    [Solved]Shadows acting funky
    38 Posts 9 Posters 1.1k Views 9 Watching
      You need to set a template that uses as little resources as possible. Add eye-candy for export πŸ‘
      • hellnbakH Offline
        hellnbak
        Actually the computer I built a year or so ago seems to handle everything pretty well. Once in a while when moving a model the textures blank out for a few seconds, but if I run Purge (the plugin) it takes care of that. I've always wondered why Purge does that, even when nothing is actually purged. But then I also wonder how bread becomes toast πŸ˜•
          Because it handles does not make it necessary. My modeling template/style is minus all the fluff that makes output look nice.
          • andybotA Offline
            andybot
            don't know why, but if I just change the saturation value by 1 step, and then change it back, it works fine. (for example color_A16 is H:169 - if I change it to 170 and back to 169, the shadows appear)
            edit: works in any of the HSB, RGB, HLS modes with any number. didn't try the color wheel as there's no direct # control)
            edit again: wow, didn't see all the info from thomthom (while I was slowly multitasking πŸ˜† ) - pretty sweet.
              Speed Up SketchUp: Use Fast Styles
              Follow the SketchUpdate blog for SketchUp news, modeling tips and tricks, user stories and more.
              (sketchupdate.blogspot.com)
              • hellnbakH Offline
                hellnbak
                I'm interested, could you explain this a bit?
                • hellnbakH Offline
                  hellnbak
                  Thanks Rich, some good information there, although the only one that applies to me is transparencies and I only use them for windshields. I do use Hidden Geometry a lot but I use a hot key to toggle it on and off as needed. Also, although I rarely use Scenes, I never noticed the options in Scene Properties, that could be very useful in the future.
                  BTW, how the heck do I mark this thread as "SOLVED"? (didn't know I was supposed to do that until recently)
                    Edit your first post title and add the [Solved] tag. I did it here but next time feel free πŸ˜‰
                      And it will also be obsolete on the new forums πŸ˜‰
                        http://news.bbc.co.uk/olmedia/460000/images/_463071_nudge.jpg
                        • hellnbakH Offline
                          hellnbak
                          What will be obsolete? Marking a thread as "solved"?
                            Yes.
                            • 2 / 2
