    [WIP] house in Helsingborg Sweden
    24 Posts 9 Posters 4.7k Views 9 Watching
    • Bryan KB Offline
      Looks great!
      Would you please share your exact fur settings for the grass?
      • novenaN Offline
        novena
        Thanks Bryan!! I dont mind sharing my fur settings...
        I used 6 different presets (fig 1), applied the first 5 to a 1x1 meter square (fig 2) and then mixed all together, the 1 square meter was used to cover all the ground and then used the preset #6 applied to 1.5 m circle and scattered along the ground (fig 3) using the crowd option of the same plugin...
        probably you have to play with the density parameters... for the materials used simple solid color with slight variations of greens for each kind of blades...
        best
        V
        http://hdzarkitektur.wordpress.com/
        • beginnerB Offline
          beginner
          Hi novena,
          Nice, clean render... 👍
          It follows my design philosophy of 3 colours or it has to be really strong reason to introduce more 😉
          Just out of interest...
          What kind of accommodation do you have on the first floor? I assume... bedroom/s (with study?) and bathroom/shower...
          If this is the case, It would be nice to see big terrace (above living...)
          • no railings and the introduction of structural glazing as balustrading.
            If the client doesn't like it - do it just for the image...
          Nice grass... 👍
          Regards, SU 'beginner'
          • Bryan KB Offline
            Excellent! Thank you so much Victor! The effect is truly outstanding.
            • novenaN Offline
              novena
              beginner,
              thanks so much for your comments... yes, you are guessing right on first floor there is the master bedroom with a study/living and bathroom, first I was proposing a bigger terrace but the client and my boss preferred it as it looks on the image, which should be presented to the client one of this days... I would prefer to eliminate the balustrading just for the image 👿
              Bryan,
              you are very welcome...
              • novenaN Offline
                novena
                update, the image rendered at 20 SL...
                Some small details to improve especially on the interior.
                I dont like the hard shadow of a wall projected on the grass, soft shadows from vegetation would be better.
                • Bryan KB Offline
                  Looks great!
                  • E Offline
                    Ecuadorian
                    Really nice... Is there any DOF effect in Maxwell? Maybe it will look a bit better by keeping only the house in tight focus, with the foreground grass a bit blurred.
                    -Miguel Lescano
                    • novenaN Offline
                      novena
                      gracias Ecuadorian,
                      yes there is DOF in maxwell and it is controled as in real life with f-stop, I used an f37 to avoid DOF in order to reduce rendering time...
                      I´ve been trying to create a Z-depth image using the sketchup´s built-in fog to be used with the lens blur filter in photoshop, with no decent results...
                      saludos
                      V
                      • stefanqS Offline
                        stefanq
                        Nothing bad to say about the renderings, looks neat, framed very nice. But I must confess... I really like the architecture, you guys are doing a great job there (in your country).
                        Cheers,
                        Stefan
                        • novenaN Offline
                          novena
                          thanks Stefan, I appreciate a lot your comments...
                          best
                          V
                          • renderizaR Offline
                            renderiza
                            I really like that you added the background trees, they look really nice. A foreground element would have been nice as well for capturing more depth. The subtle dirt detail in the wall texture makes a huge improvement in the look of the render. Placing the building off center like you did in the first image in my opinion makes the whole composition look a lot better. Overall nice renders!
                            Oh, and nice grass also… 👍
                            [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                            • novenaN Offline
                              novena
                              hi renderiza, thanks a lot for your comments... I like to create my scenes with my own background trees to have more control over the hole scene...
                              best
                              V
                              • novenaN Offline
                                novena
                                hi guys! here some progress, view from the street...
                                added a bit of fog to capture more depth on the background using sketchup's built in fog, as well as a background image to add clouds...
                                I'm not happy at all with the hedges in foreground (I will change them), need some variation on the grass as well as the asphalt texture is not complete...
                                • HieruH Offline
                                  Hieru
                                  Really interesting watching your project come together. If you can add a little random rotation to the hedge elements you should get better results.
                                  www.davidhier.co.uk
                                  • novenaN Offline
                                    novena
                                    Hieru thanks so much for your words,
                                    about the hedge it has already a random rotation and scaling, instead I changed the plant for another a bit bigger with denser foliage with a planting distance of 45cm (before plants were planted @60cm)
                                    changed the foreground hedge
                                    did a quick PS preliminary study of the lighting for a night time view, the idea is to light up the white walls while the wooden box remains dark contrasted with the interiors light
                                    preliminary study of a night time view
                                    • olisheaO Offline
                                      olishea
                                      ooh this is getting tasty!!
                                      oli
                                      • novenaN Offline
                                        novena
                                        Oli, thanks for leaving a comment!!!
                                        here comes the night time view (tested with all vegetation hidden), I need to increase the lighting on the first floor to create more contrast with the wooden box... heard that Maxwell standalone plugin supports now IES, will give it a try, I think it would be nice to see nicer flood light on those white walls...
                                        best
                                        V
                                        • V Offline
                                          Valkyre
                                          Incredible! I got to learn about the fur plugin in this thread! 😄
                                          • novenaN Offline
                                            novena
                                            valkyre, thanks for watching and commenting...
                                            best
                                            V
