 'panel'.
                Type that in and the copies appear rotated by that angle.
                Now immediately type in the number of copies needed for a full circle - in this case (360/3.75)-1 = 95 since the original '1' is already there!
                All of the slats are formed around the shape with proper lapping.Capture.PNG
                  @Dave
                  Don't think that, we are more numerous that you think! ๐Ÿ˜‰
                  • LyconthrousL
                    Lyconthrous
                    @ Dave, I might have been using SU for about 2 years now, but I still have a lot to learn. I just learned about plug-in 2+weeks ago and as you can see, I'm new to the forum. But I didn't know where to look to see that ๐Ÿ˜ณ yes it's loaded into SU. So after I finish my next attempt at a slat, I'll start working on that plug-in and figure it out. I think I've figured out a way to do a slat with all native tools.
                    @ Pilou, Sorry I thought it would work and if I had tried this 3 weeks earlier, it would still be in Ver 6. I just upgraded to Ver 8. Great picture of the yak. I know how Dave feels about camping. I feel the same at times.
                    @ Gaieus, nice to see you again.
                    @ Tig, love your forum name, my favorite way to weld. I just saw a vid on Utube from a guy in Japan doing a spring. Which gave me some good ideas to try. Which I'm about half way through now. I came back to double check how Dave did his ends and 'olly zhit I got tagged. I'll be going back over your post, hopefully after my current attempt pays off and not to bale me out of trouble.
                    I want to thank all you guys for your help. It's really help to cut down my learning curve. I hope you all stick around for the next project, A rapier hilt. I've attached a pic of 2 that are important to me. The one on the right is the 1st hilt I did that balanced out right and taught me how balancing works. The one on the left, I did well going through postate cancer treatment. It gave me something positive to focus on.
                    A warped mind is a wonderful thing to abuse
                      For Save in V6 from V8
                      Menu "Save as" / and click on the little black triangle at the end's line and choose the number of the export version ๐Ÿ˜‰
                      • LyconthrousL
                        Lyconthrous
                        Well my attempt didn't pan out. I got the lines drawn, but couldn't get a face on the drawing. I got Tig's to work, but I had a few problems there as well. With the small radius used in this yurt size, the slats do bend and I couldn't figure out a way to get the spacing right. After learning where to find draw helix, I figured out the correct inputs and got to step 4 without any problems. On step 5, Dave talks about "dividing those lines into three segments", not sure which lines that means. I thought it was the helix lines, but that didn't work. Tried the short line (didn't make sense,but what the 'ell), the only way I could get a face was to "stitch" I think you guys call it. Drawing smaller triangles to form a face. Did I do something wrong?
                        • LyconthrousL
                          Lyconthrous
                          @Pilou, That's what I thought I did. But I could have screwed up something that easy considering. So let's try it 1 more time.
                          14 yurts wall004v6.skp
                            This time that's perfect for the file ๐Ÿ˜‰
                            but not for the shape Bender in a reasonnable time! ๐Ÿ˜ข
                            I stop the process fefore the end
                            I will see if replace the numerous same groups by a component will be more easy...
                            No same result ๐Ÿ˜ž
                              Sorry for the delay in responding. I was teaching anesthesia machine nuts and bolts.
                              I was referring to dividing the short lines drawn across the ends. Right click on them and choose Divide. I divided the lines into 3 segments. Then it is important to use Weld.rb to weld the lines back together.
                                As your previous file has a very too big complex module
                                Maybe more something like this on 2 segments of an arc circle but
                                the curvated module result of the shape Bender has some no coplanar faces ๐Ÿ˜ฎ
                                (erased here with the Erase tool + Shift : so a little cheating! ๐Ÿ˜’
                                So no good for a project, sufficient for an image
                                better with it to take some textures like my previous post if you don't want volumes ๐Ÿ˜‰
                                  @ Dave : have you thought of all users of the V6 Pro who have not made the upgrades ? ๐Ÿ˜‰
                                    To be honest, no. You're the only one here who ever asks for files to be posted in V6. ๐Ÿ˜‰
                                      Others are too shy! ๐Ÿ’š
                                      I have found another one here! โ˜€
                                        One? ๐Ÿ˜„
                                          I have not made a deepth research! ๐Ÿ’š
                                          Ps Have you seen that at 3Dwarehouse quasi all objects are proposed with different version files ? and V6 of course โ˜€
                                          That will be a cool thing that files posted at Sketchucation are automatically transformed in some basic versions! ๐Ÿ˜Ž
                                          • LyconthrousL
                                            Lyconthrous
                                            @ Pilou, I have been having the worst luck with Shape Bender. I've gotten a single slat to bend, but not much more. And I don't mind post a different version of file if it helps people to learn. But something tells me the guys (your friends) are not going to stop kidding you about it.
                                            @ Dave, besides felling like an idiot, I'm still having problems. But I'm not giving up yet. I'm figuring out extrude edge by rail. Found a few pages that help explain it. Which help explain what I messed up before. If I can get it tonight, then I'll ask more questions.
                                            • 2 / 5
