Help with GPU choice
ATI
just to be different
I've an ATI and it's rubbish
I agree with ThomThom.
We had some problems with ATI in the past...
nVidia seems to be more consistent.
Have a look this - Performance vs. Value
http://www.videocardbenchmark.net/
http://www.videocardbenchmark.net/gpu.php?gpu=GeForce+GTX+560
http://www.videocardbenchmark.net/gpu.php?gpu=Radeon+HD+6870but read the full spec of your preferred card (check the extras included) to have 'like for like' comparison against different makers.
And when looking at benchmarks you must keep in mind what you will use it for. Often it's aimed at gamers. For SketchUp you want a good OpenGL card.
@thomthom said:
I would pick an nVidia product. I got an ATI card on my office machine a while ago - I experienced many strange glitches
nVidia seems to be more consistent.i use sketchup both on a laptop with ati radeon HD5730 and on a desktop with nvidia GTX560 and seems to be way more consistent and smoother on nvidia..
but not sure it'si only a gpu thing, because the overall specs of the desktop pc are better (motherboard, cpu, etc..) -
I've had ATI and nVidia on the same machines - and with SketchUp nVidia won every time. I didn't perform framerate tests or anything - but my choice is purely in reliability. (Wish I'd taken screenshots of all the odd glitches I got with ATI.)
My ATI card creates a border around the workspace on selection of geometry
Doesn't start SU with AA on at times.
Driver updates frequently cause issues.
I'll never go ATI again.
I've nVidia on my 2 desktops and they are smooth.
Ok, thanks for all the feedback so far.
So apparently the NVidia card wins hands down (especially in regards to stability/reliability)
But what about CUDA cores vs stream processors ?
What's the benefit of having CUDA cores at this very moment ?
Or is it more for the future that this will become important ?
And what about the stream processors, because the AMD card has much more stream processors than the NVidia card.FYI: I also have another system with an NVidia Quadro 600 1GB (Core i5-2400 @ 3.1 Ghz, 8GB RAM) and to be honnest I'm rather disappointed about its performance with Sketchup.
I am just speculating here, but this is not necessarily so surprising when one looks at some of the internal specifications of many of these cards. Various shaders for specific purposes having to do with fast rendering for high frame rate may have little to do with Sketchup. Many of these impressive cards use newer versions of OpenGL, where Sketchup may not utilize these capabilities. My "middle of the road" Nvidia GTS450(1Gb) utilizes OpenGL 4, for instance, and, last time I checked, Sketchup requires something like version 2.
That was my first reaction too
I expected to see a much smoother sketchup with that quadro card and cpu, but unfortunately it isn't
Sketchup can be very very slow on that system and even "not responding" or even crashing.And that's the reason why I also asked whether the cuda cores and/or stream processors are important, because that's apparently not so good with the Quadro 600 (i.e. only 96 CUDA cores)
Well, I just tried to edit my comment to include that your rendering application(s) is part of the equation for selecting your GPU. This is what puts the card to work.
Ok, I understand that the rendering application is also an important factor for the GPU choice, but my first and main concern at this very moment is the speed/usability of sketchup itself, which is unfortunately not always very satisfying at the moment.
For the rendering application I haven't made a choice yet, because the prices vary from completely free to several thousands of dollars (while each rendering application has its pros and cons of course).
Currently I am using both Kerkythea and Maxwell render free, but I am also considering Thea render, Maxwell (licensed pluginn because studio is too expensive at the moment), Artlantis Render, IRender nXt and Indigo Render.Are there already any details available about sketchup 9 ?
Will it benefit from CUDA cores ?
"No telling what Sketchup9 will offer. My guess is it probably will not. And there may be others around here who could be testing 9 right now, but may not be at liberty to say. I am not one of them.
Ok, I'll have to wait and see then
Nevertheless I decided to order the GTX-560.
Thanks everybody for giving your feedback.
BTW, I noticed that the GTX-560 (at least the Asus version) is even larger than my 8800 GT.
Combined with the dual-slot layout this means that I'll have to offer 3 of my 6 sata ports
FYI: I just received and installed my new GeForce GTX-560 and did some tests with it and I am very pleased with its performance so far
Sketchup seems to work very smooth now and the lines are much sharper than before.As an indication:
Windows Experience Index gave me a 6.9 for my 8800 GT while I get a 7.5 for the new GTX-560.
And I just noticed that my Quadro 600 on my other, more powerfull system only gets a 6.6
I dunno what problems you all had with ATI.
I had an older ATI card (ATX form 500mb) and it seemed flawless in SU and other graphic apps. Fast enough for all but the largest models panning.
Then my motherboard lunched and I replaced it, and the GPU with a newer NVidia (2GB) card and had weeks of frustration getting it setup correctly. All the colors were off, and no lines were as crisp as the ATI.
I tweaked multiple times, and defaulted at least twice. I've now settled for a near default setting, but I often get photos that are too dark, and need lightening up, which was very rare on the ATI. None of my SU materials look quite right and the lines are still not crisp like the ATI was. But it is good enough and I am used to it now, and it is faster panning large models than the ATI.
Nvidia all the way. I've had nothing but problems with ati cards and sketchup. I have the gtx560 and it works great.
I just ordered this card from Newegg. Good choice, bad choice? I'm not concerned with rendering, only SU.
I found this link:
http://en.wikipedia.org/wiki/GeForce_500_Series
In case you wanted to look at it. This page also links to other model numbers/series. The device you ordered is a branded, or repackaged nVidia unit. I do not know what that may mean at the end of the day, other than they would be like a vendor/ distributor. -
Do you have the regular 560 or the TI version ?
What are your system specs ?As I said before sketchup works much smoother with my GTX560 in comparison to my previous 8800GT, but now that my model is growing I'm starting to see some slowdowns from time to time when I set the faces to "shaded with textures".
Fortunately it's nothing dramatic yet, but my model isn't halfway...
(FYI: I have no 3d trees or other "heavy" 3d objects in my model)
