[WIP] house in Helsingborg Sweden
Thanks Bryan!! I dont mind sharing my fur settings...
I used 6 different presets (fig 1), applied the first 5 to a 1x1 meter square (fig 2) and then mixed all together, the 1 square meter was used to cover all the ground and then used the preset #6 applied to 1.5 m circle and scattered along the ground (fig 3) using the crowd option of the same plugin...
probably you have to play with the density parameters... for the materials used simple solid color with slight variations of greens for each kind of blades...
best
V
Hi novena,
Nice, clean render...
It follows my design philosophy of 3 colours or it has to be really strong reason to introduce more
Just out of interest...
What kind of accommodation do you have on the first floor? I assume... bedroom/s (with study?) and bathroom/shower...
If this is the case, It would be nice to see big terrace (above living...)- no railings and the introduction of structural glazing as balustrading.
If the client doesn't like it - do it just for the image...
Nice grass...
Excellent! Thank you so much Victor! The effect is truly outstanding.
beginner,
thanks so much for your comments... yes, you are guessing right on first floor there is the master bedroom with a study/living and bathroom, first I was proposing a bigger terrace but the client and my boss preferred it as it looks on the image, which should be presented to the client one of this days... I would prefer to eliminate the balustrading just for the image
Bryan,
you are very welcome... -
update, the image rendered at 20 SL...
Some small details to improve especially on the interior.
I dont like the hard shadow of a wall projected on the grass, soft shadows from vegetation would be better.
Looks great!
Really nice... Is there any DOF effect in Maxwell? Maybe it will look a bit better by keeping only the house in tight focus, with the foreground grass a bit blurred.
gracias Ecuadorian,
yes there is DOF in maxwell and it is controled as in real life with f-stop, I used an f37 to avoid DOF in order to reduce rendering time...
I´ve been trying to create a Z-depth image using the sketchup´s built-in fog to be used with the lens blur filter in photoshop, with no decent results...
saludos
V -
Nothing bad to say about the renderings, looks neat, framed very nice. But I must confess... I really like the architecture, you guys are doing a great job there (in your country).
Cheers,
Stefan -
thanks Stefan, I appreciate a lot your comments...
best
V -
I really like that you added the background trees, they look really nice. A foreground element would have been nice as well for capturing more depth. The subtle dirt detail in the wall texture makes a huge improvement in the look of the render. Placing the building off center like you did in the first image in my opinion makes the whole composition look a lot better. Overall nice renders!Oh, and nice grass also…
hi renderiza, thanks a lot for your comments... I like to create my scenes with my own background trees to have more control over the hole scene...
best
V -
hi guys! here some progress, view from the street...
added a bit of fog to capture more depth on the background using sketchup's built in fog, as well as a background image to add clouds...
I'm not happy at all with the hedges in foreground (I will change them), need some variation on the grass as well as the asphalt texture is not complete...
Really interesting watching your project come together. If you can add a little random rotation to the hedge elements you should get better results.
Hieru thanks so much for your words,
about the hedge it has already a random rotation and scaling, instead I changed the plant for another a bit bigger with denser foliage with a planting distance of 45cm (before plants were planted @60cm)
did a quick PS preliminary study of the lighting for a night time view, the idea is to light up the white walls while the wooden box remains dark contrasted with the interiors light
ooh this is getting tasty!!
Oli, thanks for leaving a comment!!!
here comes the night time view (tested with all vegetation hidden), I need to increase the lighting on the first floor to create more contrast with the wooden box... heard that Maxwell standalone plugin supports now IES, will give it a try, I think it would be nice to see nicer flood light on those white walls...
best
V
Incredible! I got to learn about the fur plugin in this thread!
valkyre, thanks for watching and commenting...
best
V -
hi forum!
watch the finished images here:
http://sketchucation.com/forums/viewtopic.php?f=81&t=48392best
V
