    [Talk] Plugins Index
    179 Posts 70 Posters 72.2k Views 70 Watching
      buddyholly27
      Thanks Dan, I will start the terms of use trawl, and send PMs out where appropriate, when I get home. Shouldn't complain, after the work that you plugin people have saved me over the years - not to mention the things that I simply wouldn't be able to do at all! Fingers crossed there aren't too many restricted plugins though..
      Actually, do you think the index page might have an icon range for the copyright/terms for each plugin? (Same icon, different colour according to restriction status?) Probably a whole new can of worms...
      • Dan RathbunD Offline
        Dan Rathbun
        Well no, the Index cannot do that. (It only glean's whatever info the poster puts in the Topic Title.)
        There is a "convention" to use a "[$]" icon if it's a pay plugin.
        Cost, Copyright and Terms of Use are all separate issues.
        Most often an author always claims copyright (in some form,) to protect his work, regardless of cost, or terms of use. (Usually this is to control distribution so that old versions are not floating around out the web. Sometimes a certain license like GPL or Artistic, require copyright notices by the author and each of those who may revise the code later.)
        And BTW.. technically an explicit copyright notice is no longer required (since 1972 ?, I think,) it is now implied.
        I'm not here much anymore.
        • charly2008C Offline
          charly2008
          In the "Plugins index" is a mistake. This plugin is by Didier Bur.
          Charly
            bebeep2511
            Hi to all!
            Could anyone help me where to download the getcamera distance.rb
            Thanks and regards 🎉 😉
              @bebeep2511 said:
              Hi to all!
              Could anyone help me where to download the get camera distance.rb
              Please learn to use the red 'Plugins Index' button above [single-click]; then the forum OR browser Search tools [e.g. distance]...
              Because I'm feeling kind after my lunch here's a link - I found it in 2 seconds using the simple method I outlined above... http://forums.sketchucation.com/viewtopic.php?p=221768#p221768 next time please try harder before asking, we are here to help... but we prefer 'real problems' 😉
                bebeep2511
                Well- thanks for the help.😄
                  Rubicone
                  I don't know if this has been suggested or considered but I don't think that listing plugins by publisher is very useful. I believe that listing them by the function each serves would be much better - at least from this newbie's perspective. Perhaps as a compromise between what is presently listed and what could/should be, is creating a table that contains all of these plugins. One could create this table using MS Acess (or other database), MS Word, or even Excel. In the attachment is a simple table I created using MS Word that others can comment on if they feel so inclined.
                    There is work being done on plugin repositories. Expect to see something this year. Then things can be sorted as you like.
                      stuartmitch
                      Guys,
                      just wondering if there is a plug-in that assists in drawing on uneven surfaces. I am looking to do some work with shipping containers and, as you probably know, they have a corrugated steel skin.
                      I have tried tools-on-surface but that doesn't work too well with this type of surface (or at least it doesn't when I am using it!!!).
                      Cheers....Scotty
                      • mitcorbM Offline
                        mitcorb
                        @stuartmitch:
                        reference your question "just wondering if there is a plug-in that assists in drawing on uneven surfaces."
                        Would setting cutting planes and intersecting work?
                        Would using Drape, or Stamp from Sandbox Tools work?
                        • mitcorbM Offline
                          mitcorb
                          @majid:
                          What about bentleykfrog's plugin? See in Index.
                            stuartmitch
                            @mitcorb said:
                            @stuartmitch:
                            Tim,
                            I'll give it a go and get back to you.
                            Thanks for the advice.
                            Cheers....Scotty
                            • majidM Offline
                              majid
                              a bit far from the topic, but it is my strong need:
                              recently had strong need to "flightpath", and noticed that it is a long time that it hasn't been updated (and doesn't work for su8), so thought that if there is anyway to ask authors to update them? or any other ruby masters please?
                              Majid
                              • majidM Offline
                                majid
                                @mitcorb said:
                                @majid:
                                thank you mitcorb, but I need Flightpath, that helps smooth animation, using selecting a path for camera movement... is there any other option?
                                  rv1974
                                  Have anybody counted the number of plugins (even approximately)?
                                  • mitcorbM Offline
                                    mitcorb
                                    I guess it is theoretically possible to count all the plugins. There are many unpublished, I am sure. And, there probably are a significant number of sites offering plugins that I have never visited. Not all are free, as you know. And the unpublished ones, if any, would be held by those who don't wish to share or sell.
                                      Where? Here or globally?
                                        Aerilius
                                        as an example, the Plugins page has around 891 and crai around 989 (with old versions/variants). And this does not include commercial plugins that are distributed via other ways, or company's internal tools.
                                          RickW
                                          @majid said:
                                          ...recently had strong need to "flightpath", and noticed that it is a long time that it hasn't been updated (and doesn't work for su8)...
                                          Majid
                                          Can you clarify by what you mean that it doesn't work for SU8? I use it in SU8 without problem.
                                          RickW
                                          [www.smustard.com](http://www.smustard.com)
                                            Trogluddite
                                            Now I can't stop myself seeing an image in my minds eye of SU open on a dozen 21" monitors - somewhere hidden amongst it is the remaining 1 sq.inch of viewport, the rest all containing the ultimate toolbar hell! 😆
                                            • 8 / 9
