    [Talk] Plugins Index
    179 Posts 70 Posters 102.7k Views 70 Watching
      davesec
      hi!
      i realize this is sort of a subjective subject, but could you mark maybe the top 20 'most used' or most useful plugins? i don't mean to demean anyone's efforts here, i'm sure they are all very good, but it would be a big help to me if i knew which ones are useful for almost everybody!
      • Dan RathbunD
        Dan Rathbun
        Dave, Jim's indexer only "sniffs" the information that is displayed on the forum topic list pages.
        There's no way to tell anything subjective. There are number of replies, and number of views, but these can be for other reasons (such as reporting bugs to the author, help requests, new feature requests, etc.) The number of times downloaded for files (in a batch sense,) is only something the sysops can access (I believe.) Yes you can see download number for an individual file, when you actually look AT topic page. But Jim's sniffer does not actually do that. Even if it did... that number cannot indicate much. For instance, it might be a plugin that WAS popular, but is no longer needed for the latest SU version.
        So what would happen, is Jim would need to have his script read a manually maintained "Must Have" list, and then he could mark (special color, etc.) the links for the plugins in the list.
        Any way (for now)... see this sticky topic, which IS a subjective list:
        Must Have Ruby Plugins - Visual Index
        I'm not here much anymore.
        • brookefoxB
          brookefox
          For me it would be helpful if the plugins listed here were also listed here alphabetically. I know I can search for and find any plugin in other ways, I just want my cake with a little icing, please.
          ~ Brooke
          • brookefoxB
            brookefox
            Independently of the above, how about a link to the alpha list at the Ruby Depot?
            http://rhin.crai.archi.fr/rld/plugins_list_az.php
            Yes, I have not fully thought the issues through as probably many have before me, related to outside, however closely allied, links.
            ~ Brooke
            • B
              buddyholly27
              Hi, just a little query that I've not been able to find an answer for.. I've been using the formidable sketchucation plugins for a long time, while I was an architecture student, but now I've joined a large archtiectural practice and would like to know whether it's ok to use the plugins for commercial work?
              Naturally, those that come with a price attached like ThomThom's amazing vertex tools would not be available (or would they?), but how about the vast majority of others?
              The practice I'm working at is quite resistant to Sketchup so I'm fighting an uphill battle, but they've said that I can load in my plugins library if I can prove that to do so will not contravene anyone's copyright/commercial restrictions.
              Many thanks. apologies if this is the wrong thread/forum.
              Ben
              Ps it's only when you go to the forums of other software that you realise quite how amazing the Sketchup community is (not to name names, but one's the sound a frog makes, and the other is a stopping place for really small locomotives - if you catch my drift?)
              • Dan RathbunD
                Dan Rathbun
                Many authors will put a "Terms of Use" clause in the information block at the top of the code. (Some will even list this on the download forum post.)
                You will need to check each plugin individually. If it does not say specifically... post a query to a specific plugin topic (or Private Message the author with a list his/her plugins, and ask them if it is OK to use them for commercial work.)
                • B
                  buddyholly27
                  Thanks Dan, I will start the terms of use trawl, and send PMs out where appropriate, when I get home. Shouldn't complain, after the work that you plugin people have saved me over the years - not to mention the things that I simply wouldn't be able to do at all! Fingers crossed there aren't too many restricted plugins though..
                  Actually, do you think the index page might have an icon range for the copyright/terms for each plugin? (Same icon, different colour according to restriction status?) Probably a whole new can of worms...
                  • Dan RathbunD
                    Dan Rathbun
                    Well no, the Index cannot do that. (It only glean's whatever info the poster puts in the Topic Title.)
                    There is a "convention" to use a "[$]" icon if it's a pay plugin.
                    Cost, Copyright and Terms of Use are all separate issues.
                    Most often an author always claims copyright (in some form,) to protect his work, regardless of cost, or terms of use. (Usually this is to control distribution so that old versions are not floating around out the web. Sometimes a certain license like GPL or Artistic, require copyright notices by the author and each of those who may revise the code later.)
                    And BTW.. technically an explicit copyright notice is no longer required (since 1972 ?, I think,) it is now implied.
                    • charly2008C
                      charly2008
                      In the "Plugins index" is a mistake. This plugin is by Didier Bur.
                      Charly
                      • B
                        bebeep2511
                        Hi to all!
                        Could anyone help me where to download the getcamera distance.rb
                        Thanks and regards 🎉 😉
                          @bebeep2511 said:
                          Hi to all!
                          Could anyone help me where to download the get camera distance.rb
                          Please learn to use the red 'Plugins Index' button above [single-click]; then the forum OR browser Search tools [e.g. distance]...
                          Because I'm feeling kind after my lunch here's a link - I found it in 2 seconds using the simple method I outlined above... http://forums.sketchucation.com/viewtopic.php?p=221768#p221768 next time please try harder before asking, we are here to help... but we prefer 'real problems' 😉
                          • B
                            bebeep2511
                            Well- thanks for the help.😄
                              Rubicone
                              I don't know if this has been suggested or considered but I don't think that listing plugins by publisher is very useful. I believe that listing them by the function each serves would be much better - at least from this newbie's perspective. Perhaps as a compromise between what is presently listed and what could/should be, is creating a table that contains all of these plugins. One could create this table using MS Acess (or other database), MS Word, or even Excel. In the attachment is a simple table I created using MS Word that others can comment on if they feel so inclined.
                                There is work being done on plugin repositories. Expect to see something this year. Then things can be sorted as you like.
                                  stuartmitch
                                  Guys,
                                  just wondering if there is a plug-in that assists in drawing on uneven surfaces. I am looking to do some work with shipping containers and, as you probably know, they have a corrugated steel skin.
                                  I have tried tools-on-surface but that doesn't work too well with this type of surface (or at least it doesn't when I am using it!!!).
                                  Cheers....Scotty
                                  • mitcorbM
                                    mitcorb
                                    @stuartmitch:
                                    reference your question "just wondering if there is a plug-in that assists in drawing on uneven surfaces."
                                    Would setting cutting planes and intersecting work?
                                    Would using Drape, or Stamp from Sandbox Tools work?
                                    • mitcorbM
                                      mitcorb
                                      @majid:
                                      What about bentleykfrog's plugin? See in Index.
                                        stuartmitch
                                        @mitcorb said:
                                        @stuartmitch:
                                        Tim,
                                        I'll give it a go and get back to you.
                                        Thanks for the advice.
                                        Cheers....Scotty
                                        • majidM
                                          majid
                                          a bit far from the topic, but it is my strong need:
                                          recently had strong need to "flightpath", and noticed that it is a long time that it hasn't been updated (and doesn't work for su8), so thought that if there is anyway to ask authors to update them? or any other ruby masters please?
                                          Majid
                                          • majidM
                                            majid
                                            @mitcorb said:
                                            @majid:
                                            thank you mitcorb, but I need Flightpath, that helps smooth animation, using selecting a path for camera movement... is there any other option?
                                            • 7 / 9
