    What's this?
    65 Posts 15 Posters 5.5k Views 15 Watching
    • Mike LuceyM
      Mike Lucey
      Yep, its a table and chairs, with a little difference. I am playing around with a dual use coffee table / dining table. Also some storage area. It might suit small apartments.
      This is the Mark I and I have started on Mark II which is going to be more simplified and include a clipping / holding mechanism to hold the chairs in the closed position, also playing around with the storage areas, top / side loading etc.
      I am trying to figure out how this can be built exclusively in timber as the aluminum parts would tend to make it expensive and possibly out of reach for DIYer. Also the 'lifting' system needs looking at.
      TIG, I also have the Fusion Dining set from IKEA. Liked it the first time I saw it. I am always fascinated with dual function furniture ...... suppose its the 'gadget' lover coming out in me. BTW, that Capstan table is way cool!
      • daleD
        dale
        Hey, great concept, and challenge.
        Here is a pavilion designed as a project by a team of the students at M.I.T architecture school. It uses a system of Kerf cutting, which is not new in woodworking by any means, but the technology available to accurately execute it is.
        Here is their brief:
        This pavilion is the culmination of a semester's research into a novel digital fabrication technique by a team of graduate students in the MIT Department of Architecture. The design of the pavilion is the result of an old technique reinvented using digital strategies and tools. Kerfing, the cutting of wood to add flexibility, has a long history in wood working. Our research combined the material logic of kerfing with the flexibility of parametric modeling and the accuracy of a CNC router. Our parametric model integrated all the digital steps in the modeling and fabrication process, from initial control over the global form to the unrolling and generation of the cut patterns required to make each unit. The patterns allow the plywood to be bent into a predictable shape without the use of additional tools or techniques.The pavilion is a manifestation of new possibilities for design and construction.Screen shot 2012-08-23 at 6.00.43 AM.png
        This looks like a plywood based system, but the Haida, the aboriginal natives to Haida Gwaii have been employing it for centuries using solid woods (cedar in particular), kerf cut and bent from a single piece of wood.Screen shot 2012-08-23 at 6.11.34 AM.png
        I wouldn't hesitate to try and contact the MIT folks. Maybe an arrangement can be worked out.
        Good luck with this one πŸ‘
          Beaten to the punch....
          404 Not Found
          (www.fatihcansarioz.com)
          [xxl-img:l0yqt063]http://behance.vo.llnwd.net/profiles21/729363/projects/2598441/hd_edd0edb44fcb77a09d5060e34f6a399e.jpg[/xxl-img:l0yqt063]
          • beginnerB
            beginner
            TIG, you would need some power supply. Isn't it? πŸ˜„ or one battery 9V ❓
            Regards, SU 'beginner'
            • hellnbakH
              hellnbak
              Really nice design, very imaginative πŸ‘
              One observation - it looks like the chair backs would maybe be weak (I'm assuming you would use wooden dowels, since you mentioned you wanted to use all timber)
                ArCAD-UK
                Nice idea Mike, I'm working on some compact living projects and it's the sort of solution the end user might like. Obviously this is probably personal preference but if you can sit on a bar stool at a breakfast bar then why do you need to provide a back support.
                I'd agree with TIG the table lift needs some work maybe an office chair type gas strut.
                • EscapeArtistE
                  EscapeArtist
                  I like it, but perhaps you might consider the flanges that are the supports for the base of table. Myself being rather tall and occasionally clumsy, I view those as knee-banging table rattlers. I would waste no time in scooting my seat forward and capsizing a beverage with a well placed knee-shot to the support. A flat, wide, bar-like support that rests directly on the floor or uses slightly recessed wheels would eliminated those bruises and toppled glasses of wine. Low enough to slide beneath the chair base, obviously.
                  Just a thought.
                  • Mike LuceyM
                    Mike Lucey
                    @Rich
                    You have not studied the concept. The design is primarily a coffee table then an occasional dining table.
                    While the kΓΌre looks funky, it becomes a big useless blob sitting in the middle of the room taking up valuable space when not being used as a dining table πŸ˜‰
                    @ Steve
                    Yep, you are right. the chair backs are weak. I have to work on that. Maybe even drop the backs.
                    @ArCAD-UK / Trevor B
                    TIG is right. Lifting the glass table top would require a fair amount of muscle work. I am thinking of going with a lighter wood (ply) top and a very simple way of having two heights - coffee table - dining table.
                    @Jeff
                    I'm designing for normal humans! Just kidding πŸ˜„
                    I take your point. I now think there is no need for casters on either the table or chairs, just some gliders (very short ones) like on sofas, but much smaller.
                      The table-top could have a concealed hydraulic ram - like a hatchback car's door, or even some 'springs to assist you in lifting it up easily. To lower it you'd release the 'catch' and it is damped as it settles down too...
                      OR 'Ratchet' strips could also allow an incremental lift and lower using a simple sprung 'catch' [that could all be wooden]
                      OR how about a 'lever' system in one of the legs [with a flip down/up pedal that is accessed when a chair is slid out] - that can then 'jack' the table up [like a car bottle-jack?] and when released it lets the top slowly settle back down... πŸ€“
                      • Mike LuceyM
                        Mike Lucey
                        Great suggestions TIG. I will play around with those.
                        • hellnbakH
                          hellnbak
                          Hey Mike, I got to thinking about the seat back problem, and this is something I came up with.
                          Adding the extra layer would let you increase the thickness of the seat back. This could also work with the wooden dowels.
                          Probably not the look you were going for, with all the curves, I just started having fun with it πŸ˜† But you get the idea
                          Anyhow, just an idea.
                          • Mike LuceyM
                            Mike Lucey
                            That works Steve, well done πŸ‘
                            I am moving towards doing even a more straightforward design that doesn't involve curved plywood.
                            This is great as it turning into a collaboration πŸ‘
                              A square table and 4 square chairs ? 🀣
                              • Mike LuceyM
                                Mike Lucey
                                Now there's an idea 😲
                                  The Sqhair
                                  Economical on material too.
                                  Simply table-sawn and router rounded-corners etc as needed etc.
                                  The table can use a simple foot-operated bottle-jack mechanism to lift it up and on release lower down.
                                  The storage under the seats is set back a little to avoid heel-clashes.
                                  The seat-back half 'L' slides up/down on dado friction glides [Γ  la draw-slides] with a catch to it lock 'up' ?
                                  When the seats are removed from the assembly they are set around the table at 45 degrees on the sides of the square. The seats are on castors.
                                  Sqhair.skp
                                  • hellnbakH
                                    hellnbak
                                    Nice, but those seat-backs don't look very comfortable
                                    • Mike LuceyM
                                      Mike Lucey
                                      Now we are getting places.
                                      TIG, would that table have a bit of wobble potential? Also I think Steve might be right about the backs not being too comfy.
                                      Have you a pic of a 'foot-operated bottle-jack mechanism'? I'm curious about that.
                                      I'm not so sure about the seats being on casters but they could be lockable. I think slides might work better.
                                        ArCAD-UK
                                        An octagonal shape applied to TIG's design would sort out the seat backs.
                                        • soloS
                                          http://cdn.dornob.com/wp-content/uploads/2009/05/combined-wood-table-chairs-design.jpg
                                          • hellnbakH
                                            hellnbak
                                            One possible solution to the seat-back
                                            Sorta looks like a toilet with the seat folded down πŸ˜†
                                            • 1 / 4
