    Paste Material on Multiple Faces in Groups
    18 Posts 7 Posters 1.7k Views 7 Watching
      So each of your 100 buildings is a group? To paint the individual faces you'll have to open each group for editing and apply the materials. It doesn't sound like you're doing that. Then apply the materials as needed. Keep in mind that you'll be doing this for each of your 100 groups.
      Do you have a number of buildings that while unpainted are identical? Or is each one different?
        ryangarnett
        Hi Dave, I have opened the group for editing, this produces what I want, but I want to know if there is another way to do this, without needed to open each grouped building. For the most part, each building will visually look the same (may have different dimensions, but will be represented with the same textures). They can not be copy and pasted, as they need to be represented geographically. I have attached a PDF that visually outlines the situation. I am thinking the only way is to edit the groups, I was hoping I didn't need to.
        Thanks...
        Material Pastign on Multiple Grouped Faces.pdf
          I'm afraid you'll need to open each group for editing to do this because the materials must be on the faces. Probably too late now but you'd have saved yourself some time by applying the materials prior to making the groups. Then you wouldn't need to open each one again and edit it.
            ryangarnett
            No that won't work at all, so it will remove the building ID that is associated to each group, which is a major requirement. If I explode them, there will be no way to re-associate the building ID, short of selecting, grouping and renaming.
              Looks like its either manually or ThruPaint.
              Sometimes laborious models require laborious tasks.
              I can't see any speedier method that wouldn't involve some type of destructive process.
                ryangarnett
                Thats what I was thinking and worried about. I couldn't find a better way, but I wanted to ask the community to see if I was missing or over looking something.
                Thanks..
                  Explode all to the level of the frontages and use Select by Aera by Sdmitch πŸ˜‰
                  That will maybe win some clicks πŸ˜‰
                  And never use groups for this sort of project! πŸ˜‰
                  • DavidBoulderD
                    DavidBoulder
                    Do any of the selection plugins offer face orientation as a filter? OpenStudio does this but you would spend more work converting this to OpenStuido than repainting with thru paint.
                    David Goldwasser
                    OpenStudio Developer
                    National Renewable Energy Laboratory
                      Selection Toys has some basic functions to select all parallel or perpendicular.
                      • DavidBoulderD
                        DavidBoulder
                        If it doesn't already, it would be cool to have checkbox to only select parallel with same face normal direction, vs. opposite.
                        Kind of related to this one tool I always thought would be really cool is one that lets you draw a window or crossing box drill down through groups. If you are familar with Adobe Illustrator, they have a selection tool and then a direct selection tool. It acts very much like this. One issue with this in SketchUp is that if you had rotated one of the groups and then try and move a surface within that group, it will move in the wrong direction. Actually I have an old video showing that.
                        http://www.youtube.com/watch?v=Tsx3dlSb0uI
                        David Goldwasser
                          There is a "Select Coplanar" - which is misnamed as it's actually "Same Direction" instead of being coplanar.
