    [Solved]Shadows acting funky
    38 Posts 9 Posters 1.8k Views 9 Watching
      Ah! I know what this is!
      I actually wrote about this some time ago: http://www.thomthom.net/thoughts/2012/03/the-secrets-of-sketchups-materials/
      (Scroll down to Bug with Materials and Color Alpha Channel and see example and description of bug.)
      To fix all materials in your model, enter this one-liner in your Ruby Console:
      Sketchup.active_model.start_operation('Fix Materials',true);Sketchup.active_model.materials.each { |m| c=m.color.to_a; c[3]=255; m.color=*c; };Sketchup.active_model.commit_operation
        Very nice model by the way! πŸ‘ πŸ‘
        • hellnbakH Offline
          hellnbak
          You the man!!!
          While I don't pretend to understand any of the reasoning behind it, it did the trick!
          You are now on my Xmas card list
          • hellnbakH Offline
            hellnbak
            @tobobo said:
            Strangely when I open the skip the shadows work fine.
            Maybe I'm missing something
            Maybe you had already run ThomThom's miraculous fix?
              It's a bug in the quirky design of SketchUp materials.
              A material has a Color property - and Color property contains RGBA info.
              Materials normally ignore the A value of the colour and use the Alpha property of the Material itself.
              However, for some reason, when the Color property has the alpha value set to 0 the object doesn't case a shadow. And sampling materials with the Sample Color from Screen tool can in some cases set the wrong A value for the Color property.
              This is a bug I've reported to the SketchUp team.
              • hellnbakH Offline
                hellnbak
                @thomthom said:
                @hellnbak said:
                Well, I can live with 99% opacity
                That's going to hurt performance. Transparency adds overhead to processing of the model in the viewport.
                You mean that whenever I make a material transparent, even just a little transparent, it affects the processing of the model enough to hurt performance? Or did you say that just because the affected materials in this case pretty much involve the entire exterior and some of the interior of the model?
                  When a material is transparent the 3D render engine (SketchUp's viewport) need to perform more calculations in order to determine the colour of each pixel. As you see in the Styles setting you can set to Faster, Medium or Nicer. The better the slower. For max performance you can disable transparency all together. (I do that some times with heavy models with lots of glass or clip maps.)
                  • hellnbakH Offline
                    hellnbak
                    Well, thanks again. And thanks to everyone who offered their advice and suggestions.
                    • Rich O BrienR Online
                      You need to set a template that uses as little resources as possible. Add eye-candy for export πŸ‘
                      • hellnbakH Offline
                        hellnbak
                        Actually the computer I built a year or so ago seems to handle everything pretty well. Once in a while when moving a model the textures blank out for a few seconds, but if I run Purge (the plugin) it takes care of that. I've always wondered why Purge does that, even when nothing is actually purged. But then I also wonder how bread becomes toast πŸ˜•
                          Because it handles does not make it necessary. My modeling template/style is minus all the fluff that makes output look nice.
                          • andybotA Offline
                            andybot
                            don't know why, but if I just change the saturation value by 1 step, and then change it back, it works fine. (for example color_A16 is H:169 - if I change it to 170 and back to 169, the shadows appear)
                            edit: works in any of the HSB, RGB, HLS modes with any number. didn't try the color wheel as there's no direct # control)
                            edit again: wow, didn't see all the info from thomthom (while I was slowly multitasking πŸ˜† ) - pretty sweet.
                              Speed Up SketchUp: Use Fast Styles
                              Follow the SketchUpdate blog for SketchUp news, modeling tips and tricks, user stories and more.
                              (sketchupdate.blogspot.com)
                              • hellnbakH Offline
                                hellnbak
                                I'm interested, could you explain this a bit?
                                • hellnbakH Offline
                                  hellnbak
                                  Thanks Rich, some good information there, although the only one that applies to me is transparencies and I only use them for windshields. I do use Hidden Geometry a lot but I use a hot key to toggle it on and off as needed. Also, although I rarely use Scenes, I never noticed the options in Scene Properties, that could be very useful in the future.
                                  BTW, how the heck do I mark this thread as "SOLVED"? (didn't know I was supposed to do that until recently)
                                    Edit your first post title and add the [Solved] tag. I did it here but next time feel free πŸ˜‰
                                      And it will also be obsolete on the new forums πŸ˜‰
                                        http://news.bbc.co.uk/olmedia/460000/images/_463071_nudge.jpg
                                        • hellnbakH Offline
                                          hellnbak
                                          What will be obsolete? Marking a thread as "solved"?
                                            Yes.
                                            • 2 / 2
