    What happened to the Kerkythea forums?
    extensions
    13 Posts 7 Posters 2.5k Views 7 Watching
      Rob D
      I just called by the Kerkythea forums and noticed there's been no posts since 2011 😲 I'm quite sad about that. What do you think happened there? Has everyone moved on to other rendering forums - perhaps Thea render?
      • massimoM Offline
        massimo Moderator
        Kerkythea's forum is still quite active. Perhaps you looked at the "old" forum? Try this one:
        http://www.kerkythea.net/forum/index.php?sid=6f3495ea04bfce002ba3ddee19035f22
        And here is Giannis announcement:
        http://www.kerkythea.net/forum/viewtopic.php?p=86572#p86572
          Rob D
          Thanks mate! I thought something didn't quite add up πŸ˜„
          • massimoM Offline
            massimo Moderator
            You're welcome. πŸ˜„
            • N Offline
              notareal
              Sounds strange - are we at the same forum... http://www.kerkythea.net/forum/
              Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
              • Bryan KB Offline
                There appears to be a problem with the entire website with broken links.
                Can someone contact them? Even their contact page was not working for me.
                • Bryan KB Offline
                  Thanks. I did manage to log into the forums.
                  • N Offline
                    notareal
                    http://www.solidiris.com/cms/ "contact us" does work, the contact form at kerkythea.net is broken and there certainly are some broken links after the site & forum upgrade. Take a look in http://www.kerkythea.net/forum (the new forum) or file repository http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=43
                    • Mistro11M Offline
                      Mistro11
                      I noticed that if I browse the forums as a guest, there are no new posts showing from months ago. But when I log in, I see recent posts. This should be fixed because I can imagine some people who want to join being discouraged, considering the forums dead. I wouldn't post a question on a dead forum. It's misleading and I can understand the OP's first reaction and question.
                      i7-4930k @3.4/3.7GHz, 32Gb RAM, NVidia GTX 980Ti 6Gb, Windows 7 Pro 64bit
                      Structural Integrity is Not Just Physical...It's in the Design and Purpose
                        MrKeef
                        I haven't been able to access the Kerkythea forums since the weekend. The address isn't exactly a broken link (I tested it with a google link tester) but it just loads a blank page. Is this just a routine outtage, or is the forum kaput? I use it all the time.
                        Let me know if you know anything about this.
                        • FrederikF Offline
                          Frederik
                          Not sure what have happened on the Kerkythea website... πŸ˜•
                          It has been reported to the Admins now...
                          Sorry for the inconvenience...
                          Cheers
                          Kim Frederik
                          • N Offline
                            notareal
                            Direct address into forum is http://www.kerkythea.net/forum/ and does work fine
                            At the moment the website itself cannot be accessed, we suspect that it's something to do with the service provider.
                              MrKeef
                              Awesome, thanks guys.
